Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1321 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2011 Location: pakistan
Member: 1524022 Status: Offline Sonork: 100.1608738 Thanks Meter: 51 | nokia 225 4g ta-1279 read code done. 1. Power off device, remove battery 2. Not hold any key on device! 3. Insert battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SW_VER : 11.00.17.02 LP_VER : IJ 23QEN79PK00 UserCode : 25815 UserCode : 4488 Done! Elapsed: 00:00:36 Reconnect Power/Cable! |
![]() | #1322 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,743 | Nokia 108 Reset Password Done By Cm2 Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM4) MODE : NOKIA USB SERIAL PORT : 4 BROM : Init BROM BROM init passed! CHIP : MT625A , SBID : 0xCA01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : E634A46AB8B7EBAB190E801B2B1E1F27 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : Bree.20.06.11.p4 BOOT : SWR : 20.06.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT625A AGENT : Bree.20.06.11.p4 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x88 NOR: 00EF : 0040 : 0016 : 0000 NOR: [WINBOND] W25Q32BV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x003A6000 : 0x0004E000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:44 Reconnect Power/Cable! |
![]() | #1323 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: Sindh Pakistan
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,368 | ![]() Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM43) MODE : NOKIA USB SERIAL PORT : 43 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : E8554F6BB1174BE17793D0E199BB9242 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : SUEZ.40.00.11.p1 BOOT : SWR : 40.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : SUEZ.40.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00CE0000 : 0x00314000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:05:00 Reconnect Power/Cable! |
![]() | #1324 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,368 | ![]() Operation: Reset Settings/Format FS [ v2.40a3 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: SMART RESET Wait... WARNING! Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM6) MODE: PRELOADER PORT; PORT: 6 Waiting BOOT ack... PRELOADER: ACK confirmed BROM: Init BROM Init passed CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] AGENT: Tecno: SEC_MIXED | Manual: Off [4375bf5d] C:\InfinityBox\CM2MT2\boot\Tecno\SEC_MIXED\MTK_All InOne_DA.bin Looking for suitable BootChain in DA... Switch to v2216 Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MediaTek USB Port_V1633 (COM3) MODE: BOOTROM; PORT: 3 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM Init passed CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: 3380CC35EC21D48E270940BC631A05B1 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: F3737B8F7B118ADB58DDD28511A6D182CDA2D519F95F440E50 86F30A4A8E453B SLA: Local Auth SLA: Starting Auth FireFly: Look for EMI FireFly: EMI found SLA: Auth Passed; SEC: 0x000000E0 AGENT: Tecno: SEC_MIXED | Manual: Off [4375bf5d] C:\InfinityBox\CM2MT2\boot\Tecno\SEC_MIXED\MTK_All InOne_DA.bin Looking for suitable BootChain in DA... Switch to v2216 Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Transfer control to DA... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 90014A6843396150330100508F2C1883 VEN: Hynix OEM: 74 ID: 684339615033 [hC9aP3] PRV: 0x01 SNN: 5279532 [0x00508F2C] MF: 1/2021 EMI: FireFly with 13 memory type(s) supported EMI: Init EMI from INTERNAL Database EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC CID: 90014A6843396150330100508F2C1883 VEN: Hynix OEM: 74 ID: 684339615033 [hC9aP3] PRV: 0x01 SNN: 5279532 [0x00508F2C] MF: 1/2021 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0xE8F800000 [ 58.24 GB ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 5E2D150DF7C4FF8C5F18027D745E0910 MEID: 3380CC35EC21D48E270940BC631A05B1 USB: HIGH-SPEED Boot done [1] Reading... Ok SmartInfo: AndroidVer: 10 UserDataFS: 0x03 CacheFS: 0x02 Strategy: 7 Verify device config... Ok Loaders Ok Backup [20] to C:\InfinityBox\CM2MT2\backup\MT6768__3380CC35EC21D 48E270940BC631A05B1\ [27] Read: NVRAM [10] Read: NVDATA [3] Read: PROINFO [28] Read: LK [9] Read: NVCFG [12] Read: PROTECT1 [1] Read: PGPT [11] Read: PERSIST [0] Read: PRELOADER Done 9 files Compress: C:\InfinityBox\CM2MT2\backup\MT6768__3380CC35EC21D 48E270940BC631A05B1\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6768__3380CC35EC21D 48E270940BC631A05B1.7z Verified [1] Process: RESET PROTECTION... Format Ok: RESET PROTECTION [2] Process: USERDATA... Format Ok: USERDATA [3] Process: CACHE... Format Ok: CACHE [4] Verified [5] Verified [6] Process: USERDATA... Format Ok: USERDATA [7] Process: USERDATA... Format Ok: USERDATA [1] Verified [2] Verified Done: 00:01:21 Reconnect Power/Cable now |
