Member: 391664
Sonork: Python Thanks Meter: 1,063 | Quote:
Originally Posted by JayDi That is not SX4 issue, problem in device NVM/NVServer.
Make sure you have installed SW version inside decie same, as product code on back sticker. Re-flash it with NVM update enabled and reboot device twice ( with complete init, until work table ) before unlock try.
Make sure ENOSW version is same, as base SW or newer! | Quote:
Card found: S/N : 62188684 , v0122
Registered to: maplegsm
Connect phone on selected interface...
=== Main info ===
NCSD Version : 5.1
Sw Version : 02177.00000.15221.30006
IMEI : 355159065579240
ProductCode : 059W5M7
ProductCodeB : 059T3H8
ProductSN : 72DA4D5AU
Module Code : 0205888
=== HW info ===
Public ID : C94C7C3F682B6D0FF63E708E94014789EDEB84D0
HW Version : 1000
BT Addr. : 74E28CDEC5A3
Wlan Mac : 74E28CE13514
Battery Level : 90 %
=== Branding and security info ===
Operator : ORG-GB
SimLock : Locked!
SimLock : 0000000000000
Country : Unknown
Operator : Unknown
Branding : RM-984_1017
Sec. Mode : Restricted
Done!
Core : v2.29 , WP10x FlashEngine : v3.2
FFU : RM984_02177.00000.15184.36003_RETAIL_prod_signed_1 006_026570_000-IN.ffu
Checking FFU file, wait...
FFU Revision ID : 2.0
FFU Model ID : Nokia.MSM8926.P6122
FFU RootKeyHash : 0000000000000000000000000000000000000000
FFU Languages : Portuguese(Brazil) , Russian , Greek , fr-ca , Indonesian , Korean , Polish , bn-bd , Uzbekistan(Latin) , Catalan , Swedish , Bulgarian , Japanese , Spanish , English (UK) , Czech , Latvian , Slovak , Chinese , sr-latn-rs , Vietnamese , af-za , Hindi (India) , gl-es , Turkish , Thai , Italian , Danish (Denmark) , ha-latn-ng , Slovenian , Malay (Malaysia) , Lithuanian , Persian (Iran) , Kazakh , Romanian , English , eu-es , Estonian , Filipino (Philippines) , Belorusian , Norwegian (Bokmal , Norway) , Finnish , lo-la , km-kh , Arabic , Ukrainian , Croatian , Portuguese(Portugal) , Chinese(Taiwan) , Macedonian , Hungarian , Spanish(Mexico) , Azerbaijan(Latin) , German , Albanian , Dutch (Netherlands) , French , sw-ke , Hwbre (Israel) ,
FFU ChipSectors : 20971520
FFU Header : 0x000E0000
FFU Payload : 0x72820000
FFU FastVerify : Ok
Waiting for phone...
=== Base Phone Info
=== Setting Flash Mode
Device catched in BOOT mode!
Collect Info...
=== Nokia Flash App info :
Protocol Version : 2.37
Protocol Implementation : 2.60
=== Phone Initial info :
Phone Model ID : Nokia.MSM8926.P6122.1.1
=== eMMC info :
eMMC Vendor : Toshiba
eMMC CID : 0011
eMMC Size : 15028 MiB
=== Security Initial info :
Security Status : 010100000101
Secure Boot : Enabled
Secure eFUSE : Enabled
JTAG : Disabled
RDC Key : Not Present (Retail)
UEFI SBoot : Enabled
SecHW Key : Exists
Device RootKey : 7E07F43C43AA9A241426EA94D70F9BD82C67DEBF
=== Other info :
SD present : False
Full Check skipped , will be checked by ImageSignature
Battery Level : 96%
RPMB Provision Status Code : 0x0101
Device RAM size : 1024 MiB
Device have ATRP (AntiTheft) system!
Backup to RAM Ok!
Flashing FFU
Sending FFU Header CertData
Header sent , accepted
Perform Data Partition Erase
Erase done
Sending FFU Payload Data...
Finishing flashing
Flashing done!
Green Light
Image Sent, processing PostFlash
FinalConfig : abnormal status, error code : 0xFF7B0000
Make Factory Set : Ok
Restore RAMBkp : Ok
Update NVI from Image
Ok , NVI will be updated on first boot!
PostFlash Finished
Total flash time : 00:05:39
Rebooting
Phone found!
WP10/WP8x Lumia Phone detected
Read info... Ok
Phone disconected!
Phone found!
Read info... Ok
=== Main info ===
NCSD Version : 5.1
Sw Version : 02177.00000.15184.36003
=== HW info ===
HW Version : 1000
Battery Level : 89 %
Operator : 000-IN
SimLock : Locked!
Country : Unknown
Operator : Unknown
Branding : RM-984_1006
Done!
after flashing sim status showing this
before showing this
Phone found!
Read info... Ok
=== Main info ===
SecLabel Version : Security LabelSW (wim) 20.2169.385.194
Sw Version : RM984 2177.0000.9651.15148 806906 2015/04/30 //romulus_engine/L1_RG2\r\n
=== HW info ===
Conf key : 8000000000000000
Provider key : 2343300190233141
Country : United Kingdom
Operator : Orange
Counters : Key 0 [3] , Fbus 0 [10]
Blocks : 2
LOCK STATUS :
BLK : 1
Lock1:Close
BLK : 2
Lock1:Close
LOCKS : Closed
Making RPL backup...
NPC : Read Ok , [520]
CCC : Read Ok , [352]
HWC : Read Ok , [212]
RDC : Certificate not available
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\355159065579240_CR T.rpl
Done!
SD Already Authentificated!
Done!
WP8 Unlock Started
Connecting to server...
Connected
Authenticating...
Authenticated
Checking Client version...
Client version is valid
Processing Step #1
Processing Step #2
Processing Step #3
Processing Step #4
Disconnected
Unknown result , something wrong with SDauth or Data #1 , try "Unlock" again!
Error! Check previous error message for more info!
Phone disconected! |
