12-11-2018, 06:13 | #1 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 130 TA-1017 Dead Possible To Repair or Not ? Setting : UserData erase : False Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM566) MODE : NOKIA USB SERIAL PORT : 566 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 364984A259B9831BCBC826998D8B9512 BROM : Run BootLoader ... BROM : BootLoader start Failed! Check device Battery and BSI line! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Last edited by Akhtar Ali Jatt; 12-11-2018 at 06:19. |
06-30-2020, 08:28 | #2 (permalink) |
Insane Poster Join Date: Sep 2016 Location: Peshawar, Pakistan Age: 40
Member: 2622185 Status: Offline Sonork: 100.1675196 Thanks Meter: 19 | Operation : Write FirmWare [ v1.19 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM12) MODE : NOKIA USB SERIAL PORT : 12 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCA02 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 15EF5E7E7EC23DEF7F0711A88FAF4F3F BROM : Run BootLoader ... BROM : BootLoader start Failed! Check device Battery and BSI line! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! |
