11-09-2020, 11:34 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: City of Temples
Member: 729381 Status: Offline Thanks Meter: 247 | ta-1076 flashing error need help on this Code: Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Load : D:\Nokia\OSTLA_CO2-4160-0-00WW-B01_000\Data\CO2-4160-0-00WW-B01.nb0 Load Ok! Operation : Write FW [ v1.20 ] Setting : UserData preserve : False Setting : Flash Pre-Erase : True Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM26) MODE : BOOTROM PORT : 26 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6755 AGENT : BEST_Nokia_DA_v19_1711_06 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100475836424D4203FE2BD23515AD EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GX6BMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : FE1C2C9F2372BFB0A1C5BA3882FA0537 DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM6) MODE : PRELOADER PORT PORT : 6 Boot done! DL_INFO : PMT present SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : HW verification passed! Erase : 0x0000000000000000 : 0x0000000000BC8000 Erase : 0x0000000003BC8000 : 0x0000000004000000 Erase : 0x0000000009000000 : 0x0000000001000000 Erase : 0x000000000A880000 : 0x0000000001E00000 Erase : 0x000000000C6A0000 : 0x0000000000100000 Erase : 0x000000000D4A0000 : 0x00000000C5360000 Erase : 0x00000000D3100000 : 0x0000000185700000 PMT Update : OK Flashing now ... PROCESS : PRELOADER Unpack : CO2-0-4160-00WW-preloader_CO2.bin Flash : CO2-0-4160-00WW-preloader_CO2.bin Update bootloader backup copy ... Update bootloader backup copy Ok! PROCESS : LOGO Unpack : CO2-0-4160-00WW-logo.bin Flash : CO2-0-4160-00WW-logo.bin PROCESS : SECRO Unpack : CO2-0-4160-secro.img Flash : CO2-0-4160-secro.img PROCESS : MD1IMG_A Unpack : CO2-0-4160-md1img.img Flash : CO2-0-4160-md1img.img PROCESS : MD1DSP_A Unpack : CO2-0-4160-md1dsp.img Flash : CO2-0-4160-md1dsp.img PROCESS : MD1ARM7_A Unpack : CO2-0-4160-md1arm7.img Flash : CO2-0-4160-md1arm7.img PROCESS : ODMDTBO_A Unpack : CO2-0-4160-odmdtbo.img Flash : CO2-0-4160-odmdtbo.img PROCESS : LK_A Unpack : CO2-0-4160-00WW-lk.img Flash : CO2-0-4160-00WW-lk.img PROCESS : BOOT_A Unpack : CO2-0-4160-00WW-boot.img Flash : CO2-0-4160-00WW-boot.img FLASH ERROR : SEC_IMGHDR_TYPE_MISMATCH Error : Flashing failed! Make sure device HW is in normal condition, check battery and cable! Reconnect Power/Cable! |
