11-16-2017, 10:05 | #1 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,806 | Very important how to avoid contact service in new nokia phone hi in old nokia phone u get contact service when u downgrade phone version as security file damaged rpl etc but in recent time u get contact service after flashing lower or higher version but not the version is the problem but manfucturer after nokia fall in buisness microsft bought it and issued new nokia such as nokia 105 on phone cover nokia name and nokia logo on sofware but on sticker microsoft after 2016 nokia bought buy HMD global u will read HMD global on phone sticker under battery so if flash Nokia by Microsoft with hmd global version u will get contact service and vice virsa ok first before u flash phone do this open Best go mtk section service tab tick rpl only and press flash then connect phone now from log u can check version just flash phone with same version in log but if u got phone with contcat service issue do same method read flash with rpl only ticked if in log Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive Mobile Info just flash phone with same version in log or with lower if phone by microsoft or higher if by HMD global but if u get this in log after reading rpl CBR Info is wrong! CBR SN not match with BB SN! Say thanks to some "great chinese tools" for kill your phone If backup not done - phone just a brick then no solution this happen after flashing some chinese boxes that support nokia but destroy them if post helpful press thank button |
The Following 90 Users Say Thank You to profkefah For This Useful Post: |
11-21-2017, 12:34 | #4 (permalink) |
Freak Poster Join Date: Oct 2010
Member: 1423054 Status: Offline Thanks Meter: 7 | bro i am getting error after flash wrong file for nokia 225 can u help me tiger bhai how to solve this error any idea Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 11 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 7C04F71A12419CB09A9C1B44CFA4CAFE BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL failed! (Bad ACK) BL INIT : DEAD BootLoader Init Failed (HW/Connection Error) Connect phone on selected interface... Boot Error Flashing failed! nokia 225 getting error Sent from my iPhone using Tapatalk |
02-06-2018, 15:35 | #10 (permalink) |
Insane Poster Join Date: Aug 2011 Location: United States
Member: 1629444 Status: Offline Thanks Meter: 47 | thanks. but Project ID in log just show us which file on the phone, not which file can solve the contact service. before flash: Project ID : SUEZ.30.01.11.p1 after flash: Project ID : SUEZ.12.00.11.p1 |
02-07-2018, 07:55 | #11 (permalink) |
Member: 2371500 Status: Offline Thanks Meter: 5,806 | as i wrote by log u will know before flashing which version in phone ]so u flash same one |
The Following User Says Thank You to profkefah For This Useful Post: |
