Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 11-24-2017, 07:28   #1 (permalink)
Member: 220595
Thanks Meter: 355
WinUSB Driver issue with Lumia 640 LTE
Hello
Today am trying to connect a Lumia 640 LTE RM1073
in normal m ode
all I see in device manager is three unknoen devices with yellow circled exclamation mark
named : Lumia 640 LTE (RM.1073)
same name for the three.
I installed the lumia 2016 drivers (all) from support
Installed Zune, WMDC, Windows Device Recovery Tool, etc
and there is no way to make the device to be catched by drivers.
is there a way to forcely install de correct driver ?
PS: Same issue in two different computers, both runing windows 7 64bit.
PS2: I have worked othe rLumia phones in these computers before...
Old 11-24-2017, 08:19   #2 (permalink)
Member: 220595
Thanks Meter: 355
Hello
I managed to forcedly install the WinUSB Drivers
I found a folder in "program files" which had some drivers and I manually installed from there. I selected all as WinUSB and it worked,
I entered Test mode using secwim file and after test mode is set I had to install same drivers to all devices and all went well.
I uploaded the drivers here just in case anyone need to do the same.
****************************/file/t9fn9d365i6tgnb/lumia%20drivers%20to%20force%20install%20use%20WinUSB.rar
The Following User Says Thank You to yurais For This Useful Post:
Old 07-19-2018, 03:32   #3 (permalink)
Member: 2299654
Thanks Meter: 25
Originally Posted by yurais View Post
Hello
hello .. I have the same problem I can not install the 3 drivers .. you can help me .. my email is hxc*****[email protected] ..
regards
Old 07-19-2018, 06:49   #4 (permalink)
Member: 2548908
Sonork: 100.1672479
Thanks Meter: 761
Follow This Step 100% Solved
Old 07-20-2018, 02:37   #5 (permalink)
Member: 2299654
Thanks Meter: 25
Hi .. thanks for answering .. I give that option to install the drivers and they do not install ..
Old 07-20-2018, 03:22   #6 (permalink)
Member: 2299654
Thanks Meter: 25
solved ... you have to disable the 3 drivers that it marks as "Lumia 640 LTE (RM.1073)" and do not install and only leave the ones that appear "Lumia normal mode" ... so it will not recognize these Lumia 640 LTE drivers (RM.1073 ), that's why you have to disable .. greetings
Unlock Done
The Following 2 Users Say Thank You to loganvp94 For This Useful Post:
Old 07-20-2018, 04:09   #7 (permalink)
Member: 220595
Thanks Meter: 355
Unlock Done
Great to see you got it
Enviado desde mi SM-G930F mediante Tapatalk
Old 02-27-2021, 14:16   #8 (permalink)
chlakh11787's Avatar
Member: 378892
Thanks Meter: 51
link ****************************/file/t9fn9...e%20WinUSB.rar
not found can you reupload it pls
Old 02-27-2021, 14:17   #9 (permalink)
Member: 378892
Thanks Meter: 51
reset code unlock
Page generated in 0.18527 seconds with 8 queries
