Dragon Box Chinese Phone Tool |
10-03-2012, 11:08 | #2 (permalink) |
Freak Poster Join Date: Feb 2010
Member: 1231601 Status: Offline Thanks Meter: 13 | Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=6 TXD=7 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700900006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_K5N6433ATB setting the Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A Failed to get address of NV. Read FS info...done |
10-03-2012, 14:03 | #4 (permalink) | |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
use usb method low baudrate like 115200. BR. Arsalan gsm2000 | |
10-03-2012, 15:15 | #5 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | SPD 6610 / 20 needs 112500 Baud Rate. Try with the Baud Rate as mentioned above and post the screen shot of Dragon Connecting windows. BR Dipendra Pathak |
10-04-2012, 07:50 | #8 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Write working file from working phone to this faulty phone and post the Screen shot of Dragon Connecting windows brother. BR Dipendra Pathak |
10-04-2012, 08:46 | #9 (permalink) |
Member: 1231601 Status: Offline Thanks Meter: 13 | Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=6 TXD=7 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 66100000004E6A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. phone is on but no service |
