Dragon School<<< Problems and Solutions >>> |
Q: i connect the gpgdragon to computer,and install the dirver ,computer have give me the new com port,but i can't connect mobile and all no working you need use the computer behind USB port if you use the computer In front of USB port,the Power supply insufficient |
how to do work with GPGdragon when Norton Antivirus Installed Double-click the Norton Antivirus software in your system tray. This opens your configuration window where you have several options. Click the "Scan" button on the left side of the window. Click "Custom Scan" and click "Options." This displays a list of options for the scanning process when Norton Antivirus detects viruses. Click "Security Risks." Click "Exceptions" and click "Add." This opens a configuration window where you add exceptions to any antivirus scan rule. Select a GPGDRAGON on your list of software exceptions. Norton lists each program installed on your computer, so you can eliminate the scanning process for your programs each time they load on your computer. Click "OK" to save your changes. After you create the exception, you can either re-scan your computer for viruses or leave the exception for the next time you do a system scan. Br Faisal_Computer |
China mobile P-08A(mini 8P) after pinfind stop example Initializing... DA_LIB_VER_2.4.4.7 It is sensing the pinout fast,please hold on the phone Power key RXD=6 TXD=5 Connecting...Please hold on the POWER key until the red run the gpgdragon freeware setting pinout 1:H-level 6:rx 5:tx working Q:why need do this?? A: any china mobile need setting the "charge pin" like mini 8P the charge is 1 pin or 2 pin and zte cdma mobile is 8P you need give the charge H-level and rx\tx same like the pinfind |
how can i change the SPD imei http://forum.gsmhosting.com/vbb/f646...100-a-1162032/ form gpgdragon team all worker thanks ayaz ali post this one |
problem :Error: Unsaft EFS Address, Please input the right format address and try again. Failed to auto format. solution :formatting not support in this moments you need to full flash the set from working files file can be read from other same working phone |
how to slove the gpgdragon software only SPD only can read info(can't format \flash\unlock) download the last ver gpgdragon ver 1.12(if you use the gpgdragon 1.10 now is stop no working with SPD mobile) if you use the gpgdragon ver 1.12 same promber i think you have change the computer time before you need change the time same like now after run the install the new windows system and download the new gpgdragon ver 1.12 again now will working |
Error: Failed to RX buffer, Please close all other program or change baudrate and try again. or you got error analyze file error while changing Imei of spd please check success solve the problem reported by our nice user !! : http://forum.gsmhosting.com/vbb/6805485-post9.html |
RXD=7 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Unsupport CPU, Please select another boot and retry again! just change the boot ver to 3.952 |
about the DM DP in the SPD 6600L PCB Today have one gpgdragon user connect my msn talk with me, this mobile is SPD WT6228,is New CPU,use the P-08A(mini USB) i run the gpgdragon software,select 6600L-COM and 6600L-USB but can't working,can't pinfind he is very good and help me open the mobile check the mobile have 5 connect pin have DM and DP,what is it is same like USB+ and USB- use the RJ45 connect to mobile PCB and connect to BOX rj45 working 100% but have one i can't sure,is WT6228 or no? the CPU can check it,if who have WT6228 CPU if you can help me check can it run in the gpgdragon is very good for gpgdragon user thanks http://www.mtk-box.com/pic_old/zhu/SPD_DM_DP.jpg |
if software only read info and did not do any thing else please read it http://forum.gsmhosting.com/vbb/6768959-post5.html Br Faisal_Computer |
Code: Nor Flash ID: 0000000000000000 Bad Flash Chip ,just rehot or change this problem solved Code: Initializing... Code: Nor Flash ID: 0098000300000000 Code: Read info is done. Checking box, wait... Box Firmware version: 1.43 Warning: requires firmware version 1.52, or higher... Device not found Need to update the box fimware To latest one v1.52 updater of firmware you can find on v2.01 folder |
Error: Your software has been restricted. http://forum.gsmhosting.com/vbb/f646...-week-1212208/ Advice : do not change your date , when ever you try to update your box firmware must check date and time , once you install your box and its working fine PLEASE make restore point , if you want to change date and time of your pc you can do but do not turn on GPGDRAGON software , when you want to use gpgdragon software set date and time back to normal then open it , also check your computer's mother board ( mainboard) cell inside , it must be good strongly recommend to use http://forum.gsmhosting.com/vbb/7018153-post1.html Br Faisal_Computer |
