Dragon Box Chinese Phone Tool |
12-10-2013, 09:10 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india
Member: 1140831 Status: Offline Sonork: no Thanks Meter: 232 | Karboon Android A1+ wake up from the Dead, Thanks Dragon Team!!! story my set my set on i m reed flash file but after reading set dead thx you dragon team >> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM7 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:00002CBC Flash Size:20000000->512M Flash Name:NAND_SamSungMT29C4G48MAZAPAKD CPU Name:6820/8810 >>> -Analyzing Flash File... Get Flash Format: User Read Full Flash... Flash Size:0X1FFE0000->511M >>> Decompressing file... NV_ADD :0x00640800 SIZE: 0x0000D1B0 SPL_ADD :0x00000000 SIZE: 0x00042000 UBOOT_ADD :0x00000000 SIZE: 0x0005FFA0 VMG_ADD :0x000C0000 SIZE: 0x0003D000 MODEM_ADD :0x1F040000 SIZE: 0x00642458 DSP_ADD :0x1FA40000 SIZE: 0x00200000 BOOT_IMG_ADD:0x01200000 SIZE: 0x006C6000 REC_IMG_ADD :0x01A00000 SIZE: 0x006E3800 SYSTEM_ADD :0x02200000 SIZE: 0x0A256000 USER_ADD :0x1AA01800 SIZE: 0x00000800 BOOTLOGO_ADD:0x00000000 SIZE: 0x01000000 Special remind:if you tick the system,maybe it will kill your phone!!! Waiting For Your Confirmation...>>> Writing Flash File... Write_UBOOT... Write_VMG... Write_MODEM... Write_DSP... Write_BOOT_IMG... Write_REC_IMG... All Done... |
The Following 6 Users Say Thank You to parmodparmod For This Useful Post: |
12-10-2013, 11:26 | #3 (permalink) |
Freak Poster Join Date: Oct 2011 Location: india,,,jammu
Member: 1668548 Status: Offline Sonork: 100.1647046 Thanks Meter: 24 | @GPGDragon Help my karbonn goes dead by mistake...... it flash in dragon with .pac file ....set goes onn but stuck on logo.... plz |
12-10-2013, 11:27 | #4 (permalink) |
Freak Poster Join Date: Sep 2010 Location: Pune, MH, India
Member: 1398382 Status: Offline Thanks Meter: 57 | Thanks for Report but Always Post Screenshot. Next time post in Correct section. http://forum.gsmhosting.com/vbb/f646...hones-1129576/ Regards, Yunus |
12-11-2013, 02:55 | #5 (permalink) |
Junior Member Join Date: May 2013 Location: India
Member: 1946485 Status: Offline Thanks Meter: 6 | @ parmodparmod Good work but confuse which model use it..? GpdDragon which version use it....? GpdDragon where is screen shot image....? Flash file use it..........? Always full screen results post here. |
12-11-2013, 08:45 | #7 (permalink) |
No Life Poster Join Date: Jul 2007 Location: kolkata, india
Member: 553420 Status: Offline Sonork: 100.1624012 Thanks Meter: 129 | my set is alive by writing backup flash readed by volcano, but restarting on logo.....i also tried to write factory file(v2.0.8) with factory flasher but same hang and restart problem.......plz share good working flash file...... |
12-11-2013, 19:30 | #8 (permalink) |
Freak Poster Join Date: Dec 2004 Location: Hello Age: 38
Member: 99115 Status: Offline Thanks Meter: 99 | karbonn a1+ dead/blinking solution if set goes in usb debbuge mode then wipe data with multi tool if same problem then you have to flash with factory flasher we can use volcano/dragon/modified usb by umeshgaba as interface for flash main point is that which file selected in 4 files in factory flasher for hw_info.img for me always works file XYL_XYL635143-1B_ILI9487_35_CMO_KMOEB_PZ286_DZTX_HW_info.img if that hw_info.img not works then try all 4 files. your set should alive |
12-11-2013, 20:06 | #9 (permalink) |
Member: 99115 Status: Offline Thanks Meter: 99 | after successful flash there will be some red mark on screen. then go to setting reset phone now red mark gone but imei will not same as on stiker. connect phone with usb in on condition with enable ud and change imei with factory imei changer |
12-13-2013, 06:14 | #11 (permalink) |
Member: 1140831 Status: Offline Sonork: no Thanks Meter: 232 | dear friend plz no reed you set flash file if you reed file set is dead so plz no red because your set flash file not proper read box my set after red dead and gpg team help my set on i think modified my read flash flash file the team then my set is on so connect GPGDragon Help (Sonork: 100.1597111) i think if one by one file read ( 1 nv read and save 2 spl read and save and other all file read and save i think set is not dead ) NV_ADD :0x00640800 SIZE: 0x0000D1B0 SPL_ADD :0x00000000 SIZE: 0x00042000 UBOOT_ADD :0x00000000 SIZE: 0x0005FFA0 VMG_ADD :0x000C0000 SIZE: 0x0003D000 MODEM_ADD :0x1F040000 SIZE: 0x00642458 DSP_ADD :0x1FA40000 SIZE: 0x00200000 BOOT_IMG_ADD:0x01200000 SIZE: 0x006C6000 REC_IMG_ADD :0x01A00000 SIZE: 0x006E3800 SYSTEM_ADD :0x02200000 SIZE: 0x0A256000 USER_ADD :0x1AA01800 SIZE: 0x00000800 BOOTLOGO_ADD:0x00000000 SIZE: 0x01000000 plz tell me this is baseball one by one file reading Last edited by parmodparmod; 12-13-2013 at 06:20. |
12-13-2013, 07:34 | #12 (permalink) | |
Member: 1668548 Status: Offline Sonork: 100.1647046 Thanks Meter: 24 | plz help dear pm i had already req.. my set goes alive....but hang in logo ...plz hel Quote:
dear pm i had already req.. my set goes alive....but hang in logo ...plz help ..... i done as u say " baseball one by one file reading".......but set gos onn ...hang in logo ......r help me via sending flash file of"" karbonn smart a35"" | |
12-13-2013, 10:44 | #13 (permalink) | |
Member: 1668548 Status: Offline Sonork: 100.1647046 Thanks Meter: 24 | karbon a35 stuck on logo Quote:
