Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Dragon Box
Dragon Box Chinese Phone Tool
Old 01-30-2013, 15:22   #1 (permalink)
Member: 1106460
Thanks Meter: 35
dragon team pliz check this error in rokea 5570
now the set is dead is and it had pattern problem,it cant finish flashing.check out this error and fix it....................regards
>>> Getting Mobile Connection Info...
VCC Pin:9,
GND Pin:2,
Signal Pin:3, 4, 5, 6, 7, 8, 10,
>>> Scanning Mobile PinOut...
>>> Please Hold the Power key...
Get Mobile PinOut: TXD:7 RXD:5
Mobile Connection Success...
Mobile Firmware Version:SPRD3
>>> Downloading First Boot...
>>> Mobile Info
Project ID :Spreadtrum Boot Block version 1.1
>>> Downloading Second Boot...
Baud Rate is Switched To:921600
>>> Mobile Info
CPU Name:6803H
Flash ID:0000AD36
Flash Size:04000000->64M
Flash Name:NAND_HYNIXH8BCS0CG0MBR
>>> -Analyzing Flash File...
Get Flash Format: User Read Full Flash...
Flash Size:0X04200000->66M
Detecting Flash File Format : Full Flash File...
Document processing success...
c:\temp.bin
>>> Decompressing file...
NV_ADD :0x013B4000 SIZE: 0x00010000
BOOT_ADD :0x00008000 SIZE: 0x00018000
KERNEL_ADD :0x00000000 SIZE: 0x00000000
USER_ADD :0x00000000 SIZE: 0x00000000
MMIRES_ADD :0x013D0000 SIZE: 0x02B010C0
UDISK_IMG_ADD:0x02A10400 SIZE: 0x00084C00
PRELOAD_ADD :0x02A95000 SIZE: 0x0143C0C0
Waiting For Your Confirmation...
>>> Writing Flash File...
Write_NV...
Write_BOOT...
Write_USER...
Write_UDISK_IMG...
Write_PRELOAD...
>>> Return DATA Error!!!
Terminated...
Old 01-30-2013, 15:44   #2 (permalink)
Member: 1106460
Thanks Meter: 35
Originally Posted by rraza View Post
scan pinout sine out bro
bro wat do you mean by this ....???? its a software bug,should solved by the dragon team coders.....
Old 01-31-2013, 06:56   #3 (permalink)
Member: 1106460
Thanks Meter: 35
VCC Pin:9,
GND Pin:2,
>>> Mobile Info
>>> Mobile Info
CPU Name:6803H
Flash ID:0000AD36
c:\temp.bin
Write_NV...
Write_BOOT...
Write_USER...
Write_UDISK_IMG...
Write_PRELOAD...
Terminated...
please product supporter check this and come up with a solution........ASAP
Page generated in 0.13313 seconds with 8 queries
