Dragon Box Chinese Phone Tool |
01-22-2011, 20:25 | #167 (permalink) |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | Sucessfully Unlock ZTE X760 WIth GPG and Z3X NP Unlock SP Unlock Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=7 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098000300000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... Project ID: X760_Z10UK_GD_BFFA112 Now on MTK TOOL Z3X And select model then comport gpg dragon Selected model is:Orange Vegas Updating Flash Configuration... Welcome to MTKModule v1.6.0.2 Card S/N:000x-xxxx Card ver.2.2 BROM.DLL Version :BROM_DLL_v3.932.00 From 2009/10/08 17:34:16 META.DLL Version :META_DLL_v5.808.00 From 2008/02/22 13:33:14 Detecting Loaders ... Download Agents Found :0 Ready. Selected model is:Orange Vegas Starting flasher module.... [BOOT_MODE] Boot filename: (null) Reconnect battery and press power button now! Getting MCUID... Booting... You can release power key now! Project Name: MT6225_S00 RAM Detected : 64Mb SRAM NOR Detected : (128Mb+64Mb) [TOSHIBA] TC58FVM7TDD NAND Detected : N/A Advanced detection information: BBCHIP: "MT6225_S00", EXT_26M CODE(0x6225), VER(0x8A05), SW(0x8A00) NOR_ID: "[TOSHIBA] TC58FVM7TDD" NOR_ID: 0x0098, 0x0003, 0x0000, 0x0000 NAND_ID: "NAND_UNKNOWN" NAND_ID: 0x0000, 0x0000, 0x0000, 0x0000 Detection Done! Reading NOR : "C:\Program Files\Z3X\MTK\MTKBOOT.TMP", 0x00000000:0x00080000 Operation Done! Setting NOR buffer size :1000000 PostProcessing Boot File ROMINFO V4 Structure found! Ver.:ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z10UK_ GD_BFFA112.BIN Platform:X760_Z10UK_GD_BFFA112 Filesystem:00E00000:00200000 Security:004CD5CC:00000074 Done! Wait for target power On ... Connected in META Mode. (Release Pwr Button!) BaseBand Chip version : MT6225, E05 DSP Firmware ver. : 2006.06.14 Software version : X760_Z10UK_GD_BFFA112 Hardware version : ZTEMT25_07A_HW_C Melody version : Melody V0.0 Test Mode OK. System Disk Mounted... Size:1362944 , Free:648192 Reading NVM Data... Decoding... Setting Userlock to:1122 Writing... META_FAT_Delete(): ERROR: [FAT] Target FAT file not found. Verify... Unmounting FS... Shutting Down the phone... Unlock Done... All Done Thankx GPG Dragon |
The Following User Says Thank You to ..::Rizwan::.. For This Useful Post: |
01-24-2011, 11:53 | #168 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Pakistan Age: 41
Member: 616556 Status: Offline Thanks Meter: 112 | B Boom X8 Formate done Problem Hange on Call Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Loading boot... INT_SYSRAM_BOOT test completed. Nor Flash ID: 00EC240400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... Project ID: C100.SE.HZ10.101125.01 Changing baudrate to 921600... Done. Formating Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
The Following User Says Thank You to zahidnawaz For This Useful Post: |
01-25-2011, 12:55 | #169 (permalink) |
Freak Poster Join Date: Jan 2011 Location: GIA LAI VIỆT NAM
Member: 1500952 Status: Offline Thanks Meter: 164 | flash infineon done avator box used by GPG Dragon [IMG]http://cB4.*****.com/19.0.24518373.Z2Y0/20110125183607.png[/IMG] [IMG]http://cB7.*****.com/19.0.24518386.Vru0/hinhanh001.jpg[/IMG] |
01-26-2011, 11:51 | #170 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | lephone c2 unlock done lephone c2 unlock done with GPGDRAGON READ INFO Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast... D-=8 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM324 Connected...sending boot... FDL test...OK ArmBootMode: 6600700500005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 460800 ok Reading phone HW info... Read info is done. CPU: SC6600L/WT6226A Flash: NOR_TV00560002EDGB Set FLASH Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A IMEI 1=353298040088828 IMEI 2=353298040188826 --------NOR_FLASH_CONFIG-------- Flash Bank count=1 EFS sector count=6 File sector count=0 Sector size=0x00010000 Flash start addr=0x00000000 Flash size=0x00800000 Fix NV addr=0x00780000 Product information addr=0x007F0000 MMI resource addr=0x00630000 ------Auto Format Address------- Start=0x00790000 Size =0x00060000 Read FS info...done READ CODE Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast... D-=8 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM324 Connected...sending boot... FDL test...OK ArmBootMode: 6600700500005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 460800 ok Reading phone HW info... Read info is done. CPU: SC6600L/WT6226A Flash: NOR_TV00560002EDGB Set FLASH Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 9 Privacy protect: 63744 PhoneLock: 2462368 Theft proof: 246236 Done. THANKS GPGDRAGON |
01-26-2011, 12:37 | #171 (permalink) |
Registered User Join Date: Jun 2010 Location: GSM POWERTEAM
Member: 1330543 Status: Offline Thanks Meter: 177 | club c2 unlock ok Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast... D-=8 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM14 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: 66007001 Flash: NOR_S29GL064A_T Set FLASH Parameters... Settings have been completed! Connect and search Security Code... PhoneLock: 5523459 Privacy protect: 5523459 Done. |
01-27-2011, 10:56 | #172 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ---- Age: 35
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks Meter: 445 | China Rokea SPD Phone Format done Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast... D-=19 D+=18 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM19 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100025A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: 66007001 Flash: NOR_ST_M30L0T7000T0 Set FLASH Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x00CA0000, Size=0x000E0000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
The Following User Says Thank You to madni shah For This Useful Post: |
01-28-2011, 06:59 | #173 (permalink) |
Member: 616556 Status: Offline Thanks Meter: 112 | X8 Formate done Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Loading boot... INT_SYSRAM_BOOT test completed. Nor Flash ID: 00EC240400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... Project ID: C100.SE.HZ10.101125.01 Changing baudrate to 921600... Done. Formating Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
01-28-2011, 07:02 | #174 (permalink) |
Freak Poster Join Date: Oct 2010 Location: lapu-lapu cebu
Member: 1421076 Status: Offline Sonork: 100.1595996 Thanks Meter: 31 | h318 phone luck done via dragon Code: Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast... D-=17 D+=19 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM13 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 230400 ok Reading phone HW info... Read info is done. CPU: 66007001 Flash: NOR_SVME64322UTA Set FLASH Parameters... Settings have been completed! Connect and search Security Code... Theft proof: 475869 PhoneLock: 4758 Privacy protect: 4758 Privacy protect: 1234 Done. |
01-28-2011, 17:10 | #175 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 966792 Status: Offline Sonork: 100.1602610 Thanks Meter: 199 | Analysis the file... It is sensing the pinout fast... RXD=7 TXD=5 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100006A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: 66007001 Flash: NOR_ST_M58WR064KT Set FLASH Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... All Done. |
01-29-2011, 06:02 | #176 (permalink) |
Member: 1330543 Status: Offline Thanks Meter: 177 | 2730 successful unlock It is sensing the pinout fast... D-=8 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM14 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: 66007001 Flash: NOR_EN71GL064 Set FLASH Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 1234 Done. |
01-29-2011, 08:46 | #177 (permalink) |
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks Meter: 445 | LC Format Done Code: Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=12 TXD=11 Connecting...Please hold on the POWER key until the red gauge is going... BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EC22E000000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... Project ID: MUL.9225.0603.SIV.T9.V05 Changing baudrate to 921600... Done. Formating Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
01-30-2011, 09:22 | #178 (permalink) |
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks Meter: 445 | U717 MT6253 Format done Code: Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=5 Connecting...Please hold on the POWER key until the red gauge is going... BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Loading boot... INT_SYSRAM_BOOT test completed. Nor Flash ID: 00EC240400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... Project ID: L5BMM02.9.52.1.3T07M0805_M700 Changing baudrate to 921600... Done. Formating Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done Code: Initializing... DA_LIB_VER_2.5.1.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=5 Connecting...Please hold on the ON/OFF key... Connecting, Please turn on the phone... Connected! Checking IMEI... Original IMEI 1= 135790246811220 IMEI 1 rebuild has been implemented: 350295308705815 Original IMEI 2= 135790246811220 IMEI 2 rebuild has been implemented: 350242604003115 Need to restart the phone to verify new imei. |
01-31-2011, 09:15 | #179 (permalink) |
Freak Poster Join Date: Jul 2010
Member: 1341521 Status: Offline Thanks Meter: 37 | iphone4 32g [nand flash] format done Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=19 TXD=18 Connecting...Please hold on the POWER key until the red gauge is going... BB:6235, HardwareVer:8A01, SoftwareVer:8A04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 009800D100900015 Read Hardware Information is done. Get Project ID from phone... Project ID: V_1.0.0 Changing baudrate to 921600... Done. Formating Flash... AutoFormat address: start=0x04000000, size=0x04000000 All Done |
01-31-2011, 15:50 | #180 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | ZTC 6235 Format done (SPD) Code: Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast... D-=17 D+=19 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM6 Connected...sending boot... FDL test...OK ArmBootMode: 6600700500025A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L/WT6226A Flash: NOR_ST_M30L0T7000T0 Set FLASH Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x00F00000, Size=0x000E0000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
