Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Dragon Box
Dragon Box Chinese Phone Tool
Old 05-21-2012, 12:39   #1561 (permalink)
fredinho's Avatar
Member: 975275
Sonork: 100.1607001
Thanks Meter: 221
Chip=SpreadTrum
Action=Unlock
FlashType=NOR
boot=6600L/WT6226/6610/6620
Expert Mode=Disable
Range[start]=0x0
Range[size]=0x0
Interface=COM
FlashFile=
Comport=COM76
Baudrate=921600
CPU_Type=SC6600L2
CPU_ID=66007001
NOR_ID=002088C0002088C0
NOR_Size=8MB
NOR_Name=NOR_ST_M58WR064HU
NOR_DieCnt=1
NAND_ID=
NAND_Size=
NAND_Name=
Initializing...
DA_LIB_VER_4.3.6.8
It is sensing the pinout fast...
RXD=1 TXD=3
Connecting...
Connected...sending boot...
FDL test...OK
ArmBootMode: 6600700100006A00_00
Wait for init Commzero Security Engine...
Done.
Loading bootloader...
Done.
Changing baudrate...
Set baudrate to 921600 is ok
Reading phone HW info...
Read info is done.
CPU: SC6600L2 Flash: NOR_ST_M58WR064HU
setting the Flash Parameters...
Settings have been completed!
Connect and search Security Code...
PhoneLock: 9630
Privacy protect: 1234
PhoneLock: 24003
Theft proof: 240003
Done.
Old 05-21-2012, 12:40   #1562 (permalink)
fredinho's Avatar
Member: 975275
Sonork: 100.1607001
Thanks Meter: 221
Chip=MTK
Action=Unlock
FlashType=NOR
boot=Ver5.1152
Expert Mode=Disable
Range[start]=0x0
Range[size]=0x0
Interface=COM
FlashFile=
Comport=COM76
Baudrate=921600
Initializing...
DA_LIB_VER_4.3.6.8
Tip: The phone must be able to power-on normally
It is sensing the pinout fast,please hold on the phone Power key
RXD=22 TXD=23
Connecting...Please hold on the POWER key until the red gauge is going...
Any errors please select another boot and try again.
BB:6223, HardwareVer:8A08, SoftwareVer:8A00
Read info...ok, Waitting enter meta...
Connected...can release Power button now, tracking...
Code=36987412
Old 05-21-2012, 12:40   #1563 (permalink)
fredinho's Avatar
Member: 975275
Sonork: 100.1607001
Thanks Meter: 221
Chip=MTK
Action=Unlock
FlashType=NOR
boot=Ver5.1152
Expert Mode=Disable
Range[start]=0x0
Range[size]=0x0
Interface=COM
FlashFile=
Comport=COM76
Baudrate=921600
Initializing...
DA_LIB_VER_4.3.6.8
RXD=22 TXD=23
Code=1996
Old 05-22-2012, 16:03   #1564 (permalink)
Syifa.Cell's Avatar
Member: 624037
Sonork: 100.1608764
Thanks Meter: 41
need firmware for iphone copy 32 mb.with format still dead
log:
Chip=MTK
Action=ReadInfo
FlashType=NOR
boot=Ver5.1152
Expert Mode=Disable
Range[start]=0x0
Range[size]=0x0
Interface=COM
FlashFile=
Comport=COM45
Baudrate=921600
CPU_Type=MT6225
CPU_ID=C9030008
NOR_ID=00EC227E22632260
NOR_Size=32MB
NOR_Name=[SAMSUNG] KAL5563CAM
NOR_DieCnt=
NAND_ID=0000000000000000
NAND_Size=0MB
NAND_Name=Nand:N/A
Initializing...
DA_LIB_VER_4.3.6.8
RXD=9 TXD=3
BB:6225, HardwareVer:8A05, SoftwareVer:8A00
Loading boot...
INT_SYSRAM_BOOT test completed.
Loading boot...
Boot2 test completed.
Nor Flash ID: 00EC227E22632260
Nand Flash ID: 0000000000000000
Read Hardware Information is done.
Config EMI(Nor Flash only)...
H/W detection ok.
Get Project ID from phone...
Project ID: ONECOM.C202
Old 05-23-2012, 20:38   #1565 (permalink)
dapx's Avatar
Member: 1064967
Thanks Meter: 131
Unlock BAK MP662 Done!
 Searching commport...please wait...
 Connecting...
 Spd USB-to-Serial=COM75
 FDL test...OK
 ArmBootMode: 6600700900005A00_00
 Done.
 Done.
 Read info is done.
 CPU: SC6600L7      Flash: NOR_K5N6433ATB
 Theft proof: 362362
 PhoneLock: 36258
 Privacy protect: 362
 Done.
Old 05-23-2012, 20:56   #1566 (permalink)
fredinho's Avatar
Member: 975275
Sonork: 100.1607001
Thanks Meter: 221
Chip=SpreadTrum
Action=Unlock
FlashType=NOR
Expert Mode=Disable
Range[start]=0x0
Range[size]=0x0
Interface=COM
FlashFile=
Comport=COM76
Baudrate=921600
CPU_Type=SC6600L7
CPU_ID=66007009
NOR_ID=007F227E22102201
NOR_Size=8MB
NOR_Name=NOR_EN71GL064
NOR_DieCnt=1
NAND_ID=
NAND_Size=
NAND_Name=
Initializing...
DA_LIB_VER_4.3.6.8
RXD=4 TXD=7
Connecting...
FDL test...OK
ArmBootMode: 6600700900006A00_00
Done.
Done.
Read info is done.
CPU: SC6600L7 Flash: NOR_EN71GL064
PhoneLock: 3211
Theft proof: 321165
Done.
Old 05-23-2012, 20:57   #1567 (permalink)
fredinho's Avatar
Member: 975275
Sonork: 100.1607001
Thanks Meter: 221
Chip=MTK
Action=Unlock
FlashType=NOR
boot=Ver5.1152
Expert Mode=Disable
Range[start]=0x0
Range[size]=0x0
Interface=COM
FlashFile=
Comport=COM76
Baudrate=921600
Initializing...
DA_LIB_VER_4.3.6.8
RXD=2 TXD=3
Code=17951
Code=06770771
Code=1963
Old 05-23-2012, 20:59   #1568 (permalink)
fredinho's Avatar
Member: 975275
Sonork: 100.1607001
Thanks Meter: 221
Chip=SpreadTrum
Action=Unlock
FlashType=NOR
Expert Mode=Disable
Range[start]=0x0
Range[size]=0x0
Interface=COM
FlashFile=
Comport=COM76
Baudrate=921600
CPU_Type=SC6600L7A
CPU_ID=66007019
NOR_Size=8MB
NOR_DieCnt=1
NAND_ID=
NAND_Size=
NAND_Name=
Initializing...
DA_LIB_VER_4.3.6.8
RXD=1 TXD=3
Connecting...
FDL test...OK
ArmBootMode: 6600701900026A00_00
Done.
Done.
Read info is done.
CPU: SC6600L7A Flash: NOR_ST_M58WR064HU
PhoneLock: 1977
Done.
Old 05-25-2012, 14:28   #1569 (permalink)
.:TithiMobile:.'s Avatar
Member: 629327
Sonork: 100.1663374
Thanks Meter: 537
Ipro I6 pro Sucsessfully done
Initializing...
DA_LIB_VER_4.3.6.8
RXD=4 TXD=3
BB:6223, HardwareVer:8A05, SoftwareVer:8A00
Loading boot...
Loading boot...
Nor Flash ID: 002088C400000000
H/W detection ok.
Project ID: F96Z08E3v01.01b05
Changing baudrate to 921600...
Done.
Formatting Flash...
AutoFormat address: start=0x00E00000, size=0x00200000
All Done
Initializing...
DA_LIB_VER_4.3.6.8
RXD=4 TXD=3
IMEI=354225037023814
Rebulid IMEI1=351847007527020
Rebulid IMEI2=350483036079774
Initializing...
DA_LIB_VER_4.3.6.8
RXD=4 TXD=3
Loading boot...
Loading boot...
H/W detection ok.
Done.
Reading full Flash...
Saved file to:
iPro I6pro
All Done.
Old 05-25-2012, 14:29   #1570 (permalink)
Member: 629327
Sonork: 100.1663374
Thanks Meter: 537
Kenxinda M2 Successfully repair Emergency with Flashing Working File
Initializing...
DA_LIB_VER_4.3.6.8
D-=4 D+=6
Connecting...
Spd USB-to-Serial=COM6
FDL test...OK
ArmBootMode: 6610000000FE5A00_00
Done.
Done.
Read info is done.
CPU: SC6610/20 Flash: SF_GD25Q32
setting the Serial Flash Parameters...
Unlocking all blocks before program/erase...
Unlock Done.
Programming...
Compare Image: Enable
All Done
Old 05-25-2012, 16:09   #1571 (permalink)
BASHARTEL's Avatar
Member: 1379712
Sonork: 100.1607970
Thanks Meter: 44
Thumbs up Micromax Q7 IMEI DONE 100%OK
MTK-6235
__________________
Avoid Receiving WARNINGS And Getting BANNED!
* Read All Forum Rules!
..:::BASHARTEL:::..
[email protected]
Old 05-29-2012, 13:11   #1572 (permalink)
Member: 629327
Sonork: 100.1663374
Thanks Meter: 537
ZTE GN 295 Orange Unlock Done
Old 05-30-2012, 05:14   #1573 (permalink)
Member: 233142
Sonork: 100.1595099
Thanks Meter: 527
Nokia X8 format done
 Initializing...
 DA_LIB_VER_4.3.6.8
 RXD=7  TXD=9
 BB:6253,    HardwareVer:8A00,    SoftwareVer:8A04
 Loading boot...
 Loading boot...
 Nor Flash ID: 0089890300000000
 H/W detection ok.
 Project ID: T219.GLS.BT.FM.SC.FL.L14.V02
 Done.
 Formatting Flash...
 All Done
Old 05-30-2012, 09:02   #1574 (permalink)
BASHARTEL's Avatar
Member: 1379712
Sonork: 100.1607970
Thanks Meter: 44
Thumbs up Leady.mini.mtk6219.100%ok
LEADY.MINI.MTK6219.100%OK
__________________
..:::BASHARTEL:::..
[email protected]
Old 05-30-2012, 14:07   #1575 (permalink)
Member: 1702845
Sonork: 1611195
Thanks Meter: 3
ZTE 553 OK
Initializing...
DA_LIB_VER_4.3.6.8
RXD=3 TXD=2
BB:6235, HardwareVer:8A01, SoftwareVer:8A04
Loading boot...
Loading boot...
Nor Flash ID: 0000000000000000
Nand Flash ID: 00AD00A100800015
Project ID: X930_V1_Z3_UKIE_DEITES_B1FF106
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.30793 seconds with 10 queries
