Dragon Box Chinese Phone Tool |
06-10-2012, 12:21 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: inside my SOFTWARE ROOM
Member: 761864 Status: Offline Thanks Meter: 63 | r3850 pattern lock, pls help >>> Scan Mobile Pinout... USB Pinout: D+:19 D-:17 Detected Mobile PinOut ... >>> SCAN SCI Port... Detected SCI Port :COM127 Mobile Connect Success... >>> Downloading First "boot1.bin" Success... Reading the First Boots: Spreadtrum Boot Block version 1.1 >>> Downloading Second "boot2.bin" Success... >>> Mobile Info CPU Name:6800H Flash ID:0000ADA1 Flash Size:0X08000000->128M Flash Name:H8BCS0PG0MBP Flash Factory:NAND_HYNIX All Done... and it readed the codes as 1234 how can i fix this pattern lock? pls help..... THANKS |
06-10-2012, 12:30 | #3 (permalink) |
No Life Poster Join Date: Mar 2009 Location: earth
Member: 992568 Status: Offline Sonork: kulit Thanks Meter: 231 | you cannot fix sir it because the new louche of this team is only for testing hope it will fix soon as possible reading and info are cannot help for now |
06-11-2012, 00:36 | #5 (permalink) |
Freak Poster Join Date: Dec 2008 Location: Algeria
Member: 918393 Status: Offline Thanks Meter: 515 | Working Solution It's Very Easy Because you Have Mirror Methode Too Pattern Lock In Chainesse Phone = Digit Lock Just Read Code From Flash File , Then Enter It As Digit You Don't See Digit On Screen But After That You Phone Will Be Unlocked Tested By Me On Same Phone As Your's 100/100 Worked |
06-11-2012, 06:47 | #6 (permalink) | |
Member: 761864 Status: Offline Thanks Meter: 63 | Quote:
thanks... | |
06-12-2012, 07:02 | #8 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,311 | try with latest ver :http://forum.gsmhosting.com/vbb/f646...-12-a-1489316/ |
06-16-2012, 10:59 | #9 (permalink) | |
i used that version v1.20 but still pattern lock not apprear, any other solution sir? same as v1.0.. here is the v1.20 logs.. USB Pinout: D+:6 D-:8 Detected Mobile PinOut ... >>> SCAN SCI Port... Detected SCI Port :COM127 Mobile Connect Success... >>> Downloading First "boot1.bin" Success... Reading the First Boots: Spreadtrum Boot Block version 1.1 >>> Downloading Second "boot2.bin" Success... >>> Mobile Info CPU Name:6800H Flash ID:0000ADA1 Flash Size:0X08000000->128M Flash Name:H8BCS0PG0MBP Flash Factory:NAND_HYNIX >>> Reading Flash... Access To The Flash Mode2... Read Flash Done... >>> Analzing Code...Please Wait... IMEI 1: 359642049256957 IMEI 2: 359642049256965 IMEI 3: 358570010103893 IMEI 4: 910575601400468 Password1: 1234 All Done... pls. help. thanks... | |
06-16-2012, 12:00 | #10 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | You can try with 6800h new version 1.5 http://forum.gsmhosting.com/vbb/f646...lease-1492133/ Or If not you have two option:- a) Use search button for hard reset or b) Flash the falty phone with Working file (from working Phone). BR Last edited by Dipendra Pathak; 06-18-2012 at 07:15. |
07-07-2012, 17:07 | #11 (permalink) |
Freak Poster Join Date: May 2007
Member: 516878 Status: Offline Thanks Meter: 7 | need flash z3850 .........after fash itt firm backup phone dead help pls > Scan Mobile Pinout... VCC Pin:7, GND Pin:2, Signal Pin:1, 3, 4, 5, 6, 8, 9, 10, USB Pinout: D+:6 D-:8 >>> SCAN SCI Port... Detected SCI Port :COM73 Mobile Connect Success... >>> Downloading First "boot1.bin" Success... Reading the First Boots: Spreadtrum Boot Block version 1.1 >>> Downloading Second "boot2.bin" Success... >>> Mobile Info CPU Name:6800H Flash ID:0000AD76 Flash Size:04000000->64M Flash Name:HY27XS08121M Flash Factory:NAND_HYNIX >>> Wrtieing Flash ... Write NV To Flash ... Write BOOT_LOADER To Flash... Write MMIRES To Flash... All Done... |
02-06-2013, 10:52 | #12 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 786285 Status: Offline Sonork: [email protected] Thanks Meter: 11 | r3850 pattern lock, pls help using spreadtrum 6800h tool logs; >>> Scan Mobile Pinout... USB Pinout: D+:19 D-:17 Detected Mobile PinOut ... >>> SCAN SCI Port... Detected SCI Port :COM127 Mobile Connect Success... >>> Downloading First "boot1.bin" Success... Reading the First Boots: Spreadtrum Boot Block version 1.1 >>> Downloading Second "boot2.bin" Success... >>> Mobile Info CPU Name:6800H Flash ID:0000ADA1 Flash Size:0X08000000->128M Flash Name:H8BCS0PG0MBP Flash Factory:NAND_HYNIX All Done... and it readed the codes as 1234 how can i fix this pattern lock? pls help..... THANKS Sir pls argent upload this flash fiile |
02-06-2013, 12:46 | #13 (permalink) | |
Cheater -Don't Deal with him- Join Date: Sep 2010
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Quote:
,,,,,,,,,,,,,, contact me too ,,,, | |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
SP Lock 1&4 | dw | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 06-26-1999 06:22 |
