Dragon Box Chinese Phone Tool |
10-31-2010, 10:16 | #1 (permalink) |
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | GPG Dragon Successfully Unlocked / Repaired / Flashed Phones !!! Last edited by Faisal_Computer; 09-07-2011 at 09:10. |
The Following 37 Users Say Thank You to FullFLASHgSMPH For This Useful Post: |
11-01-2010, 03:20 | #3 (permalink) |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | spd read code easy Initializing... DA_LIB_VER_2.4.4.7 It is sensing the pinout fast... D-=8 D+=6 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM11 Connected...sending boot... FDL test...OK ArmBootMode: 6600700138E3A000_01 Wait for init SB... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: 66007001 Flash: NOR_TV00570002xDGB Set FLASH Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 258456 Done. |
The Following 17 Users Say Thank You to FullFLASHgSMPH For This Useful Post: |
11-01-2010, 09:44 | #4 (permalink) |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | again Privacy protect read Fast and safe again Privacy protect read Fast and safe Initializing... DA_LIB_VER_2.4.4.7 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Spd USB-to-Serial=COM11 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700038A3A000_01 Wait for init SB... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L/WT6226A Flash: NOR_S71PL127N Set FLASH Parameters... Settings have been completed! Connect and search Security Code... Theft proof: 381274 Privacy protect: 6657 PhoneLock: 4748 Done. |
The Following 18 Users Say Thank You to FullFLASHgSMPH For This Useful Post: |
11-02-2010, 11:48 | #5 (permalink) |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | iphone 5 change imei done DA_LIB_VER_2.4.4.7 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=1 TXD=2 Connecting...Please hold on the ON/OFF key... Connecting, Please turn on the phone... Connected! Checking IMEI... Original IMEI 1= 135790246811220 IMEI 1 rebuild has been implemented: 350092755668990 Original IMEI 2= 135790246811220 IMEI 2 rebuild has been implemented: 350092755668998 Need to restart the phone to verify new imei. |
The Following 16 Users Say Thank You to FullFLASHgSMPH For This Useful Post: |
11-05-2010, 03:49 | #6 (permalink) |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | SC6600L/WT6226A Initializing... DA_LIB_VER_2.4.4.7 It is sensing the pinout fast... D-=8 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM11 Connected...sending boot... FDL test...OK ArmBootMode: 6600700538E3A000_01 Wait for init SB... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L/WT6226A Flash: NOR_ST_M30L0T7000T0 Set FLASH Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x00EA0000, Size=0x00140000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
11-06-2010, 08:49 | #7 (permalink) |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | MTK 6226 DA_LIB_VER_2.4.4.4 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=5 TXD=6 Connecting...Please hold on the ON/OFF key... Connecting, Please turn on the phone... Connected! Checking IMEI... Original IMEI 1= 135790246811220 IMEI 1 rebuild has been implemented: 350093566778999 Need to restart the phone to verify new imei. |
The Following 13 Users Say Thank You to FullFLASHgSMPH For This Useful Post: |
11-06-2010, 09:02 | #8 (permalink) |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | torque dl85 torque dl85 BB:6223 Initializing... DA_LIB_VER_2.4.4.7 It is sensing the pinout fast,please hold on the phone Power key RXD=5 TXD=4 Connecting...Please hold on the POWER key until the red gauge is going... BB:6223, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0001227E22212201 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... Project ID: C26_HX_QCIF_NT_ML7_V1.0.0 Changing baudrate to 921600... Done. Formating Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
11-06-2010, 11:02 | #9 (permalink) |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | Spd LOCKCODE EASY Initializing... DA_LIB_VER_2.4.4.7 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM11 Connected...sending boot... FDL test...OK ArmBootMode: 6600700538E3A000_01 Wait for init SB... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L/WT6226A Flash: NOR_TV00560002EDGB Set FLASH Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 1629 Theft proof: 123456 PhoneLock: 12345 Done. |
11-08-2010, 07:46 | #10 (permalink) |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | Bb:6235 Initializing... DA_LIB_VER_2.4.4.7 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=7 TXD=9 Connecting...Please hold on the ON/OFF key... BB:6235, HardwareVer:8A01, SoftwareVer:8A04 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... |
11-13-2010, 04:25 | #15 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Caribbean
Member: 237911 Status: Offline Thanks Meter: 632 | hmm Who is reseller in philippines? and how much this cost on our currency? i saw BB china model is supported, which is not by Spidey w/ spread (not sure) im interested |
The Following 8 Users Say Thank You to eyestrain For This Useful Post: |
