Dragon Box Chinese Phone Tool |
11-02-2015, 14:35 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: FOCSANI Age: 39
Member: 718470 Status: Offline Thanks Meter: 79 | huawei y600-u20 after update white lcd help Pleae use USB Cable Connect mobile to computer... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM15 Driver Name->>>MediaTek PreLoader USB VCOM Port Mobile Connection Success... CPU_ID:MT6572 Hardware Version:8A00 Software Version:CA01 >>> Downloading First Boot... >>> Authenticating BOOT... BOOT Validation Success... >>> Return DATA Error!!! error ???? huawei y600-u20 need firmware spflashtool I tried to write Y600-U20V100R001C435B012_DCC done after white lcd update firmware with sd card not working |
11-21-2015, 10:13 | #9 (permalink) |
Member: 718470 Status: Offline Thanks Meter: 79 | i write Y600-U20V100R001C435B012_DCC HUAWEI Y600-U20 FLASH FILE 100% TESTED LOGO HANG RIPAIR FILE BY FOYSAL TELECOM Y600-U20V100R001C435B012_Firmware_Oman_United%20Arab%20 Emirates_Bahrain_ Y600-U20_V100R001C456B008_Firmware_Malaysia y600-u20 dark and off ok by team Gsm-Developers.ir white screen after flash |
11-21-2015, 11:06 | #10 (permalink) |
No Life Poster Join Date: Sep 2012 Location: Ghana
Member: 1809548 Status: Offline Sonork: mysty619/100.167036 Thanks Meter: 120 | Formart all data including bootloader on fone using sp flashtool then reflash again using the same firmware. After flash goto recovery n format user data n cache partition and restart |
11-21-2015, 11:27 | #12 (permalink) |
Member: 1809548 Status: Offline Sonork: mysty619/100.167036 Thanks Meter: 120 | Make sure it is the same model ok!, Then try this firmware here " http://gsmxda.********.com/2015/05/h...ptool.html?m=1 " and do the above procedure i gave erlier on. Or pm me |
11-21-2015, 11:52 | #15 (permalink) |
Junior Member Join Date: Feb 2004 Location: Lebanon
Member: 52297 Status: Offline Thanks Meter: 3 | Huawei Y600-U20 white display after update I had two unit .after flash with sp tool ,White display.Repaired by replace copy display.this the final solution i got |
