jugate z9978 not pinfinding...Solved this phone on board has pinouts av tried rx tx & gnd but not pinfinding,on board there is also pwr-on,vbat,tdo,tms,rstn,tdi,tck vvddio which ons should i add on rj 45 cable pliz i need guidance |
whats phone status? |
if you Connect rj45 pinouts then you must need to connect the main cable + and - wire to phone battery connector |
this modle you can select 6600L-USB and hold the * Key will ok the second you can open the Mobile ,pcb have rx and tx,you connect and select the 6600L-COM then will ok |
Bro gpg dragon help you are da boom da star trick has worked,thanx once again wish there was a double thanx button on dis forum............. |
