Dragon Box Chinese Phone Tool |
03-01-2012, 06:16 | #286 (permalink) | |
Freak Poster Join Date: May 2005 Location: Philippines Age: 42
Member: 144777 Status: Offline Sonork: 100.111515 Thanks Meter: 100 | Quote:
maybe same programmer but deferent box name | |
03-01-2012, 08:35 | #291 (permalink) |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | still the same error Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=2 TXD=1 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6610000000806A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_MX25U6435E setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading Flash... Saved file to: C:\Documents and Settings\Administrateur\Mes documents\C9 spread All Done. Reading Project Version... Error: Unsupport FileSystem. |
03-01-2012, 08:43 | #292 (permalink) |
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | the same error in format at 20% Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=2 TXD=1 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6610000000406A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_MX25U6435E setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... Error: Get Flash die baseaddress Failed to auto format. |
03-01-2012, 09:14 | #295 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Pakistan
Member: 720264 Status: Offline Sonork: 100.1649278 Thanks Meter: 192 | MASHA A L L A H Good update, Initializing... DA_LIB_VER_4.0.3.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=7 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=73362 Code=0000 Read Code, BB:6252, working. |
