Dragon Box Chinese Phone Tool |
02-29-2012, 11:58 | #121 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=7 TXD=9 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6610000000306A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 1234 PhoneLock: 8585 Done. |
02-29-2012, 12:03 | #125 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 966792 Status: Offline Sonork: 100.1602610 Thanks Meter: 199 | set blinking problum Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... D-=8 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM37 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100025A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Manufacturer: ST & NUMONYX, Device: Unknow CPU: SC6600L2 Flash: NOR_UNKNOWN setting the Flash Parameters... Settings have been completed! CPU: SC6600L2 Flash: User-defined Reading Flash... Saved file to: D:\lgnew\gpgdragon\backup\buzz All Done. Reading Project Version... Platform Version: MOCOR_09A_3216.W10.29_Release Project Version: 7707_YL_BUZZ_FM_FL_MP4_1040_H13_V06_110429_ENG_HIN _NOBT_NOCAMERA_TIANMA+HANCAI MMI Version: SC6600L_sp6601l BASE Version: SC6600L_sp6601l HW Version: SC6600L_sp6601l Project Bulid Time: 4-29-2011 16:25:53 format problum Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=6 TXD=7 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Manufacturer: ST & NUMONYX, Device: Unknow CPU: SC6600L2 Flash: NOR_UNKNOWN setting the Flash Parameters... Settings have been completed! CPU: SC6600L2 Flash: User-defined Reading FileSystem info... FileSystem Version: 0A Failed to auto format. |
02-29-2012, 12:05 | #126 (permalink) |
No Life Poster Join Date: Oct 2007 Location: pakistan
Member: 601913 Status: Offline Sonork: 100.1597350 Thanks Meter: 658 | SPD 6610/20 fully support now in 2.12 see test report here Code: Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=18 TXD=17 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6610000000E26A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. |
