Dragon Box Chinese Phone Tool |
01-08-2014, 09:28 | #1 (permalink) |
Freak Poster Join Date: Nov 2010 Age: 36
Member: 1442627 Status: Offline Thanks Meter: 108 | need help urgent plz i read full flash then formated set hang on logo i try to write back readed file its come error plz help me here logo >>> Getting Mobile Connection Info... VCC Pin: GND Pin:1, Signal Pin:2, 3, 4, 5, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:4 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM9 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:00002CBC Flash Size:20000000->512M Flash Name:NAND_SamSungMT29C4G48MAZAPAKD CPU Name:6820/8810 >>> -Analyzing Flash File... Get Flash Format: User Read Full Flash... Flash Size:0X20000000->512M >>> Decompressing file... NV_ADD :0x00D8B800 SIZE: 0x0000D1B0 SPL_ADD :0x00000000 SIZE: 0x00042000 UBOOT_ADD :0x00040000 SIZE: 0x000673BC VMG_ADD :0x00100000 SIZE: 0x0003D000 MODEM_ADD :0x00180000 SIZE: 0x003C1E0E DSP_ADD :0x01300000 SIZE: 0x001E0000 BOOT_IMG_ADD:0x01BC0000 SIZE: 0x00686800 REC_IMG_ADD :0x025C0000 SIZE: 0x006A8800 SYSTEM_ADD :0x02FC0000 SIZE: 0x08A36800 USER_ADD :0x1ABC9800 SIZE: 0x00002000 BOOTLOGO_ADD:0x00000000 SIZE: 0x01000000 Special remind:if you tick the system,maybe it will kill your phone!!! Waiting For Your Confirmation... >>> Eraseing Flash .... Erase Done... >>> Writing Flash File... Write_UBOOT... Write_VMG... Write_MODEM... Write_DSP... Write_BOOT_IMG... Write_REC_IMG... Write_SYSTEM... >>> Return DATA Error!!! Terminated... |
01-08-2014, 13:36 | #2 (permalink) |
No Life Poster Join Date: May 2011
Member: 1576733 Status: Offline Thanks Meter: 622 | Try this method: http://forum.gsmhosting.com/vbb/f646...-team-1750096/ If not work,then, go Original Flasher. diosa |
