ztc g18 set hangs on startup after write imei i have a ztc g18 set having spd 6610 cpu which was working ok but imei problem , then i try to change the imei with the latest version of dragon . but after writing imei the set hangs on startup logo only . i had taken the flash backup too but after writing the backup also the set remains in the same hanging status .. please help me .. Code: >>> Getting Mobile Connection Info... when i try to write the backup then after some seconds it says ful flashing and then Finish but doesent shows any progress , just says finish , what is this ? Code: >>> Getting Mobile Connection Info... please help me urgently recover this set to the same condition as it was before ... |
use 2,13 for flashing plz |
the flash chip is not supported by that version ab any other way? Sent from my iPhone using Tapatalk |
format it and write again you can try or you read back flash ,and change IMEI with 2.13 softwrae after 2.13 will give you the new IMEI Flash,and you write this flash to your mobile,is ok |
i have the full backup taken with latest version of dragon, i want to know how to. write the full backup with the latest version of dragon ? which option to choose before writing ? Sent from my iPhone using Tapatalk |
no need,just select CPU name and select flash and click start you can write flash |
as i have done the same way to read and write the taken backup with this latest version but after writing the backup , same problem remains .. |
Why don't you try with another working file ? BR Dipendra Pathak |
the main point is y dont backup works ? Sent from my iPhone using Tapatalk |
when i try to write the file after changing the imei with 2.13 version then i get this error . Code: >>> Getting Mobile Connection Info... |
try another box, and post result. |
can anyone give me the flash file of this set ? |
Please check the Flash file in our Sub-forum or post your request there : Dragon Flash Files - GSM-Forum BR Dipendra Pathak |
i am asking here because this thread is related to that set and it is created by me , and after trying all the methods to get the set same as before formatting with the latest version of dragon then i had to ask for a second file .... if u say then i will have to start a new topic for only this file in that sub- forum, |
