Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > Smart-gsm team
Old 06-21-2011, 02:06   #1 (permalink)
Member: 1222089
Sonork: 100.1583019
Thanks Meter: 2,688
Thumbs up Smart Gsm Nokia X1-01 Pro Fbus Cable !
TESTED LOGS WITH ATF (ADVANCE TURBO FLASHER)
23:08:06 : ///////// /// /// /////// /////// /////////
23:08:06 : /// /// /// /// // /// /// /// ///
23:08:06 : /// /// /// /////// /////// /// ///
23:08:06 : /// /// /// /// /// /// /// /// ///
23:08:06 : /// ///// /// /// /////// //////
23:08:06 :
23:08:06 : =======================================
23:08:06 : /// /// /// ///////// /////// //////
23:08:06 : ///// /// /// /// /// // /// ///
23:08:06 : /// ///// /// /// /////// /// ///
23:08:06 : /// //// /// /// /// /// /// ///
23:08:06 : /// /// /// /// /// /// //////
23:08:06 :
23:08:26 :
23:08:26 : Make sure that you plugged the cable to the
23:08:26 : RJ-45 Port Marked << EXTENSION >>
23:08:26 :
23:08:26 : =======================================
|| FLASHBUS EXTENSION ||
|| | | (O) (O) (O) | CABLE | ||
PLUG IN
CABLE HERE
23:08:29 : VBATT OFF...
23:08:32 : VBATT ON
23:08:32 : Setting VBATT Done!...
23:08:32 :
23:08:32 : Booting Phone...
23:08:32 : CPU ID Response: A200341100
23:08:32 : CPU Type: XG110 2.1B
23:08:32 : Phone Booted at after First attempt...
23:08:32 :
23:08:32 : ************************************************** ****
23:08:32 : START INFINEON BUS CHECK
23:08:32 :
23:08:32 :
23:08:32 : Sending PBL 37888 bytes...
23:08:34 : PBL Successfully Sent...
23:08:34 : Sending SBL 65024 bytes...
23:08:35 : SBL Successfully Sent...
23:08:35 :
23:08:35 : Flash Chip Manufacturer: STMicroelectronics
23:08:35 : Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR
23:08:35 : Extended Information: Multiple Bank / Burst / 1.8v
23:08:35 :
23:08:35 : ************************************************** ****
23:08:35 : INFINEON BUS CHECK DONE
23:08:35 :
23:08:37 :
23:08:38 : MCU: V 05.27 26-05-11 RM-713 (c) Nokia
23:08:38 : IMEI: 356269040844947
23:08:38 : Product Serial Number: 225D120AH
23:08:38 : Product Code : 059D815
23:08:38 : Module Code : 0204727
23:08:38 : Basic Production Code: 059C3M4
23:08:38 : MCU SW Version : V 05.27 26-05-11 RM-713 (c) Nokia MA
23:08:39 : ADSP Version : p V 05.27\n26-05-11\nRM-713\n(c) NMP\nma
23:08:39 : PPM Version : V 05.27 26-05-11 RM-713 (c) Nokia
23:08:39 : HW Version : 1000
23:08:39 : UEM Version : 1328
23:08:39 : UPP Version : 8850
23:08:39 : LCD Version : TPO:BARACOAv82 HX5081
23:08:40 : ********** SIMLOCK INFO **********
23:08:40 : CONFIG_DATA : 0010100000000000
23:08:40 : PROFILE_BITS : 0000000000030002
23:08:40 : Asic : 11
23:08:40 : Provider : Default Test Operator
23:08:40 :
23:08:41 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
23:08:41 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
23:08:41 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
23:08:41 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
23:08:41 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
23:08:41 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
23:08:41 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
23:08:41 : ST_LCD_TEST : PASSED
23:08:41 :
23:08:41 :
23:08:48 :
23:08:49 : MCU: V 05.27 26-05-11 RM-713 (c) Nokia
23:08:49 : IMEI: 356269040844947
23:08:49 : Product Serial Number: 225D120AH
23:08:49 : Product Code : 059D815
23:08:49 : Module Code : 0204727
23:08:49 : Basic Production Code: 059C3M4
23:08:49 : MCU SW Version : V 05.27 26-05-11 RM-713 (c) Nokia MA
23:08:49 : ADSP Version : p V 05.27\n26-05-11\nRM-713\n(c) NMP\nma
23:08:50 : PPM Version : V 05.27 26-05-11 RM-713 (c) Nokia
23:08:50 : HW Version : 1000
23:08:50 : UEM Version : 1328
23:08:50 : UPP Version : 8850
23:08:50 : LCD Version : TPO:BARACOAv82 HX5081
23:08:51 : ********** SIMLOCK INFO **********
23:08:51 : CONFIG_DATA : 0010100000000000
23:08:51 : PROFILE_BITS : 0000000000030002
23:08:51 : Asic : 11
23:08:51 : Provider : Default Test Operator
23:08:51 :
23:08:52 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
23:08:52 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
23:08:52 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
23:08:52 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
23:08:52 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
23:08:52 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
23:08:52 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
23:08:52 : ST_LCD_TEST : PASSED
23:08:52 :
23:08:52 :
23:09:17 : VBATT OFF...
23:09:19 : VBATT ON
23:09:19 : Setting VBATT Done!...
23:09:19 :
23:09:19 : Booting Phone...
23:09:20 : CPU ID Response: A200341100
23:09:20 : CPU Type: XG110 2.1B
23:09:20 : Phone Booted at after First attempt...
23:09:20 :
23:09:20 : ************************************************** ****
23:09:20 : TIME STARTS HERE
23:09:20 :
23:09:20 :
23:09:20 : Sending PBL 19456 bytes...
23:09:22 : PBL Successfully Sent...
23:09:22 :
23:09:22 : Sending SBL 65024 bytes...
23:09:22 : SBL Successfully Sent...
23:09:22 :
23:09:22 : Flash Chip Manufacturer: STMicroelectronics
23:09:22 : Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR
23:09:22 : Extended Information: Multiple Bank / Burst / 1.8v
23:09:22 :
23:09:22 : Processing Image File: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-713\rm713_005.270
23:09:22 :
23:09:23 : FIRMWARE Image Found...
23:09:23 : Number of Sections: 03
23:09:23 : FIRMWARE Certificate Block Sent Successfully...
23:09:23 : Processing Section 01 of 03
23:09:23 : FIRMWARE Erase Block: 0x00000000~0x0001FFFE
23:09:23 : Start Erasing...
23:09:23 : Erasing Please Wait...
23:09:24 : Block Erase Done...
23:09:24 : Preparing Data Blocks...
23:09:24 : Data Size: 24576 bytes
23:09:24 : Data Checksum: 55FD
23:09:24 : Uploading Data Blocks to phone...
23:09:25 : FIRMWARE Data Blocks uploaded to phone...
23:09:25 : Processing Section 02 of 03
23:09:25 : FIRMWARE Erase Block: 0x00800000~0x00BFFFFE
23:09:25 : Start Erasing...
23:09:25 : Erasing Please Wait...
23:10:01 : Block Erase Done...
23:10:01 : Preparing Data Blocks...
23:10:01 : Data Size: 4128768 bytes
23:10:01 : Data Checksum: 2291
23:10:01 : Uploading Data Blocks to phone...
23:11:03 : FIRMWARE Data Blocks uploaded to phone...
23:11:03 : Processing Section 03 of 03
23:11:03 : FIRMWARE Erase Block: 0x00C5D000~0x00E5FFFE
23:11:03 : Start Erasing...
23:11:03 : Erasing Please Wait...
23:11:21 : Block Erase Done...
23:11:21 : Preparing Data Blocks...
23:11:21 : Data Size: 1697536 bytes
23:11:21 : Data Checksum: 6B3C
23:11:21 : Uploading Data Blocks to phone...
23:11:46 : FIRMWARE Data Blocks uploaded to phone...
23:11:46 : Start Data Verification... (Please wait)
23:11:51 : Data Verification Successful...
23:11:51 :
23:11:51 :
23:11:51 : Processing Image File: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-713\rm713_005.27qb
23:11:51 :
23:11:51 : PPM Image Found...
23:11:51 : Number of Sections: 01
23:11:51 : PPM Certificate Block Sent Successfully...
23:11:51 : Processing Section 01 of 01
23:11:51 : PPM Erase Block: 0x00100000~0x005E00BE
23:11:51 : Start Erasing...
23:11:51 : Erasing Please Wait...
23:12:36 : Block Erase Done...
23:12:36 : Preparing Data Blocks...
23:12:36 : Data Size: 5112000 bytes
23:12:36 : Data Checksum: 4A62
23:12:36 : Uploading Data Blocks to phone...
23:13:53 : PPM Data Blocks uploaded to phone...
23:13:53 : Start Data Verification... (Please wait)
23:13:53 : Data Verification Successful...
23:13:53 :
23:13:54 :
23:13:54 : Processing Image File: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-713\rm7130_nai05.27qb
23:13:54 :
23:13:54 : CONTENT Image Found...
23:13:54 : Number of Sections: 01
23:13:54 : CONTENT Certificate Block Sent Successfully...
23:13:54 : Processing Section 01 of 01
23:13:54 : CONTENT Erase Block: 0x00E60000~0x00F0BD3E
23:13:54 : Start Erasing...
23:13:54 : Erasing Please Wait...
23:14:01 : Block Erase Done...
23:14:01 : Preparing Data Blocks...
23:14:01 : Data Size: 703808 bytes
23:14:01 : Data Checksum: 452C
23:14:01 : Uploading Data Blocks to phone...
23:14:12 : CONTENT Data Blocks uploaded to phone...
23:14:12 : Start Data Verification... (Please wait)
23:14:12 : Data Verification Successful...
23:14:12 :
23:14:12 :
23:14:12 : Exit Flash Mode Done...
23:14:12 : Time Elapse : 00:04:52
23:14:15 :
23:14:15 : ************************************************** ****
23:14:15 : You must Factory Reset the phone to enable the
23:14:15 : ringtones and other customized settings to work
23:14:15 :
23:14:15 :
23:14:15 : Waiting For Phone to go Online...
23:14:15 :
23:14:15 : 5,
23:14:16 : 4,
23:14:16 : 3,
23:14:16 : 2,
23:14:16 : 1...
23:14:16 :
23:14:16 : MCU: V 05.27 26-05-11 RM-713 (c) Nokia
23:14:16 : IMEI: 356269040844947
23:14:16 : Product Serial Number: 225D120AH
23:14:16 : Product Code : 059D815
23:14:17 : Module Code : 0204727
23:14:17 : Basic Production Code: 059C3M4
23:14:17 : MCU SW Version : V 05.27 26-05-11 RM-713 (c) Nokia QB
23:14:17 : ADSP Version : p V 05.27\n26-05-11\nRM-713\n(c) NMP\nqb
23:14:17 : PPM Version : V 05.27 26-05-11 RM-713 (c) Nokia
23:14:19 : HW Version : 1000
23:14:19 : UEM Version : 1328
23:14:19 : UPP Version : 8850
23:14:19 : LCD Version : TPO:BARACOAv82 HX5081
23:14:20 : ********** SIMLOCK INFO **********
23:14:20 : CONFIG_DATA : 0010100000000000
23:14:20 : PROFILE_BITS : 0000000000030002
23:14:20 : Asic : 11
23:14:20 : Provider : Default Test Operator
23:14:20 :
23:14:21 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
23:14:21 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
23:14:21 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
23:14:21 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
23:14:21 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
23:14:21 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
23:14:21 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
23:14:21 : ST_LCD_TEST : PASSED
23:14:21 :
23:14:21 :
23:14:21 :
23:14:22 : FACTORY SET TO : Full Factory Set
23:14:23 : OK
23:14:23 : FACTORY SET TO : User Data
23:14:23 : OK
23:14:23 : FACTORY SET TO : Leave Factory
23:14:23 : OK
23:14:23 : FACTORY SET TO : Service Center
23:14:23 : OK
23:14:23 : FACTORY SET TO : Software Upgrade
23:14:23 : OK
23:14:23 : FACTORY SET TO : Production Tune
23:14:23 : OK
Br.,
Smart-Gsm Team
The Following 2 Users Say Thank You to Smart-gsm For This Useful Post:
Old 06-29-2011, 04:00   #2 (permalink)
omkar3268's Avatar
Member: 1161713
Sonork: 100.1607798
Thanks Meter: 421
Br.,
Smart-Gsm Team
ImageShack® - Online Photo and Video Hosting
Old 07-18-2011, 08:23   #3 (permalink)
FullFlashPak's Avatar
Member: 782530
Thanks Meter: 8,136
good quality cable from trusted manufacturer.non stop doing good quality for your daily needs...keep it up bro
think smart !! buy smart !!
Old 11-24-2014, 11:26   #4 (permalink)
Member: 2133244
Sonork: www.sonork.com
hell community at and all friends on gsm, my question is can i get universal flash box and universal usb cable
that work with any phone model. my *** bless u and me good work we are doing in area of technology field
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.16046 seconds with 9 queries
