Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
AVATOR BOX (China Phones Service Tool) |
![]() | #16 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2010 Location: Gsm Hosting (INDIA)
Member: 1478271 Status: Offline Sonork: 100.1608386 Thanks Meter: 1,798 ![]() | Panasonic Eluga i3 Mega Remove FRP W/O Data Loss With Avator Pro |
The Following 2 Users Say Thank You to Momin_Telecom For This Useful Post: |
![]() | #17 (permalink) |
Member: 1478271 Status: Offline Sonork: 100.1608386 Thanks Meter: 1,798 ![]() | SAMSUNG 1200Y Format Simlock Code Done By AVATOR Pro SAMSUNG 1200Y Format Simlock Code Done By AVATOR Pro Dongle Code: Operation : Read Info Boot: SC6530 NOR Error Report: OFF Hint: Power off phone, hold bootkey, Insert usb cable Scanning usb device... Phone found : SPRD U2S Diag (COM9) A thread is created to handle new usb connection, pls wait... Bootstrap: SPRD3 Connected...sending boot... FDL test...OK ArmBootMode: 6530C00000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6500E Flash: SF_GD27Q64 NOR ID : 00C8006000170000 NOR Size : 8MB NOR Name : SF_GD27Q64 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 7C IMEI 1=354505099456188 ------Auto Format Address------- Start=0x00700000 Size =0x00100000 Read FS info...done Operation Done: 00:00:13 Avator Pro SW 2.4 Operation : Format / Reset Boot: SC6530 NOR Error Report: OFF Hint: Power off phone, hold bootkey, Insert usb cable Scanning usb device... Phone found : SPRD U2S Diag (COM9) A thread is created to handle new usb connection, pls wait... Bootstrap: SPRD3 Connected...sending boot... FDL test...OK ArmBootMode: 6530C00000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6500E Flash: SF_GD27Q64 NOR ID : 00C8006000170000 NOR Size : 8MB NOR Name : SF_GD27Q64 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 7C Start=0x00700000, Size=0x00100000 Unlocking all blocks before program/erase... Buffer Program: Enable Unlock Done. Auto formatting... Done. Operation Done: 00:00:40 Avator Pro SW 2.4 Thanks to AVATOR Pro Dongle |
![]() | #18 (permalink) |
Member: 1478271 Status: Offline Sonork: 100.1608386 Thanks Meter: 1,798 ![]() | Samsung B110E Read User Lock Code Done With Avator Pro Samsung B110E Read User Lock Code Done With Avator Pro Code: Operation : Read user locks Boot: SC6530 NOR Error Report: OFF Hint: Power off phone, hold bootkey, Insert usb cable Scanning usb device... Phone found : SPRD U2S Diag (COM9) A thread is created to handle new usb connection, pls wait... Bootstrap: SPRD3 Connected...sending boot... FDL test...OK ArmBootMode: 6530C00000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6500E Flash: SF_GD27Q64 NOR ID : 00C8006000170000 NOR Size : 8MB NOR Name : SF_GD27Q64 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Connect and search Security Code... PhoneLock: 102030 PhoneLock: 5690733 Done. Operation Done: 00:00:23 Avator Pro SW 2.4 Thanks To Avator Pro Team |
![]() | #19 (permalink) |
Member: 1478271 Status: Offline Sonork: 100.1608386 Thanks Meter: 1,798 ![]() | Karbonn K9 Virat 4G format Done Without Data Loss wit Avator Pro Karbonn K9 Virat 4G format Done Without Data Loss wit Avator Pro Code:
![]() Thanks To Avator Team |
The Following User Says Thank You to Momin_Telecom For This Useful Post: |
![]() | #20 (permalink) |
Member: 1478271 Status: Offline Sonork: 100.1608386 Thanks Meter: 1,798 ![]() | Micromax Q402 Hang On Logo Solve Just One Click With Avator Pro Micromax Q402 Hang On Logo Solve Just One Click With Avator Pro ![]() Code: Operation : Format / Reset Boot: SC9832 EMMC Error Report: OFF Hint: Power off phone, hold bootkey, Insert usb cable Scanning usb device... Phone found : SPRD U2S Diag (COM33) A thread is created to handle new usb connection, pls wait... Bootstrap: SPRD3 Connected...sending boot... FDL1 test...OK Sending FDL2... FDL2 test...OK Checking H/W report info... Read info is done. Erasing userdata partiton, it will take a minute or so, pls wait... Erase has been completed. Auto formatting... Format Done. Operation Done: 00:00:26 Avator Pro SW 2.4 Thanks To Avator Pro Team |
![]() | #21 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Oct 2011 Location: Karnataka.bangalore
Member: 1681098 Status: Offline Sonork: mahindra Thanks Meter: 74 | lava z60 frp done with aviator pro dongle lava z60 frp done with aviator pro dongle Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 eMMC cid: 150100464536324D42 EMMC CID : 150100464536324D42 EMMC Vendor: Samsung_FE62MB EMMC Size : 16GiB BOOT1 Size : 4 MiB BOOT2 Size : 4 MiB RPMB Size : 4 MiB User Area : 14.56 GiB Boot Completed. Checking userdata encryption... Userdata State : Encrypted Resetting DATA... FRP DATA Found, Reset ok. All Done Operation Done: 00:00:22 Avator Pro SW 2.4 ![]() |
![]() | #22 (permalink) | |
Insane Poster ![]() ![]() ![]() Join Date: Aug 2018
Member: 2861894 Status: Offline Thanks Meter: 53 | MMX Q340 Flashing success- Quote:
The Following User Says Thank You to AvatorPro For This Useful Post: |
![]() | #24 (permalink) | |
Member: 2861894 Status: Offline Thanks Meter: 53 | MMX Q350 Flashing success- Quote:
![]() | #26 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2007 Location: Infinity-Box Support-
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,352 ![]() | Gionee X1 FRP reset done- Quote:
![]() | #27 (permalink) | |
Member: 2861894 Status: Offline Thanks Meter: 53 | Panasonic P55 flashing- Quote:
![]() | #28 (permalink) | |
Member: 2861894 Status: Offline Thanks Meter: 53 | Gionee P7 Max frp reset done- Quote:
![]() | #29 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2015 Location: EARTH Age: 38
Member: 2332823 Status: Offline Sonork: 100.1662161:modern-mobile Thanks Meter: 460 ![]() | ![]() Vivo Y66 (1609) Fix Hang On Logo Avator Pro Code: Operation : Factory Reset Brand: VIVO Model: MTK_AUTO Error Report: OFF Hint:Power off phone, Insert usb cable (Connecting 'BROM Mode' Hold Bootkeys) Tip: requiring BROM port scanning usb device... Phone found: MediaTek USB Port_V1632 (COM35) A thread is created to handle new usb connection, pls wait... Any errors please select another boot and try again. SoC: 6755 [MT6755], SW: 0001, HW: CB00 BL Ver: FE; Indicate: 00000005 Waiting for new comport... New Port: COM23...ok CPU: MT6750 Waitting enter meta... Connected, tracking... Factory Resetting ... Reset Done Operation Done: 00:00:39 Avator Pro SW 2.4 |
The Following User Says Thank You to modern-mobile For This Useful Post: |
![]() | #30 (permalink) | |
Member: 2861894 Status: Offline Thanks Meter: 53 | Xolo Era3x Privacy Lock removed- Quote:
