AVATOR BOX (China Phones Service Tool) |
05-18-2011, 03:58 | #1 (permalink) |
Freak Poster Join Date: Apr 2011
Member: 1555119 Status: Offline Thanks Meter: 102 | powerful Avator Box Hot function If you have some news and test please send to E-mail [email protected] Form Avator Box bugz2001 feedback Spd 3 IMEI Change !!! i changed 3 imie by avator with this method 1: change original imie 1 to new imie 1 2: change original imie 2 to new imie 2 3: it will rebuild a new flashfile renamed " rebuild_flashfile name" 4: select the new flash file 5: change original imie 1 (in this case imie 2 ) to new imie 1 (in this case imie 2 ) 6: change original imie 2 (in this case imie 3 ) to new imie 2 (in this case imie 3 ) 7: this is rebuild a new flash file call "rebuild_rebuild_flash file" 8: write this new flash to fone Last edited by Avatorbox_Help; 05-18-2011 at 05:32. |
The Following 6 Users Say Thank You to Avatorbox_Help For This Useful Post: |
05-18-2011, 04:05 | #2 (permalink) |
Member: 1555119 Status: Offline Thanks Meter: 102 | Avator Box RJ45 Pinfind (Easy Repair China nokia Pinout in PCB) Last edited by Avatorbox_Help; 05-18-2011 at 04:26. |
The Following 4 Users Say Thank You to Avatorbox_Help For This Useful Post: |
05-18-2011, 04:12 | #3 (permalink) |
Member: 1555119 Status: Offline Thanks Meter: 102 | Avator Box Mstar Support News!!! <<Infinite possibility>><<Infinite upgrade>> 16MB Flash Read only 1 min 15 Sec |
The Following 2 Users Say Thank You to Avatorbox_Help For This Useful Post: |
05-18-2011, 04:30 | #5 (permalink) |
Member: 1555119 Status: Offline Thanks Meter: 102 | Two pinfind options in SPD 6600L Avator Box slove the 6600L CPU 100% Log = using S6600L/WE6226 - COM Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast... RXD=7 TXD=9 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100006A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: 66007001 Flash: NOR_EN71GL064 Set FLASH Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A IMEI 1=355289000606939 IMEI 2=355289000606947 --------NOR_FLASH_CONFIG-------- Flash Bank count=1 EFS sector count=6 File sector count=0 Sector size=0x00010000 Flash start addr=0x00000000 Flash size=0x00800000 Fix NV addr=0x00780000 Product information addr=0x007F0000 MMI resource addr=0x005C0000 ------Auto Format Address------- Start=0x00790000 Size =0x00060000 Read FS info...done Log = using S6600L/WE6226 - USB Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast... D-=8 D+=6 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM113 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: 66007001 Flash: NOR_EN71GL064 Set FLASH Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A IMEI 1=355289000606939 IMEI 2=355289000606947 --------NOR_FLASH_CONFIG-------- Flash Bank count=1 EFS sector count=6 File sector count=0 Sector size=0x00010000 Flash start addr=0x00000000 Flash size=0x00800000 Fix NV addr=0x00780000 Product information addr=0x007F0000 MMI resource addr=0x005C0000 ------Auto Format Address------- Start=0x00790000 Size =0x00060000 Read FS info...done |
05-18-2011, 04:36 | #6 (permalink) |
Member: 1555119 Status: Offline Thanks Meter: 102 | Avator Box LG MTK Mobile Support <test LG GX220> Read Info Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... BB:6235, HardwareVer:8A01, SoftwareVer:8A04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 00EC00F100000095 Read Hardware Information is done. Get Project ID from phone... Project ID: GX200-00-V10e-724-XX-FEB-24-2010 Write Imei Initializing... DA_LIB_VER_2.5.1.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Connecting, Please turn on the phone... Connected! Checking IMEI... Original IMEI 1= 358688000000058 IMEI 1 rebuild has been implemented: 354521200000000 Original IMEI 2= 358688000000058 IMEI 2 rebuild has been implemented: 354782220000000 Need to restart the phone to verify new imei. |
The Following User Says Thank You to Avatorbox_Help For This Useful Post: |
05-18-2011, 04:48 | #7 (permalink) |
Member: 1555119 Status: Offline Thanks Meter: 102 | Avator Box help you Repair Hardware <best tool no need talk more> flash ID 000000000000 reheat alug mtk chip and flash chip then try on the fone same no power then detect again Format it here result |
The Following 3 Users Say Thank You to Avatorbox_Help For This Useful Post: |
05-18-2011, 05:22 | #10 (permalink) |
Member: 1555119 Status: Offline Thanks Meter: 102 | avator Box success flash the INFINEON With 5.301 Tool Initializing... DA_LIB_VER_3.2.2.7 It is sensing the pinout fast,please hold on the phone Power key RXD=8 TXD=7 Connecting...Please hold on the POWER key until the red gauge is finishing... Changing baudrate... Set baudrate to 115200 ok Reading phone HW info... Read info is done. BB: PMB7880 Flash: NOR_MX29LV320T setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. Last edited by Avatorbox_Help; 05-18-2011 at 05:27. |
05-25-2011, 06:49 | #12 (permalink) |
Member: 1555119 Status: Offline Thanks Meter: 102 | example: Mobile:PHERIPS k850 WT6226_ST M36L0R7050U3ZS First,we need Find The mobile pinout in PCB Connect the Mobile with UFC cable and use the Box red and black to mobile bettery Pin Now we can pinfind and unlock with Avator Box Just a Simple example In here!!! |
07-13-2011, 15:19 | #13 (permalink) |
No Life Poster Join Date: Mar 2011 Location: GSM World!! Age: 35
Member: 1530237 Status: Offline Sonork: 100.1614868 Thanks Meter: 5,598 | Huawei and Zte INfineon are also supported for repair .. And unlock by flash unlocked Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=4 TXD=3 Connecting...Please hold on the POWER key until the red gauge is finishing... Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. Repair File for A35G+ Zte A36G+by resident AvatorTeam.rar - 4shared.com - online file sharing and storage - download Repair File for Huawei T158 T158 Claro repair File by resident Avator Team.rar - 4shared.com - online file sharing and storage - download How repair.. Select Infineon CPU select write Flash select Flash file Phone repaired How read Codes from Firmware we click on the Tools CHIP Infineon7870/80 select and press search A window select the Flash file wait 10 seconds fully realized and successful operation Br simlock |
The Following 2 Users Say Thank You to resident2011 For This Useful Post: |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
i WANT TO BUY NOKIA BOX !!! | Eric | Wanted Products | 8 | 02-14-2011 13:23 |
New Nokia BOX for you!!! | gsmEsteve | Main Sales Section | 0 | 11-18-2000 17:09 |
===!! TOP 20 hot SOFTWARE FREE DOWNLOAD !!!=== | cimbalo | GSM Mobile Links | 3 | 10-01-2000 14:53 |
