AvatorBox - TEST Report [ copy Nokia 2700 CPU:SPD6531 ] DONE 1 Attachment(s) AvatorBox - TEST SPD6531 DONE
Connect Instruction: http://forum.gsmhosting.com/vbb/atta...1&d=1416603208
Info: Code:
-------------------Created: 20.11.2014 12:32:30-------------------
Chip=SpreadTrum Action=ReadInfo
FlashType=NOR
boot=6531
Expert Mode=Disable
Range[start]=0x0
Range[size]=0x0
Interface=USB
FlashFile=
Comport=COM3
Baudrate=921600
CPU_Type=SC6531
CPU_ID=65310000
NOR_ID=00EF004000160000
NOR_Size=4MB
NOR_Name=SF_W25Q32BV
NOR_DieCnt=1
NAND_ID=
NAND_Size=
NAND_Name=
Initializing...
DA_LIB_VER_5.9.0.0
Auto reset and search the USB-to-Serial...
Connecting...
Spd USB-to-Serial=COM16
Connected...sending boot...
FDL test...OK
ArmBootMode: 6531000000005A00_00
Wait for init Commzero Security Engine...
Done.
Loading bootloader...
Done.
Changing baudrate...
Set baudrate to 921600 is ok
Reading phone HW info...
Read info is done.
CPU: SC6531 Flash: SF_W25Q32BV
setting the Flash Parameters...
Settings have been completed!
setting the Serial Flash Parameters...
Reading FileSystem info...
File System Ver: 80
IMEI 1=355147050181734
------Auto Format Address-------
Start=0x003B0000
Size =0x00050000
Read FS info...done
+++++++++++++++++++End at: 20.11.2014 12:32:40+++++++++++++++++++
Read Full: Code:
-------------------Created: 20.11.2014 12:37:33-------------------
Chip=SpreadTrum
Action=ReadFlash
FlashType=NOR
boot=6531
Expert Mode=Disable
Range[start]=0x0
Range[size]=0x0
Interface=USB
FlashFile=C:\Users\Cifroservis\Desktop\2700_6531
Comport=COM3
Baudrate=921600
CPU_Type=SC6531
CPU_ID=65310000
NOR_Size=4MB
NOR_DieCnt=1
NAND_ID=
NAND_Size=
NAND_Name=
Initializing...
DA_LIB_VER_5.9.0.0
Connecting...
FDL test...OK
Done.
Done.
Read info is done.
Reading Flash...
Saved file to:
All Done.
+++++++++++++++++++End at: 20.11.2014 12:39:57+++++++++++++++++++ |
