Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > AVATOR BOX
AVATOR BOX (China Phones Service Tool)
Old 01-02-2012, 08:35   #1 (permalink)
tonmobile's Avatar
Member: 191096
Sonork: 1610034
Thanks Meter: 475
AvatorBox Universal JIG to USB cable
May be not perfect in your eyes But useful in your works
By this cable converter you can use USB cable come with phone as flash cable
Tested with MicroUSB 100 % worked [Working as 05B]
Br.
tonmobile
The Following 36 Users Say Thank You to tonmobile For This Useful Post:
Old 01-03-2012, 14:21   #2 (permalink)
Member: 1146881
Thanks Meter: 19
super
thank u
The Following User Says Thank You to abdul_rahman9 For This Useful Post:
Old 01-03-2012, 14:28   #3 (permalink)
Member: 1682114
Sonork: 100.1608979
thanks....................
The Following User Says Thank You to haroon_1_5 For This Useful Post:
Old 01-03-2012, 15:50   #4 (permalink)
Member: 1134306
Thanks Meter: 133
Avator is always great and always think for there customer
Old 01-03-2012, 19:21   #5 (permalink)
h-d
Member: 102872
Thanks Meter: 11
this way can not connect the cable to transfer data to nokia and samsung ... I saw a small amperage is not enabled USB function
Old 01-04-2012, 01:22   #6 (permalink)
tonmobile's Avatar
Member: 191096
Sonork: 1610034
Thanks Meter: 475
Connect to Nokia as Data Storage
Connect to Nokia as Media
Connect to Nokia as Nokia PC Suite
tonmobile
The Following 6 Users Say Thank You to tonmobile For This Useful Post:
Old 01-04-2012, 01:42   #7 (permalink)
tonmobile's Avatar
Member: 191096
Sonork: 1610034
Thanks Meter: 475
USB MINI as 05A
tonmobile
The Following User Says Thank You to tonmobile For This Useful Post:
Old 01-04-2012, 01:49   #8 (permalink)
Member: 1222089
Sonork: 100.1583019
Thanks Meter: 2,688
Great One .. thanks For your effort
Br.,
SmartGsm
Originally Posted by tonmobile View Post
USB MINI as 05A
tonmobile
The Following 2 Users Say Thank You to Smart-gsm For This Useful Post:
Old 01-04-2012, 02:19   #9 (permalink)
GsmSolution.'s Avatar
Member: 1388679
Sonork: 1597516:GsmSolution
Thanks Meter: 2,757
i think smart need to add this kind of adaptor as it is needed for avator users..thanks for your good idea
br
The Following 3 Users Say Thank You to GsmSolution. For This Useful Post:
Old 01-04-2012, 03:46   #10 (permalink)
Member: 1222089
Sonork: 100.1583019
Thanks Meter: 2,688
yes . i can ... why not
Br.,
smartgsm
The Following User Says Thank You to Smart-gsm For This Useful Post:
Old 01-04-2012, 05:47   #11 (permalink)
Member: 1522153
Sonork: Uzbekistan Andijan
Thanks Meter: 21
Old 01-04-2012, 07:00   #12 (permalink)
h-d
Member: 102872
Thanks Meter: 11
I found it did not work, I tested the two boxes on the avator and gpg (I see its hardware is the same)
I use the mini usb cable P-05B. used on the nokia and samsung are not. amperage is too small. I used to supply power through the usb adapter to work ok. it shows the amperage is not enough.
because I see in the box spiderman (usb finder) and ve-pro (power board) has many transistors are controlled to power. This in no Avator.
set pinout:
set GND, VCC
Old 01-04-2012, 07:06   #13 (permalink)
h-d
Member: 102872
Thanks Meter: 11
I find that avator has provided a lot of cable, first plug the usb drive needs to be done. need only pinout that everything can be solved
Old 01-04-2012, 08:52   #14 (permalink)
tonmobile's Avatar
Member: 191096
Sonork: 1610034
Thanks Meter: 475
With my convertor cable in this topic
1. To working as mobile phone software service
Use AvatorBox cable and using power through Black-Red of Main cable
And working through my convertor cable.
2. For options to use as Data cable.
Must connect phone by internal battery. It will be worked fine.
tonmobile
Old 01-04-2012, 09:07   #15 (permalink)
h-d
Member: 102872
Thanks Meter: 11
I think you probably have not tried on many models.
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.22697 seconds with 11 queries
