Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > AVATOR BOX
AVATOR BOX (China Phones Service Tool)
Old 06-27-2011, 04:02   #1 (permalink)
ksvimal's Avatar
Member: 1569095
Sonork: 100.1606114
Thanks Meter: 19
Smile Gfive G350 not detect
Model: Gfive G350
Problem: Sudden off after call abort (Sometimes).
Fone is in Working Condition.
But In Avator, Fone not Detected.
So Please Guide me to solve this problem..
Waiting For Your Reply...
Old 06-27-2011, 09:52   #2 (permalink)
..::Sourav::..'s Avatar
Member: 1101631
Sonork: 100.1604605
Thanks Meter: 68
Use Latest Ver, Also Install Correct Box Driver,
Than Post Ur Result.
Br,
Sourav
Old 06-28-2011, 07:57   #3 (permalink)
ksvimal's Avatar
Member: 1569095
Sonork: 100.1606114
Thanks Meter: 19
Br,
Sourav
Still same problem . now i use ver 5.510 .. plz help
Old 06-28-2011, 11:42   #4 (permalink)
FullFlashPak's Avatar
Member: 782530
Thanks Meter: 8,136
hello bro .
this phone not a conect with cable. used rx tx pintout on borad.
Old 06-28-2011, 12:34   #5 (permalink)
ksvimal's Avatar
Member: 1569095
Sonork: 100.1606114
Thanks Meter: 19
Originally Posted by multi_ele View Post
hello bro .
Initializing...
DA_LIB_VER_3.4.1.2
It is sensing the pinout fast,please hold on the phone Power key
RXD=2 TXD=22
Connecting...Please hold on the POWER key until the red gauge is going...
Any errors please select another boot and try again.
Failed to read HardCode, REG=0x80000008
Error: Failed to read REG=0x80010008
Error: Failed to read REG=0x84010008
Error: Failed to read REG=0x80001008.
(i used all boot type and lower version of avator, and i try in baudrate change tooo. all same result)
please help me broooo
Old 06-28-2011, 13:22   #6 (permalink)
Member: 782530
Thanks Meter: 8,136
Originally Posted by ksvimal View Post
initializing...
Da_lib_ver_3.4.1.2
it is sensing the pinout fast,please hold on the phone power key
rxd=2 txd=22
connecting...please hold on the power key until the red gauge is going...
Failed to read hardcode, reg=0x80000008
error: Failed to read reg=0x80010008
error: Failed to read reg=0x84010008
error: Failed to read reg=0x80001008.
(i used all boot type and lower version of avator, and i try in baudrate change tooo. All same result)
bro please conect with me ...ym,msn.
Or post here team viwer id pass
Old 06-28-2011, 15:50   #7 (permalink)
Member: 1101631
Sonork: 100.1604605
Thanks Meter: 68
Initializing...
DA_LIB_VER_3.4.1.2
RXD=2 TXD=22
Read a Flash File From Same Model Working Phone.
& Then Write Flash In Problem Phone...
Then Post Your Result...
Regard,s
Sourav
Old 07-14-2011, 13:23   #8 (permalink)
ksvimal's Avatar
Member: 1569095
Sonork: 100.1606114
Thanks Meter: 19
Regard,s
Sourav
First try to tell the solution to read and format pleaseeeeeeeee,
Old 07-14-2011, 16:56   #9 (permalink)
ksvimal's Avatar
Member: 1569095
Sonork: 100.1606114
Thanks Meter: 19
first try to tell the solution to read and format pleaseeeeeeeee,
avator team please helpppp ,any experts please help its urgent
Old 07-15-2011, 03:54   #10 (permalink)
Member: 782530
Thanks Meter: 8,136
Sir Here Is Soluation
http://forum.gsmhosting.com/vbb/7221705-post16.html
Old 07-15-2011, 04:15   #11 (permalink)
Member: 782530
Thanks Meter: 8,136
Initializing...
DA_LIB_VER_3.4.1.2
RXD=2 TXD=22
Dear Sir,
Your Chack Your Cellphone In mtk Chip.
Please Chack In Spd .
Or
Your Conect With Spd Chip Now U Chack With MTK Chip.
I hope YOur Problem Will Be Slve.
Post Result .Must
Old 07-15-2011, 04:31   #12 (permalink)
Avatorbox_Help's Avatar
Member: 1555119
Thanks Meter: 102
check your cable connect
maybe is damage
Old 07-15-2011, 05:17   #13 (permalink)
ernie78™'s Avatar
Member: 1229604
Sonork: 100.1602688
Thanks Meter: 4,813
Initializing...
DA_LIB_VER_3.4.1.2
RXD=2 TXD=22
this error is 100% cable problem
try to use rj45 cable then read info then readflash then format post result
screen shot
Old 10-02-2011, 08:37   #14 (permalink)
Member: 1417077
Sonork: 100.1626477
Thanks Meter: 32
Model: Gfive G350
now iam using avator v5.620 problem still
any solution
thanks in advance
Old 10-02-2011, 09:18   #15 (permalink)
GsmUniversal's Avatar
Member: 649528
Sonork: 100.1590443
Thanks Meter: 6,958
Hi
Let us know which chip your phone have ?
did you tried to connect phone on spd , mtk or another tab ?
is phone giving pinout on pinout function ?
please post complete info ill try to guide u to solve ur problem as soon as possible..
Regards
Avatorbox Team
Originally Posted by anu remesh View Post
Model: Gfive G350
any solution
thanks in advance
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
hope it is not too comercial aleksj Wanted Products 0 06-12-2000 13:22
Nokia 5110 - "SIMcard not accepted". Kond Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 03-02-2000 22:46
winlock wintesla m2bus do not work Bigbrothers2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 01-26-2000 14:31
Page generated in 0.40042 seconds with 9 queries
