Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > AVATOR BOX
AVATOR BOX (China Phones Service Tool)
Old 06-02-2015, 20:14   #1 (permalink)
Umesh_Arora's Avatar
Member: 1792140
Sonork: 100.1618782,gaba
Thanks Meter: 6,087
How To Compress single Large file in multi part 1,2,3,4 Files Using Winrar
Upload your phone large size *cmz file in 3 or 4 part
Do you wish to compress files so that it can transfer easily between storage devices, or when you want to upload it to an email or how about when you just want to save precious hard drive space when storing files.Well, now you can just do that.
To compress large file using Winrar follow simple steps given below:
Step 1: Select and Right click on the file you want to Compress and select Add to Archive option.
Step 2: A window will pop up with various options. In Archive name field type the name of your archive manually in the text box provided below.
Step 3: When creating a new archive, you first need to select the archive format. ZIP is preferable when you are not sure that a receiver of your archive has WinRAR. Otherwise just select RAR, since it provides more options and higher compression.
Step 4: There are six compression methods supported: "Store", "Fastest", "Fast", " Normal", "Good" and "Best". The Best method provides high, but slow compression. Fastest method compresses poorly, but it is very fast. Store method just merges files into an archive without any compression. If you want to create an archive for distribution or for long storage, It would be best to probably ignore the time constraint and choose the Best compression method to reduce the size as much as possible. But for daily backups choose Normal compression method
Step 5: At the bottom there is a Tab saying “Split to Volume, Bytes” In the box enter a figure or you can use the drop down menu to make your choice. Remember you have to enter the value in bytes, kilobytes or megabytes and this applies only to .rar extension. (1024 KB equals 1 MB)
In the example below, I have chosen 98078 KB which comes to around 95.77 MB.
choice 700mb for 3.5gb file
Step 6: When you have chosen the right options for your archive, click the OK button.
(In my example below, the video file I had chosen was compressed into three parts comprising of 95.7 MB each)
You can also watch this same procedure on YouTube. I have created the video just to make it easier for everyone to learn
http://www.youtube.com/watch?v=JTV2bYx6Dtg
Umesh Gaba
The Following 5 Users Say Thank You to Umesh_Arora For This Useful Post:
Old 06-03-2015, 02:51   #2 (permalink)
Mirtelecom's Avatar
Member: 1754881
Sonork: 100.1644926
Thanks Meter: 146
Good sharing Umesh Sir jee, happy to see you on Avator Section.
Br. Mirtelecom
Old 06-03-2015, 09:01   #3 (permalink)
Member: 1043909
Thanks Meter: 60,921
Hello,
For best compression you can use 7-Zip: 7-Zip
Its free and very good.
You can pack the same file with rar and 7zip and compare result file size.
The Following 3 Users Say Thank You to YellowBoss For This Useful Post:
Old 06-03-2015, 15:53   #4 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Originally Posted by YellowBoss View Post
Hello,
Thanks but how to compress a single file to a smallest one,the tutorial above shows spliting of file to parts,1,2,3, Etc...
Old 06-04-2015, 06:27   #5 (permalink)
Member: 1043909
7-Zip has similar menu and you can split big files to small parts with 7-Zip also.
Old 06-04-2015, 07:15   #6 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
am talking of compressing big file to small not splitting
Page generated in 0.18716 seconds with 8 queries
