AVATOR BOX (China Phones Service Tool) |
08-13-2018, 08:29 | #1 (permalink) |
Banned Join Date: Jan 2015 Location: EARTH Age: 40
Member: 2332823 Status: Offline Sonork: 100.1662161:modern-mobile Thanks Meter: 463 | Oppo A83 cph1729 password pattern pin Disable all lock withoutdata loss done by Avato Oppo A83 cph1729 password pattern pin Disable all lock withoutdata loss done by Avator_Pro Operation : ScreenLock Unlock/Relock Brand: OPPO Model: MTK_AUTO Hint:Power off phone, Insert usb cable (Connecting 'BROM Mode' Hold Bootkeys) scanning usb device... Phone found: MediaTek USB Port (COM8) A thread is created to handle new usb connection, pls wait... Any errors please select another boot and try again. SoC: 6763 [MT6763], SW: 0001, HW: CA01 BL Ver: FE; Indicate: 000000E5 Loading boot... INT_SYSRAM_BOOT test completed. Any errors manually select "ConnectMothods" and try again Connection type:brom Configuring DRAM... Waiting for DRAM detection...OK Sending 2nd DA ... SYNC... OK 2nd DA...OK Retrieving RAM Configuration ... SRAM Size: 0x40000 DRAM Size: 0xC0000000 Retrieving Memory Configuration ... EMMC CID : 90014A484247346132A51FC310CA152B EMMC Vendor: Hynix_HBG4a2 EMMC Size : 32GiB BOOT1 Size : 4 MiB BOOT2 Size : 4 MiB RPMB Size : 4 MiB User Area : 29.12 GiB Boot Completed. Checking userdata encryption... Userdata State : Encrypted Unlock / Relocking Screen Lock... Tip: first execution is unlcok and the second is relock code=1 All done. Operation Done: 00:00:11 Avator Pro SW 2.2 WBR ___________ modern-mobile |
The Following 10 Users Say Thank You to modern-mobile For This Useful Post: |
08-13-2018, 14:55 | #2 (permalink) |
Member: 2332823 Status: Offline Sonork: 100.1662161:modern-mobile Thanks Meter: 463 | Again oppo a83 frp also done avator pro Operation : Reset FRP Brand: OPPO Model: MTK_AUTO Hint:Power off phone, Insert usb cable (Connecting 'BROM Mode' Hold Bootkeys) scanning usb device... Phone found: MediaTek USB Port_V1632 (COM8) A thread is created to handle new usb connection, pls wait... Any errors please select another boot and try again. SoC: 6763 [MT6763], SW: 0001, HW: CA01 BL Ver: FE; Indicate: 000000E5 Loading boot... INT_SYSRAM_BOOT test completed. Any errors manually select "ConnectMothods" and try again Connection type:brom Configuring DRAM... Waiting for DRAM detection...OK Sending 2nd DA ... SYNC... OK 2nd DA...OK Retrieving RAM Configuration ... SRAM Size: 0x40000 DRAM Size: 0xC0000000 Retrieving Memory Configuration ... EMMC CID : 90014A484247346132A50E90746AC4FB EMMC Vendor: Hynix_HBG4a2 EMMC Size : 32GiB BOOT1 Size : 4 MiB BOOT2 Size : 4 MiB RPMB Size : 4 MiB User Area : 29.12 GiB Boot Completed. Checking userdata encryption... Userdata State : Encrypted Reading phone info... done. Android7.1.1 Resetting DATA... FRP DATA Found, Reset ok. All Done Operation Done: 00:00:14 Avator Pro SW 2.2 |
The Following 3 Users Say Thank You to modern-mobile For This Useful Post: |
01-24-2020, 08:06 | #3 (permalink) |
Junior Member Join Date: Nov 2014 Location: Proddatur
Member: 2295125 Status: Offline Thanks Meter: 14 | 10000% unlock cph1729 Oppo A83 with umt mtk tool Operation : Factory Reset (New) Checking for existing META ports... Found Android Gadget VCOM Driver (COM286) on COM286 Device Path : usb\vid_22d9&pid_0006&rev_???? Configuring Communication Channel... Reading phone information... CPU : MT6763 SW Ver. : MOLY.LR12A.R1.TC16.SP.V26.P28 HW Ver. : OPPO6763_C66_N1_HW Starting Factory Reset... Reset success Operation finished [UltimateMTK Ver. 2.5] power off phone press and hold volume up down select cpu MT6763 and click FacRst (Meta) its Done |
