need H999 SPD 8M flash Connecting... Spd USB-to-Serial=COM74 Connected...sending boot... FDL test...OK ArmBootMode: 6600700900005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_EN71GL064B0 setting the Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A IMEI 1=352472040000064 IMEI 2=352472040000080 --------NOR_FLASH_CONFIG-------- Flash Bank count=4587595 EFS sector count=0 File sector count=0 Sector size=0x00000000 Flash start addr=0x00000000 Flash size=0x00800000 Fix NV addr=0x00000000 Product information addr=0x00760000 MMI resource addr=0x0000002B ------Auto Format Address------- Start=0x00000000 Size =0x00760000 Read FS info...done |
need avator box logs...... whts problem with your cellphone. |
i need arabic this phone i read flash from this mobile and flash it with another flash but phone dead i write orignal flash but programming stop at 99% now phone not work |
Change buarate .. And write again. |
i try change baudrate to 11,23,46,92 but flash stop at 99% pls help me |
ITS 3 SIM CELLPHONE ????? [IMG]http://**********.pk/images/rgh1293037943z.jpg[/IMG] TRY WITH THIS FLASH FILE. Q 7 H999.bin POST RESULT. |
Error: Failed to TX buffer, Please check the ،°Buff PGM،±option in the global settings. |
Post here teamviwer id pass |
1 Attachment(s) Quote:
ok thank you i will try this and send result thank you for help |
when i choose buffer pgm flash stop at 0% then show this msg Programming... Compare Image: Enable Error: Failed to TX buffer, Please check the ،°Buff PGM،±option in the global settings. |
i send pm to u pls check thanks |
Hi i have seen u have problem ... if u have problem in writing flash after click on Buff PGM Option. then it means your Phone Flash ic is damage rehot or change flash ic and try again .. BR AvatorBox Team |
