AVATOR BOX (China Phones Service Tool) |
07-13-2013, 11:39 | #2 (permalink) |
No Life Poster Join Date: Oct 2010 Location: AvatorBox MCU
Member: 1427447 Status: Offline Sonork: 100.1596998 Thanks Meter: 4,218 | you phone detecting wrong Port Must detect like this see the image Do the Following Steps 1. SPRD U2S Diag Port ( this Diag port use for Onlt Imei(daig rebuilt)) 2. Right click > SPRD U2S Diag Port > Update Driver > select path (AvatorBox-V6.733\Drivers\Mobile Phone Drivers\SPD Android\SciU2S) 3. Choose Your Windows 32bit or 64bit 4. Install Drivers 5. Restart after restart computer Do these steps 1. SPD TAB 2. Select Read info or read Flash 3. Seelct Boot nand 4. Select boot 6820 or 8810 5.Select USB 6. uncheck pinfind 7. Press Start Than Connect usb boot cable to phone And Put Battery within 2 or 3 seconds . software will detects if you dont have usb boot cable . , Connect normal usb with hold Boot key and insert battery |
The Following User Says Thank You to Avatorbox For This Useful Post: |
