SC6530 WriteFlash Failed after Reset in AvatorBox Ver6.817 + SC 2 Attachment(s) To: Mr. resident2011 Phone Brand: Cross T2 CPU : SC_6530 Flash: SF_GD27Q64 8MB Phone Condition before Reset: Hang, Touchscreen Not Work Phone Condition After Reset : DEAD (No Power On) ReadInfo, ReadFlash, Reset is OK Done but phone not power on after reset. I try to writeflash backup file or change file from same good phone, but always: Error: Failed to send request to phone. I think still any bugs on this update and i hope will solved on next update. Thank you BR. elvahape |
I will check and I will answer as soon as possible I have personally performed tests on SC6530 and all were satisfactory. |
CROSS T2 dead after format using Avator 6.733 CPU : SC_6530 Flash: SF_GD27Q64 8M. Error: Failed to send request to phone. |
Please, compress your file. If you have 0 byte file, flash file is bad = phone dead. |
readed file is ok 8.192kb (8mb) and flash file from same good phone is ok too. so, i think this bug in software version and hope will fix soon by AB team :) |
After you compress the readed flashfile . how much MB or KB shows ? |
6,45Mb. -This Readed File: Cross_T2_SC6530_SF_GD27Q64 - Download - 4shared -This Compressed file: Cross_T2_SC6530_SF_GD27Q64 - Download - 4shared |
Only this Flash ID have problem ... or All Flash ID of 6530 have problem ? Do you try with previous version ? |
also SF_N25W0128 16MB have problem for reset or format, phone dead. Yes, i've been try ver6.733 but still problem. phone can live a normal life again when flashing using .pac file + original flasher. but we find it difficult to get the file .pac. |
We try to find the phone with these Flash IDs in our local market . As soon as i will reply you . or i will try contact you in yahooo . for remote testing ... if you found any other phones with diffrent flash ID of SC6530 . Please report us .. Is this phones Are brand in your country ? |
other's still cant, what about AB? CMIIW |
i will be eternally grateful |
yes it is a local brand in Indonesia. To date only two cases for flash ID of SC6530, namely: SF_N25W0128 16MB (Asiafone AF-7997 and AF-7000) & SF_GD27Q64 8MB (Cross T2). I am always ready to report not instances of intractable cases by avatorbox. |
MAXTRON MG-537 sprd6530 Dead After Format Quote:
LOG here Code: Chip=SpreadTrum |
Put Flash IC to SC6610 phone than write firmware Code: Initializing... |
