AVATOR BOX (China Phones Service Tool) |
04-30-2012, 12:00 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: mumbai india
Member: 432679 Status: Offline Thanks Meter: 118 | 6252 emergency??? emergecy ..imei changed same problem kindly assit Code: Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1148 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 FlashFile= Comport=COM101 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00C2002500350000 NOR_Size=2MB NOR_Name=SF_MX25U3235E NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.2.7 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C2002500350000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: C150B.XCX.3188.07.DMES.120301 |
04-30-2012, 12:48 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: ..::INDIA::.. Andhra Pradesh Age: 41
Member: 1528548 Status: Offline Sonork: 100.1613286(Offline) Thanks Meter: 2,244 | search same model working fone take Backup nv file then write nv file your fulty fone then change goodworking imei numbers i hope solve your problem if not solve problem check in hardwear Post result |
04-30-2012, 13:03 | #3 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Write good nv file ,if no luck then check its hardware. Regards |
The Following User Says Thank You to amn32 For This Useful Post: |
Emergency ....I need help!!!!!!!!!! I will ofer you winddp or windls dct3 | florinmar | Alcatel & TCL Old Models | 2 | 01-25-2002 02:20 |
Need 8210 full flash (austria) EMERGENCY | Gmcpaul | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-24-2001 01:26 |
EMERGENCY HOW TO REPAIR ALL CLOSED GID/MSIN? | ced1298 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-25-2001 09:07 |
OTE HD1 Emergency. IMEI Loss. Please Help!!! | Icarus | Alcatel & TCL Old Models | 6 | 11-20-2000 22:49 |
unlock sw for OTEdb need emergency | beginer | Alcatel & TCL Old Models | 1 | 01-05-2000 03:33 |
