N8 calculating process 100% but code not found 4 days and 12 hours ( >100hours) of calculating process but the code is not found ! Code: ******** Reading SimLock ******** |
Dont overclock your GPU and not work for your PC and your N8 code found . BR ;). |
but this last one (N8) it can't find the code at 100% |
Read hash again, or check hash and info on bat file.... |
1 Attachment(s) Quote:
as said you used overclock,you calculated the code fastly that's why code was not found desactivate overclock,that happened with me once |
Which tool you use for pm decrption ??? |
use ati 6990 duo gpu it found |
its a problem caused by wrong hash readed. :) |
BR ;). |
try to use other soft calculat for which one 100% code not found believe me Tested. br. |
BR, Lavarow |
