Need advice about GPU SL3 temp MSI afterburn Have 2 HD5970 latest 11.3 drivers using SLAP 2.1 MSI afterburner: 790 MHZ clock (Ram 1000Mhz) got about 6300 M/s GPU1 temp ~58 C GPU2 temp ~60 C GPU3 temp ~80 C GPU4 temp ~80 C GPU fans working at maximum in the open PC case there are more 4 working Fans( from side and from up from behind) Room temperature ~21 C ------------------------------------------------- What is gpu 3 and gpu 4 ? its in 1 card? how GPU 1-2-3-4 are counting? 1-2 one card? 3-4 other card? ------------------------------------------------- When pause temperature drops to ~31 C |
P.S. In the room BOEING 767 flying :)))))) destination SL3 code :)))))) |
Hi gpu core 1 and 2 is card that is lower and 3 and 4 gpu core is card that is higher in computer. This temperature is normal when in room you got 21C and use normal stock fans. If need better results buy this and you will got 60-65C max temp on both cards. Omni A.L.C. |
If I change GPU one with another? its would be the same? or now 3 and 4 gpu card is more faulty (I buy these cards used) ? 80..84 degrees its not too bad? to caution? and why its bigger temp? I connect full HD monitor to 3-4 GPU card but I do nothing only calculating codes (you cant do I think its stucked a bit) |
Will be the same card that is upper get hot air from first card and need got higher temp. 80-85C is accepted but not long time your fans on card will burn and after card burn too becosue if you want use this more then week instant work buy water cooling system in other way you burn cards in month. |
wgmmmx1 i m going to buy system quotation is core i7 3.40 ghz (Proccesser) asus sabertooth p67 (Mother Bord) corsair dominator 6 gb (Ram) Thermal Take 1200 w (PSU) Just 1 advice nedded Witch cards i m use for best calaculation 2x 5970 Or 2x 6990 ???????????????????? Plz Help me advice me best |
GPU2 + GPU4 On Card 2 Simple GPU1 and GPU 2 Near Fan on the Card temperature lower than GPU3&4 |
