Problem unlock 7230 Hello Problem reading SL3 Log info for 7230 - JAF and UFS always error Connecting to UFS3 SarasSoft #2 (SN:) UFxBoot V2.2 (c) SarasSoft 2003 UFS_USB V2.8 (c) SarasSoft 2007 Connected to UFS interface. Connection interface is set to UFS now. Job's finished successfully! SL3 Unlocking started Setting flash mode Reading CMT boot data... CMT Boot Data -------------- Asic ID : 000000010000022600000001020C192102044100 Public ID : 07300110059D544055C20FE2A09DD78AF142DA10 Hash : 7B045400E1752022F9EB80B0DEA9C65D Hardware ID: 020C192102044100 Sending 2ND... Cannot initialize booting 2ND Job's finished with errors! |
try with cable with 2 m-bus conector. I unlocked just today a 7230 with SLAP 2.3 Perfect http://www.4shared.com/photo/pv5CgNY...spaa_Feni.html B/R The_polack |
i tried ufs universal cable also the same, it wont go into local mode - also flashed new sw over usb - read info over fbus is no problem |
Why i should show you the time, i can't calculate the code, because i can't read out data i need! But i reach about 3400M h/s, if you want to know... (one 5970) |
still same problem - any ideas? |
but i tried all BSI on UFC Cable, and also bought Fbus Cable.... - and it just flicker white, and reboots, but i can read out info with UFS and HWK Soft? |
Maybe , problem is in phone. Have 1 here, have read log without problem, and 2. phone same sw version, not possible. Problem can only be in phone, not in cable!! |
Edit: Have modifyed my cable now, and 2. phone was readed also. But 1. phone without modification!! |
Have correct Pinout for UFC universal Fbus? Regards. |
Again having a problem reading Log - Please again update Fenix Team Hello, For a few month - you update fenix Software because ID was not supported for 7230 - now same case - maybe you can add ID again? SL3 Unlocking started Setting flash mode Reading CMT boot data... CMT Boot Data -------------- Asic ID : 000000010000022600000001020C192102044100 Public ID : 30E00211E62E00496B144E045BE4FDE612999D49 Hash : 7B045400E1752022F9EB80B0DEA9C65D Hardware ID: 020C192102044100 Sending 2ND... Cannot initialize booting 2ND Job's finished with errors! |
