02-12-2012, 11:44 | #46 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: falcon box
Member: 106346 Status: Offline Sonork: 100.1577684 Thanks Meter: 1,061 | Quote:
br matcom gsm | |
02-14-2012, 14:43 | #47 (permalink) |
No Life Poster Join Date: Jun 2002 Location: Czech republic Age: 43
Member: 12813 Status: Offline Thanks Meter: 20 | thank you for the great update unplug a replug Fenix key after computer start / restart remains in windows 7 64bit :-( Do you plan repair this bug? |
02-15-2012, 18:37 | #48 (permalink) |
Junior Member Join Date: May 2006
Member: 285042 Status: Offline Thanks Meter: 0 | C3-00, X2-00 bug C3-00 via USB Read Log: Fenix Reader SW version: 0.0.2 No FTDI drivers installed, USB connection is available only. If you want to use JAF/UFS interface install latest drivers. Connection interface is set to USB now. Checking connection... Reading phone info Product type: RM-614 MCU SW Version: V 03.36 05-07-10 RM-614 (c) Nokia PPM Version: V 03.36 05-07-10 RM-614 (c) Nokia OB Content Pack Version: Content: orange PL V 03.36 05-07-10 RM-614 (c) Nokia Imei: 354844045525592 Product code: 059B7R4 Simlock status: Profile bits: 8000000000000000 Config key: 2600300000000000 Fbus codes typed: 0/10 Key codes typed: 0/3 Block 1: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 26 00 3F Analyzing profile bits... This phone can be unlocked via keyboard and fbus Looking for flash files No flash files found for selected product Job's finished successfully! SL3 Unlocking started (via USB) Reading phone data Powering off the phone PLEASE PRESS PHONE`S POWER BUTTON CMT Hash : 1B0D74C532CA1C6133940C740E8C786E CMT Hw ID: 22000509200C0000 CMT Boot ROM CRC: DE56D582 CMT Secure ROM CRC: BDDE7A3A CMT Public Id: 00000000008719DCB2C8D87D9450644CFAE12CFC Preparing *****trap to use USB BootMedia Sending RAW 2ND Initializing... Could not generate encryption key Job's finished with errors! No phone found. Connect your phone using USB cable and try again. Checking connection... Reading phone info Product type: RM-614 MCU SW Version: V 03.36 05-07-10 RM-614 (c) Nokia PPM Version: V 03.36 05-07-10 RM-614 (c) Nokia OB Content Pack Version: Content: orange PL V 03.36 05-07-10 RM-614 (c) Nokia Imei: 354844045525592 Product code: 059B7R4 Simlock status: Profile bits: 8000000000000000 Config key: 2600300000000000 Fbus codes typed: 0/10 Key codes typed: 0/3 Block 1: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 26 00 3F Analyzing profile bits... This phone can be unlocked via keyboard and fbus Looking for flash files No flash files found for selected product Job's finished successfully! SL3 Unlocking started (via USB) Reading phone data Could not generate encryption key Job's finished with errors! No phone found. Connect your phone using USB cable and try again. Checking connection... Reading phone info Product type: RM-614 MCU SW Version: V 03.36 05-07-10 RM-614 (c) Nokia PPM Version: V 03.36 05-07-10 RM-614 (c) Nokia OB Content Pack Version: Content: orange PL V 03.36 05-07-10 RM-614 (c) Nokia Imei: 354844045525592 Product code: 059B7R4 Simlock status: Profile bits: 8000000000000000 Config key: 2600300000000000 Fbus codes typed: 0/10 Key codes typed: 0/3 Block 1: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 26 00 3F Analyzing profile bits... This phone can be unlocked via keyboard and fbus Looking for flash files No flash files found for selected product Job's finished successfully! X2-00 read LOG via USB: o phone found. Connect your phone using USB cable and try again. Checking connection... Reading phone info Product type: RM-618 MCU SW Version: V 04.80 03-08-10 RM-618 (c) Nokia PPM Version: V 04.80 03-08-10 RM-618 (c) Nokia C Content Pack Version: Content: kpn nl V 04.80 03-08-10 RM-618 (c) Nokia Imei: 352699042403108 Product code: 059C3T3 Simlock status: Profile bits: 8000000000000000 Config key: 2040800000000000 Fbus codes typed: 0/10 Key codes typed: 0/3 Block 1: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 20 40 8F Block 2: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 20 41 2F Analyzing profile bits... This phone can be unlocked via keyboard and fbus Looking for flash files No flash files found for selected product Job's finished successfully! SL3 Unlocking started (via USB) Reading phone data Powering off the phone PLEASE PRESS PHONE`S POWER BUTTON CMT Hash : 1B0D74C532CA1C6133940C740E8C786E CMT Hw ID: 22000509200C0000 CMT Boot ROM CRC: DE56D582 CMT Secure ROM CRC: BDDE7A3A CMT Public Id: 000000000071B6EBC53D00DDC38F0C9D6C2DA2BC Preparing *****trap to use USB BootMedia Sending RAW 2ND Initializing... Could not generate encryption key Job's finished with errors! What I do bad?? |
02-18-2012, 21:03 | #50 (permalink) |
Junior Member Join Date: Mar 2006
Member: 245506 Status: Offline Thanks Meter: 2 | Today I bought this program and I hope that we will solve the problems that exist in slap4.3 SL3 BF Distributed System - HOME |
02-21-2012, 11:38 | #51 (permalink) |
Freak Poster Join Date: May 2005 Location: Novi Sad, Serbia Age: 43
Member: 145248 Status: Offline Thanks Meter: 27 | i had same problem with x2-01.. disconect phone, close Fenix flasher and click on Update card on fenix sw.. after that, run Fenix flasher, connect phone and click on Read Log. For me, fenix saved LOG file but FNX file does not saved... i dont know which is, 15-digits or 20-digits without that... |
02-21-2012, 13:24 | #52 (permalink) | |
br matcom gsm | |
02-23-2012, 05:25 | #54 (permalink) |
Freak Poster Join Date: Jan 2010 Location: Indonesia
Member: 1199611 Status: Offline Thanks Meter: 23 | Code: Detected card sn: 123456789123 Card version: 01.00 Life counter: 99.97% Fenix Reader SW version: 0.0.2 Connection interface is set to USB now. Looking for flash files Flash files found for selected product Resetting user code in TEST mode PLEASE PRESS PHONE`S POWER BUTTON CMT Hash : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT Hw ID: 030C192101033000 CMT Boot ROM CRC: 273F6D55 CMT Secure ROM CRC: DFAAF68F CMT Public Id: 23A0000371747F562EE3EB46CE054A57462C7D17 Extracting loaders from flash file Please use newer loaders for this device. Job's finished with errors! Thanks a lot sir.... |
02-23-2012, 20:34 | #57 (permalink) | |
http://forum.gsmhosting.com/vbb/8137154-post1.html br matcom gsm | |
02-23-2012, 20:49 | #58 (permalink) | |
Checking connection... Reading phone info Product type: RM-717 MCU SW Version: V 07.22 16-12-10 RM-717 (c) Nokia PPM Version: V 07.22 16-12-10 RM-709 (c) Nokia NTM Content Pack Version: Content: TMOUS_V1_059D9X6 V 07.22 16-12-10 RM-709 (c) Nokia Imei: 355971043262388 Product code: 059D9X6 Simlock status: Profile bits: 8000000000000000 Config key: 3102000000000000 Fbus codes typed: 0/10 Key codes typed: 0/3 Block 1: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 31 01 60 Block 2: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 31 02 00 Block 3: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 31 02 10 Block 4: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 31 02 20 Block 5: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 31 02 30 Block 6: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 31 02 40 Block 7: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 31 02 50 Block 8: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 31 02 60 Block 9: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 31 02 70 Block 10: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 31 03 10 Block 11: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 31 05 80 Block 12: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 31 06 60 Block 13: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 31 08 00 Block 14: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 31 04 90 Analyzing profile bits... This phone can be unlocked via keyboard and fbus Looking for flash files No flash files found for selected product Job's finished successfully! SL3 Unlocking started (via USB) Reading phone data Powering off the phone PLEASE PRESS PHONE`S POWER BUTTON CMT Hash : 1B0D74C532CA1C6133940C740E8C786E CMT Hw ID: 22000509200C0000 CMT Boot ROM CRC: DE56D582 CMT Secure ROM CRC: BDDE7A3A CMT Public Id: 00000000005BDF0CA6A067C710D4E57753940168 Preparing *****trap to use USB BootMedia Sending RAW 2ND Initializing... Could not verify hash, only LOG file is created Job's finished successfully! log file 355971043262388 BFBD3AD068C871DD2E204BD17602899F86B70209A90C7FB441 0049944082FA29F3F7C94A267012E5BF241DB07229D38EFFF4 8721569EFF95333110742EB41BA1AC48B54FE3D475DAF69857 03DCDB929A5D175C007357A57A2A647DE38E9DBB854B2B3348 18A6ABA1F390ABCC533D32E489A46188F624ADF2B5EE198238 D2F80CD771FE4E649C987FED3A52E5C302738BC5F50A6DAAF5 1A7E2A6C0544F28FB094 | |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
