05-10-2001, 14:06 | #1 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Uzhgorod, Ukraine Age: 47
Member: 3023 Status: Offline Thanks Meter: 1 | Mitsubishi Galaxy problem. I've got a problem while flashing this phone. I've started the flasher, the phone still displayed "Contact Provider" but the LED was blinking. During transfer the mains voltage was swiched off, and so the transfer was interrupted. The power was restored, but the phone now does not want to swich on at all even for flashing or EEPROM operations. Is it possible to bring it back to life? Please, send your replies to my e-mail as well: [email protected] Thank you in advance. WBR, Chris. |
05-11-2001, 00:03 | #2 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Be Age: 48
Member: 3081 Status: Offline Thanks Meter: 8 | Hi man, when you flash the phon firs of all you have to use cable for flsahig not for unlok, if you use cable for flash when you plug in the conector the led of your fone must go red and stay this way and after this remove the batery an then start flasher after aprox 5 second your phone must display if the flashing process goes ok.It must work, but after this i am not sure if your CONTACT SERVICE disapear because your CONTACT SERVICE is in your eprom. Regards Fludor |
Mitsubishi Tool Problem | maplegsm | Multi-Box | 7 | 03-13-2008 10:15 |
Mitsubishi M320i Problem for UNlocking | Amir-SkillZ | Multi-Box | 2 | 11-26-2007 16:31 |
Mitsubishi Mars PROBLEM | ARC | Mitsubishi | 0 | 02-19-2002 14:44 |
Mitsubishi Mars problem!!! :( Please help! | mastergsm | Mitsubishi | 0 | 08-19-2001 18:56 |
Mitsubishi MTD30 problem | peran | Various | 0 | 03-01-2000 04:33 |
