Need Flash file Lawow F800...Solved Model Name:- Lawow F800 CPU: SC6600L/WT6226A Flash: NOR_ST_M30L0T7000T0 Chip Size:- 16MB problem:- Set blinking(Lawow only) |
get from here link............... |
contact me on yahoo i have readed flash file |
set is dead now(not blinking ) |
here is another one try and post the result :link |
here i provide for all my frnds Quote:
here i provide for all my frnds LAWOW F800 16mb flash file working n tested LINK |
Initializing... DA_LIB_VER_3.2.2.7 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM134 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_TV00560002EDGB setting the Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A IMEI 1=355787044521899 IMEI 2=355787044521907 --------NOR_FLASH_CONFIG-------- Flash Bank count=1 EFS sector count=5 File sector count=0 Sector size=0x00010000 Flash start addr=0x00000000 Flash size=0x00800000 Fix NV addr=0x00790000 Product information addr=0x007F0000 MMI resource addr=0x005F0000 ------Auto Format Address------- Start=0x007A0000 Size =0x00050000 Read FS info...done hellooo sir i am little confuce about file i have f800 with blinkinn on startup and backup of flash 8 mb and here is available file please suggest me wich file use for this set |
Hello did u solve your problem???? |
Hello bro check this file first your phone flash file then try wit this....... |
Hello bro check this file first your phone flash file then try wit this....... F800_LAWOW_BLACK_OK_CPU=66007001_FLASH=TV00560002E DGB.bin |
f800 lawow blining Quote:
always error in 3% or 5% Initializing... DA_LIB_VER_3.2.2.7 It is sensing the pinout fast... RXD=2 TXD=8 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100006A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_TV00560002EDGB setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Buffer Program: Enable Unlock Done. Programming... Compare Image: Enable Error: Erase Flash |
