01-14-2021, 10:45 | #1 (permalink) |
Insane Poster Join Date: Mar 2019 Location: Algeria
Member: 2900446 Status: Offline Thanks Meter: 279 | 1st World Condor Smart TV S50G5500 Repair VIA eMMC 1st World Condor Smart TV S50G5500 Repair VIA eMMC Code: Main Board TP.MS338.PC821 Code: [/COLOR][/B]Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC 4FPD3R Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 1501003446504433520276F6B20D74DB Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 4FPD3R Product revision : 0.2 Product serial number : (hex) 76F6B20D Manufacturing date : 07/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x0A) 00001010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + High Speed timings in boot operation RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/4FPD3R_14_01_2021_09_11_01.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.8; FW: 1.24. --------------------------------------------------------------- Searching Android build info... Not found --------------------------------------------------------------- EXT_CSD saved to file H:/TP.MS338.PC821/S50G5500/(EXT_CSD CONDOR S50G5500) SAMSUNG EMMC 4FPD3R.bin. Switched to boot area partition 1. Opening H:/TP.MS338.PC821/S50G5500/(BOOT1 CONDOR S50G5500) SAMSUNG EMMC 4FPD3R.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.8; FW: 1.24. Switched to boot area partition 2. Opening H:/TP.MS338.PC821/S50G5500/(BOOT2 CONDOR S50G5500) SAMSUNG EMMC 4FPD3R.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.8; FW: 1.24. Switched to user area. Opening H:/TP.MS338.PC821/S50G5500/(FULL CONDOR S50G5500) SAMSUNG EMMC 4FPD3R_BY_DZGSM_TEAM.bin file... Reading. Please wait... Done. Elapsed time 00:25:01 SW: 2.1.8; FW: 1.24. Switched to boot area partition 1. Added partition BOOT1 to constructor file. Switched to boot area partition 2. Added partition BOOT2 to constructor file. SRF "H:/TP.MS338.PC821/S50G5500/CONDOR_S50G5500_SAMSUNG EMMC 4FPD3R_BY_DZGSM_TEAM.srf" has been installed successfully. Last edited by DZGSM-TEAM; 01-14-2021 at 10:54. |
The Following 4 Users Say Thank You to DZGSM-TEAM For This Useful Post: |
