12-11-2020, 14:10 | #1 (permalink) |
Major Poster Join Date: Feb 2012
Member: 1728056 Status: Offline Thanks Meter: 110 | 1st World Enie tv eles42m06a14k Repair VIA eMMC ADD SRF BY EMMC --BOOT1-BOOT2-FULL-EXT_CSD Full Dump 100% ENIE LED SMART TV3D 715 Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 004G90 Page size : 512 B Block size : 512 B Block count : 7733248 Size : 3776.00 MB --------------------------------------------------------------- CID Info CID : 110100303034473930109087CCEA41F5 Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 004G90 Product revision : 1.0 Product serial number : (hex) 9087CCEA Manufacturing date : 04/2014 --------------------------------------------------------------- CSD Info CSD : D00E00320F5903FFFFFFFFE792400075 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 1 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 4096 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 512 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1933312 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/004G90_10_12_2020_21_39_41.bin. Connect successful. Code: RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1933312 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/004G90_10_12_2020_21_39_41.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.4; FW: 1.24. Opening C:/Users/m/Desktop/Toshiba eMMC 004G90_10_12_2020_21_43_26.bin file... Reading. Please wait... Code: SW: 2.1.4; FW: 1.24. Opening C:/Users/m/Desktop/Toshiba eMMC 004G90_10_12_2020_21_43_26.bin file... Reading. Please wait... Done. Elapsed time 00:26:42 SW: 2.1.4; FW: 1.24. Switched to boot area partition 1. Opening C:/Users/m/Desktop/enie eles42m06a14ks serie 715 EMMC/Toshiba eMMC 004G90_10_12_2020_22_13_51.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.4; FW: 1.24. Switched to boot area partition 2. Opening C:/Users/m/Desktop/enie eles42m06a14ks serie 715 EMMC/Toshiba eMMC 004G90_10_12_2020_22_14_23.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.4; FW: 1.24. EXT_CSD saved to file C:/Users/m/Desktop/enie eles42m06a14ks serie 715 EMMC/EXT_CSD_10_12_2020_22_14_36.bin |
The Following 8 Users Say Thank You to kaka88 For This Useful Post: |
12-11-2020, 14:23 | #2 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | Thanks for the perfect report |
The Following 2 Users Say Thank You to Fast Unlocker For This Useful Post: |
