12-26-2019, 12:39 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | 1st World JKM-LX1 REPAIR Done by changing Rubbish Micron eMMC to Samsung 64GB [IMG]****************************/convkey/8e12/om8kq3wzkjw64fszg.jpg?size_id=4[/IMG] 1st World HUAWEI Y9 2019 JKM-LX1 Repair done by changing old eMMC Micron model to Samsung with same capacity storage 64GB by new MEDUSA PRO II Software with max Bus mode & Speed [IMG]****************************/convkey/44d8/qcnximjsn1lkb10zg.jpg[/IMG]PHONE State = DEAD by OTA update I tried to repair PHONE via TP & eMMC but no SUCCESS then removed eMMC and tried on adapter but a same result LOG : Code: Welcome to Medusa Pro Software version 2.0.0. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: FT SCR2000 2 Reader #3: Generic Usb Smart Card Reader 0 Reader #4: Generic Usb Smart Card Reader 1 Reader #5: Generic Usb Smart Card Reader 2 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 8 bits Bus speed : 20 MHz Connecting... Device : Unknown eMMC S0J38Y Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 13014E53304A333859100B3FD013C571 Manufacturer ID : 0X13 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4E Product name : S0J38Y Product revision : 1.0 Product serial number : (hex) B3FD013 Manufacturing date : 12/2018 --------------------------------------------------------------- CSD Info CSD : D05F01328F5913FFFFFFFFEF964000A9 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 50 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x78) 01111000 Boot partition enable : User area (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 20348928 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 4620288 Number of sectors : 7241728 Build ID : OPM1.171019.011 Display Build ID : System 8.2.0.104(0079) Release ID : 8.1.0 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : generic_a15-user 8.1.0 OPM1.171019.011 eng.jenkin.20190411.160453 test-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/S0J38Y_26_12_2019_09_26_03.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.0; FW: 1.24. P00: GPT (00000000, 00000400) 512 KB P01: frp (00000400, 00000400) 512 KB P02: persist (00000800, 00001000) 2048 KB P03: reserved1 (00001800, 00002800) 5 MB P04: reserved6 (00004000, 00000400) 512 KB P05: vrl (00004400, 00000400) 512 KB P06: vrl_backup (00004800, 00000400) 512 KB P07: modem_secure (00004C00, 00004400) 8.5 MB P08: nvme (00009000, 00002800) 5 MB P09: certification (0000B800, 00000800) 1024 KB P10: oeminfo (0000C000, 00020000) 64 MB P11: secure_storage (0002C000, 00010000) 32 MB P12: modem_om (0003C000, 00010000) 32 MB P13: modemnvm_factory (0004C000, 00008000) 16 MB P14: modemnvm_backup (00054000, 00008000) 16 MB P15: modemnvm_img (0005C000, 00011000) 34 MB P16: reserved7 (0006D000, 00001000) 2048 KB P17: hisee_encos (0006E000, 00002000) 4 MB P18: veritykey (00070000, 00000800) 1024 KB P19: ddr_para (00070800, 00000800) 1024 KB P20: reserved2 (00071000, 0000D800) 27 MB P21: splash2 (0007E800, 00028000) 80 MB P22: bootfail_info (000A6800, 00001000) 2048 KB P23: misc (000A7800, 00001000) 2048 KB P24: dfx (000A8800, 00008000) 16 MB P25: rrecord (000B0800, 00008000) 16 MB P26: fw_lpm3_a (000B8800, 00000200) 256 KB P27: reserved3_a (000B8A00, 00001E00) 3840 KB P28: hdcp_a (000BA800, 00000800) 1024 KB P29: hisee_img_a (000BB000, 00002000) 4 MB P30: hhee_a (000BD000, 00002000) 4 MB P31: hisee_fs_a (000BF000, 00004000) 8 MB P32: fastboot_a (000C3000, 00006000) 12 MB P33: vector_a (000C9000, 00002000) 4 MB P34: isp_boot_a (000CB000, 00001000) 2048 KB P35: isp_firmware_a (000CC000, 00007000) 14 MB P36: fw_hifi_a (000D3000, 00006000) 12 MB P37: teeos_a (000D9000, 00004000) 8 MB P38: sensorhub_a (000DD000, 00008000) 16 MB P39: erecovery_kernel_a (000E5000, 0000C000) 24 MB P40: erecovery_ramdisk_a (000F1000, 00010000) 32 MB P41: erecovery_vendor_a (00101000, 00008000) 16 MB P42: kernel_a (00109000, 0000C000) 24 MB P43: ramdisk_a (00115000, 00008000) 16 MB P44: recovery_ramdisk_a (0011D000, 00010000) 32 MB P45: recovery_vendor_a (0012D000, 00008000) 16 MB P46: dts_a (00135000, 0000C000) 24 MB P47: dto_a (00141000, 00004000) 8 MB P48: trustfirmware_a (00145000, 00001000) 2048 KB P49: modem_fw_a (00146000, 0001C000) 56 MB P50: reserved4_a (00162000, 00006000) 12 MB P51: preload_a (00168000, 00004000) 8 MB P52: recovery_vbmeta_a (0016C000, 00001000) 2048 KB P53: erecovery_vbmeta_a (0016D000, 00001000) 2048 KB P54: vbmeta_a (0016E000, 00002000) 4 MB P55: modemnvm_update_a (00170000, 00008000) 16 MB P56: modemnvm_cust_a (00178000, 00008000) 16 MB P57: patch_a (00180000, 00010000) 32 MB P58: version_a (00190000, 00010000) 32 MB P59: vendor_a (001A0000, 0017C000) 760 MB P60: product_a (0031C000, 00060000) 192 MB P61: cust_a (0037C000, 00060000) 192 MB P62: odm_a (003DC000, 00058000) 176 MB P63: cache (00434000, 00034000) 104 MB P64: system_a (00468000, 006E8000) 3536 MB P65: userdata (00B50000, 0692C000) 52.59 GB Partition table has been found on device. Partition table is found from file C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin. Don't forget to reconnect the device after writing to see changes. Writting partitions. Please wait... Writing partition GPT from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... ERROR[012]: Write error. Attempting to read... Disconnected. Reconnect the device to see changes. I took an Samsung eMMC from Condor A100 LOG NEW eMMC : Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 8 bits Bus speed : 20 MHz Connecting... Device : Samsung eMMC CWBD3R Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 15010043574244335202151DB2EA820B Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : CWBD3R Product revision : 0.2 Product serial number : (hex) 151DB2EA Manufacturing date : 08/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF92404009 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 20357120 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 212992 Number of sectors : 5881856 Device Manufacturer : condor Device Platform : mt6795 Build ID : LMY47I Display Build ID : PGN607 Release ID : 5.1 Device Model : PGN607 Device Name : PGN607 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : full_gionee6795_lwt_l1-user 5.1 LMY47I 1439267902 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/CWBD3R_26_12_2019_09_45_18.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.0; FW: 1.24. P00: GPT (00000000, 00000400) 512 KB P01: proinfo (00000400, 00001800) 3072 KB P02: nvram (00001C00, 00002800) 5 MB P03: protect1 (00004400, 00005000) 10 MB P04: protect2 (00009400, 00005000) 10 MB P05: seccfg (0000E400, 00000200) 256 KB P06: lk (0000E600, 00000300) 384 KB P07: boot (0000E900, 00008000) 16 MB P08: recovery (00016900, 00008000) 16 MB P09: secro (0001E900, 00003000) 6 MB P10: para (00021900, 00000400) 512 KB P11: logo (00021D00, 00004000) 8 MB P12: frp (00025D00, 00000800) 1024 KB P13: expdb (00026500, 00005000) 10 MB P14: tee1 (0002B500, 00002800) 5 MB P15: tee2 (0002DD00, 00006300) 12.38 MB P16: system (00034000, 0059C000) 2872 MB P17: cache (005D0000, 000D4000) 424 MB P18: userdata (006A4000, 06DCFC00) 54.91 GB P19: flashinfo (07473C00, 00008000) 16 MB LOG FORMAT eMMC : Code: Factory Format will erase all eMMC data! Do you want to continue? Yes. Formating...Done. SW: 2.0.0; FW: 1.24. Disconnected. LOG WRITTING EXT_CSD : Code: Writing EXT_CSD succesfully complete! Disconnected. LOG eMMC GEOMETRY EDIT : Code: Flash geometry successfully changed. Boot1, Boot2 size changed to 4 MB. RPMB size changed to 512 KB. LOG CHANGING eMMC CID : Code: Changing CID to 13014E53304A333859100B3FD013C571. Write CID succesfully completed. Disconnected. Code: Write CSD successfully completed. Disconnected. LOG WRITTING BOOT 1 & 2 : Code: Switched to boot area partition 1. Opening C:/Users/STARKRIMES/Desktop/jkm-lx1/(BOOT1_HUAWEI_JKM-LX1) eMMC S0J38Y.bin file... Write data verification is enabled. Writing. Please wait... Done. SW: 2.0.0; FW: 1.24. Switched to boot area partition 2. Opening C:/Users/STARKRIMES/Desktop/jkm-lx1/(BOOT2_HUAWEI_JKM-LX1) eMMC S0J38Y.bin file... Write data verification is enabled. Writing. Please wait... Done. SW: 2.0.0; FW: 1.24. Code: |
The Following 8 Users Say Thank You to starkrimes For This Useful Post: |
12-26-2019, 13:14 | #2 (permalink) |
Member: 1191316 Status: Offline Thanks Meter: 900 | LOG WRITTING FULL DUMP : Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Unknown eMMC S0J38Y Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 13014E53304A333859100B3FD013C571 Manufacturer ID : 0X13 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4E Product name : S0J38Y Product revision : 1.0 Product serial number : (hex) B3FD013 Manufacturing date : 12/2018 --------------------------------------------------------------- CSD Info CSD : D05F01328F5913FFFFFFFFEF964000A9 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 50 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 20357120 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/S0J38Y_26_12_2019_12_11_12.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.0; FW: 1.24. Partition table was not found. Partition table is found from file C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin. Don't forget to reconnect the device after writing to see changes. Writting partitions. Please wait... Writing partition GPT from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition frp from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition persist from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition reserved1 from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition reserved6 from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition vrl from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition vrl_backup from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition modem_secure from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition nvme from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition certification from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition oeminfo from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition secure_storage from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition modem_om from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition modemnvm_factory from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition modemnvm_backup from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition modemnvm_img from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition reserved7 from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition hisee_encos from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition veritykey from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition ddr_para from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition reserved2 from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition splash2 from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition bootfail_info from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition misc from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition dfx from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition rrecord from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition fw_lpm3_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition reserved3_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition hdcp_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition hisee_img_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition hhee_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition hisee_fs_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition fastboot_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition vector_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition isp_boot_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition isp_firmware_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition fw_hifi_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition teeos_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition sensorhub_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition erecovery_kernel_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition erecovery_ramdisk_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition erecovery_vendor_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition kernel_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition ramdisk_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition recovery_ramdisk_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition recovery_vendor_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition dts_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition dto_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition trustfirmware_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition modem_fw_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition reserved4_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition preload_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition recovery_vbmeta_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition erecovery_vbmeta_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition vbmeta_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition modemnvm_update_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition modemnvm_cust_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition patch_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition version_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition vendor_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition product_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition cust_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition odm_a from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing partition cache from C:/Users/STARKRIMES/Desktop/jkm-lx1/HUAWEI Y9 2019 JKM-LX1 eMMC DUMP/JKM-LX1 eMMC DUMP.bin file... Done. Writing is finished. SW: 2.0.0; FW: 1.24. Reconnect the device to see changes. Disconnected. LOG AFTER REPAIR DONE : Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Unknown eMMC S0J38Y Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 13014E53304A333859100B3FD013C571 Manufacturer ID : 0X13 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4E Product name : S0J38Y Product revision : 1.0 Product serial number : (hex) B3FD013 Manufacturing date : 12/2018 --------------------------------------------------------------- CSD Info CSD : D05F01328F5913FFFFFFFFEF964000A9 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 50 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 20357120 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/S0J38Y_26_12_2019_12_35_30.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.0; FW: 1.24. P00: GPT (00000000, 00000400) 512 KB P01: frp (00000400, 00000400) 512 KB P02: persist (00000800, 00001000) 2048 KB P03: reserved1 (00001800, 00002800) 5 MB P04: reserved6 (00004000, 00000400) 512 KB P05: vrl (00004400, 00000400) 512 KB P06: vrl_backup (00004800, 00000400) 512 KB P07: modem_secure (00004C00, 00004400) 8.5 MB P08: nvme (00009000, 00002800) 5 MB P09: certification (0000B800, 00000800) 1024 KB P10: oeminfo (0000C000, 00020000) 64 MB P11: secure_storage (0002C000, 00010000) 32 MB P12: modem_om (0003C000, 00010000) 32 MB P13: modemnvm_factory (0004C000, 00008000) 16 MB P14: modemnvm_backup (00054000, 00008000) 16 MB P15: modemnvm_img (0005C000, 00011000) 34 MB P16: reserved7 (0006D000, 00001000) 2048 KB P17: hisee_encos (0006E000, 00002000) 4 MB P18: veritykey (00070000, 00000800) 1024 KB P19: ddr_para (00070800, 00000800) 1024 KB P20: reserved2 (00071000, 0000D800) 27 MB P21: splash2 (0007E800, 00028000) 80 MB P22: bootfail_info (000A6800, 00001000) 2048 KB P23: misc (000A7800, 00001000) 2048 KB P24: dfx (000A8800, 00008000) 16 MB P25: rrecord (000B0800, 00008000) 16 MB P26: fw_lpm3_a (000B8800, 00000200) 256 KB P27: reserved3_a (000B8A00, 00001E00) 3840 KB P28: hdcp_a (000BA800, 00000800) 1024 KB P29: hisee_img_a (000BB000, 00002000) 4 MB P30: hhee_a (000BD000, 00002000) 4 MB P31: hisee_fs_a (000BF000, 00004000) 8 MB P32: fastboot_a (000C3000, 00006000) 12 MB P33: vector_a (000C9000, 00002000) 4 MB P34: isp_boot_a (000CB000, 00001000) 2048 KB P35: isp_firmware_a (000CC000, 00007000) 14 MB P36: fw_hifi_a (000D3000, 00006000) 12 MB P37: teeos_a (000D9000, 00004000) 8 MB P38: sensorhub_a (000DD000, 00008000) 16 MB P39: erecovery_kernel_a (000E5000, 0000C000) 24 MB P40: erecovery_ramdisk_a (000F1000, 00010000) 32 MB P41: erecovery_vendor_a (00101000, 00008000) 16 MB P42: kernel_a (00109000, 0000C000) 24 MB P43: ramdisk_a (00115000, 00008000) 16 MB P44: recovery_ramdisk_a (0011D000, 00010000) 32 MB P45: recovery_vendor_a (0012D000, 00008000) 16 MB P46: dts_a (00135000, 0000C000) 24 MB P47: dto_a (00141000, 00004000) 8 MB P48: trustfirmware_a (00145000, 00001000) 2048 KB P49: modem_fw_a (00146000, 0001C000) 56 MB P50: reserved4_a (00162000, 00006000) 12 MB P51: preload_a (00168000, 00004000) 8 MB P52: recovery_vbmeta_a (0016C000, 00001000) 2048 KB P53: erecovery_vbmeta_a (0016D000, 00001000) 2048 KB P54: vbmeta_a (0016E000, 00002000) 4 MB P55: modemnvm_update_a (00170000, 00008000) 16 MB P56: modemnvm_cust_a (00178000, 00008000) 16 MB P57: patch_a (00180000, 00010000) 32 MB P58: version_a (00190000, 00010000) 32 MB P59: vendor_a (001A0000, 0017C000) 760 MB P60: product_a (0031C000, 00060000) 192 MB P61: cust_a (0037C000, 00060000) 192 MB P62: odm_a (003DC000, 00058000) 176 MB P63: cache (00434000, 00034000) 104 MB P64: system_a (00468000, 006E8000) 3536 MB P65: userdata (00B50000, 0692C000) 52.59 GB Download MEDUSA PRO II Software v.2.0.0 Find out more at: https://medusabox.com/ |
The Following 13 Users Say Thank You to starkrimes For This Useful Post: |
01-03-2020, 08:28 | #3 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | nice share with full steps … it really takes time can you share the Dump please |
The Following 3 Users Say Thank You to Fast Unlocker For This Useful Post: |
01-04-2020, 14:41 | #5 (permalink) |
No Life Poster Join Date: Jun 2011 Location: earth
Member: 1591394 Status: Offline Thanks Meter: 552 | https://mega.nz/#!fdQ12aCS!4FMke8Efd...59rRtBLchLykcw its tested by ufi but can work with medusa i think |
The Following 2 Users Say Thank You to kikas112 For This Useful Post: |
01-04-2020, 15:33 | #6 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | goood work thanks for posting all steps and result... whats about imei and network...how you repair |
The Following User Says Thank You to chand_gee For This Useful Post: |
