11-01-2020, 03:58 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | 1st World SAMSUNG M30 SM-M305F FRP & MDM U6 REMOVE DONE VIA eMMC [IMG]****************************/convkey/2929/akzsnfnbmk8efylzg.jpg?size_id=7[/IMG] 1st World SAMSUNG M30 SM-M305F/DS FRP & MDM LOCKS BINARY U6 REMOVE DONE VIA eMMC & VIA SRF FILE CREATED FROM OTHER SMOOTHLY WORKING PHONE BY THE GIANT MEDUSA PRO [IMG]****************************/convkey/ad6e/fw4lt64oez5g0zizg.jpg[/IMG]LOG INFO : Code: Selected BGA 153/169 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-M305F-DS SRF : E:/FLASH TELEPHONE/eMMC PROJECTS/M305F-DS SRF/Samsung_M305F-DS_U6_FRP_MDM_OFF_By_STARKRIMES.srf Voltage : 1.8V Bus Mode : 4 bits Bus speed : 50 MHz Full speed mode! Connecting... Device : Samsung eMMC BJTD4R Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100424A54443452004BE895E6864F Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : BJTD4R Product revision : 0.0 Product serial number : (hex) 4BE895E6 Manufacturing date : 08/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/BJTD4R_01_11_2020_03_35_00.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.4; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: bota0 (00002000, 00002000) 4 MB P02: bota1 (00004000, 00004000) 8 MB P03: efs (00008000, 0000A000) 20 MB P04: cpefs (00012000, 00004000) 8 MB P05: cm (00016000, 00004000) 8 MB P06: m9kefs1 (0001A000, 00002000) 4 MB P07: m9kefs2 (0001C000, 00002000) 4 MB P08: m9kefs3 (0001E000, 00002000) 4 MB P09: nad_refer (00020000, 00000800) 1024 KB P10: param (00020800, 00004000) 8 MB P11: misc (00024800, 00001000) 2048 KB P12: boot (00025800, 00010000) 32 MB P13: recovery (00035800, 00013000) 38 MB P14: dtb (00048800, 00004000) 8 MB P15: dtbo (0004C800, 00004000) 8 MB P16: radio (00050800, 00016800) 45 MB P17: persistent (00067000, 00000400) 512 KB P18: steady (00067400, 00002000) 4 MB P19: reserved2 (00069400, 00002C00) 5.5 MB P20: system (0006C000, 00770000) 3808 MB P21: vendor (007DC000, 000F8000) 496 MB P22: odm (008D4000, 000D4000) 424 MB P23: cache (009A8000, 0004B000) 150 MB P24: hidden (009F3000, 00032000) 100 MB P25: omr (00A25000, 0000A000) 20 MB P26: cp_debug (00A2F000, 00002800) 5 MB P27: nad_fw (00A31800, 0000A000) 20 MB P28: userdata (00A3B800, 03000800) 24 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/BJTD4R_efs_0x8000_0xa000_01_11_2020_03_35_00.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.4; FW: 2.00. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 442368 Number of sectors : 7798784 Build ID : QP1A.190711.020 Display Build ID : QP1A.190711.020.M305FDDU6CTI3 Release ID : 10 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : m30ltedd-user 10 QP1A.190711.020 M305FDDU6CTI3 release-keys ---------------------------------------------------------------RPMB: Counter of the successful data write requests = 4196. LOG SMART REPAIR (REMOVING MDM & FRP ) : Code: Repairing from file "E:/FLASH TELEPHONE/eMMC PROJECTS/M305F-DS SRF/Samsung_M305F-DS_U6_FRP_MDM_OFF_By_STARKRIMES.srf". Write data verification is enabled. Writing partition... Done. Writing persistent partition... Done. Smart Repair is successfully complete. SW: 2.1.4; FW: 2.00. Disconnected. Download MEDUSA PRO II V2.1.4 Software Find out more at: https://medusabox.com/ Download Octoplus PRO JTAG V2.1.4 Software Find out more at: www.octoplusbox.com |
The Following 5 Users Say Thank You to starkrimes For This Useful Post: |
