07-05-2020, 01:24 | #1 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,108 | A310F U5 FRP Reset and Dump File Read by Medusa Pro । 05 । 07 । 2020 FRP Reset Code: Welcome to Medusa Pro Software version 2.1.1. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC AJNB3R Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100414A4E42335203A337F09E93F5 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : AJNB3R Product revision : 0.3 Product serial number : (hex) A337F09E Manufacturing date : 09/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/AJNB3R_02_07_2020_20_40_27.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: BOTA1 (00004000, 00002000) 4 MB P03: EFS (00006000, 0000A000) 20 MB P04: CPEFS (00010000, 00004000) 8 MB P05: m9kefs1 (00014000, 00002000) 4 MB P06: m9kefs2 (00016000, 00002000) 4 MB P07: m9kefs3 (00018000, 00002000) 4 MB P08: CARRIER (0001A000, 00000800) 1024 KB P09: PARAM (0001A800, 00004000) 8 MB P10: BOOT (0001E800, 00010000) 32 MB P11: RECOVERY (0002E800, 00013000) 38 MB P12: OTA (00041800, 00004000) 8 MB P13: CDMA-RADIO (00045800, 00002000) 4 MB P14: RADIO (00047800, 0002C000) 88 MB P15: TOMBSTONES (00073800, 00000800) 1024 KB P16: DNT (00074000, 00000800) 1024 KB P17: PERSISTENT (00074800, 00000400) 512 KB P18: PERSDATA (00074C00, 00006000) 12 MB P19: RESERVED2 (0007AC00, 00001400) 2560 KB P20: SYSTEM (0007C000, 005DC000) 3000 MB P21: CACHE (00658000, 00064000) 200 MB P22: HIDDEN (006BC000, 0006E000) 220 MB P23: USERDATA (0072A000, 0162E000) 11.09 GB Backuping EFS partition... Opening C:/Program Files/Octoplus Pro JTAG Software/Backups/AJNB3R_EFS_0x6000_0xa000_02_07_2020_20_40_27.bin file... Reading. Please wait... Done. Elapsed time 00:00:08 SW: 2.1.1; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 507904 Number of sectors : 6144000 Device Manufacturer : samsung Device Platform : exynos5 Build ID : NRD90M Display Build ID : NRD90M.A310FXXS5CSF1 Release ID : 7.0 Device Model : SM-A310F Device Name : a3xeltexx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : a3xeltexx-user 7.0 NRD90M A310FXXS5CSF1 release-keys ---------------------------------------------------------------Backuping FRP data... Opening C:/Program Files/Octoplus Pro JTAG Software/Backups/FRP_0x74800_0x400_02_07_2020_20_40_51.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.1; FW: 1.24. Removing FRP. Please wait... Done. SW: 2.1.1; FW: 1.24. Dump File Read Code: Welcome to Medusa Pro Software version 2.1.1. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC AJNB3R Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100414A4E42335203A337F09E93F5 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : AJNB3R Product revision : 0.3 Product serial number : (hex) A337F09E Manufacturing date : 09/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/AJNB3R_02_07_2020_21_14_58.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: BOTA1 (00004000, 00002000) 4 MB P03: EFS (00006000, 0000A000) 20 MB P04: CPEFS (00010000, 00004000) 8 MB P05: m9kefs1 (00014000, 00002000) 4 MB P06: m9kefs2 (00016000, 00002000) 4 MB P07: m9kefs3 (00018000, 00002000) 4 MB P08: CARRIER (0001A000, 00000800) 1024 KB P09: PARAM (0001A800, 00004000) 8 MB P10: BOOT (0001E800, 00010000) 32 MB P11: RECOVERY (0002E800, 00013000) 38 MB P12: OTA (00041800, 00004000) 8 MB P13: CDMA-RADIO (00045800, 00002000) 4 MB P14: RADIO (00047800, 0002C000) 88 MB P15: TOMBSTONES (00073800, 00000800) 1024 KB P16: DNT (00074000, 00000800) 1024 KB P17: PERSISTENT (00074800, 00000400) 512 KB P18: PERSDATA (00074C00, 00006000) 12 MB P19: RESERVED2 (0007AC00, 00001400) 2560 KB P20: SYSTEM (0007C000, 005DC000) 3000 MB P21: CACHE (00658000, 00064000) 200 MB P22: HIDDEN (006BC000, 0006E000) 220 MB P23: USERDATA (0072A000, 0162E000) 11.09 GB Backuping EFS partition... Opening C:/Program Files/Octoplus Pro JTAG Software/Backups/AJNB3R_EFS_0x6000_0xa000_02_07_2020_21_14_58.bin file... Reading. Please wait... Done. Elapsed time 00:00:08 SW: 2.1.1; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 507904 Number of sectors : 6144000 Device Manufacturer : samsung Device Platform : exynos5 Build ID : NRD90M Display Build ID : NRD90M.A310FXXS5CSF1 Release ID : 7.0 Device Model : SM-A310F Device Name : a3xeltexx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : a3xeltexx-user 7.0 NRD90M A310FXXS5CSF1 release-keys ---------------------------------------------------------------Backuping FRP data... Opening C:/Program Files/Octoplus Pro JTAG Software/Backups/FRP_0x74800_0x400_02_07_2020_21_15_19.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.1; FW: 1.24. Removing FRP. Please wait... Done. SW: 2.1.1; FW: 1.24. Opening C:/Program Files/Octoplus Pro JTAG Software/A310F a3xeltexx-user 7.0 NRD90M A310FXXS5CSF1/Samsung eMMC AJNB3R_02_07_2020_21_16_26-a3xeltexx-user 7.0 NRD90M A310FXXS5CSF1-512MB.bin file... Reading. Please wait... Done. Elapsed time 00:03:35 SW: 2.1.1; FW: 1.24. Switched to boot area partition 1. Opening C:/Program Files/Octoplus Pro JTAG Software/A310F a3xeltexx-user 7.0 NRD90M A310FXXS5CSF1/Samsung eMMC AJNB3R_02_07_2020_21_20_46_Boot area-1.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.1; FW: 1.24. Switched to boot area partition 2. Opening C:/Program Files/Octoplus Pro JTAG Software/A310F a3xeltexx-user 7.0 NRD90M A310FXXS5CSF1/Samsung eMMC AJNB3R_02_07_2020_21_21_15-Boot area-2.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.1; FW: 1.24. Download===> Link 1, !! Link 2 !! Link 3 A310F a3xeltexx-user 7.0 NRD90M A310FXXS5CSF1_Dump File by Palash Ahammad
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. Last edited by ...:::::NP™:::::...; 07-05-2020 at 08:50. Reason: Info Updated |
The Following 5 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
