07-12-2021, 21:22 | #1 (permalink) |
Freak Poster Join Date: Aug 2013
Member: 2012251 Status: Offline Sonork: hat07 Thanks Meter: 28 | A315f dead Repair A315f dead by wiping persistent with cm2 Repair done by writing same firmware that was on the phone with isp without useedata and system. Last edited by hat07; 07-12-2021 at 21:30. |
07-13-2021, 16:02 | #3 (permalink) | |
Member: 2012251 Status: Offline Sonork: hat07 Thanks Meter: 28 | Quote:
Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Your current activation is not fully compatible with present hardware and requires an upgrade. Some features may be disabled or slower than expected. Use Card Update Tool to activate your upgrade string. Loading firmware. Please wait... Done. Selected eMMC interface. Socket detected! Get Measurements error. Reloading... Loading firmware. Please wait... Done. Selected eMMC interface. Your current activation is not fully compatible with present hardware and requires an upgrade. Some features may be disabled or slower than expected. Use Card Update Tool to activate your upgrade string. Socket detected! Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting to server. Please wait... Connection to server successful Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC DV6DMB Page size : 512 B Block size : 512 B Block count : 244285440 Size : 116.48 GB (119280.00 MB) --------------------------------------------------------------- CID Info CID : 150100445636444D4200274FD4D1B739 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : DV6DMB Product revision : 0.0 Product serial number : (hex) 274FD4D1 Manufacturing date : 11/2020 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 40714240 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/DV6DMB_12_07_2021_19_45_21.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.5; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: boot_para (00002000, 0000D000) 26 MB P02: para (0000F000, 00000400) 512 KB P03: efs (0000F400, 00004000) 8 MB P04: sec_efs (00013400, 00004000) 8 MB P05: bota (00017400, 0000E400) 28.5 MB P06: param (00025800, 00002000) 4 MB P07: up_param (00027800, 00002000) 4 MB P08: expdb (00029800, 0000A000) 20 MB P09: frp (00033800, 00000800) 1024 KB P10: nvcfg (00034000, 00010000) 32 MB P11: nvdata (00044000, 00020000) 64 MB P12: metadata (00064000, 00010000) 32 MB P13: protect1 (00074000, 00004000) 8 MB P14: protect2 (00078000, 00004000) 8 MB P15: seccfg (0007C000, 00004000) 8 MB P16: persist (00080000, 00018000) 48 MB P17: persistent (00098000, 00000400) 512 KB P18: misc (00098400, 00003C00) 7.5 MB P19: keyrefuge (0009C000, 00008000) 16 MB P20: recovery (000A4000, 00010000) 32 MB P21: md_udc (000B4000, 0000C000) 24 MB P22: sec1 (000C0000, 00001000) 2048 KB P23: proinfo (000C1000, 00001800) 3072 KB P24: md1img (000C2800, 00040000) 128 MB P25: spmfw (00102800, 00000800) 1024 KB P26: scp1 (00103000, 00000800) 1024 KB P27: sspm_1 (00103800, 00000800) 1024 KB P28: efuse (00104000, 00000400) 512 KB P29: nvram (00104400, 00020000) 64 MB P30: reserved2 (00124400, 00003C00) 7.5 MB P31: vbmeta (00128000, 00000080) 64 KB P32: vbmeta_samsung (00128080, 00000080) 64 KB P33: keydata (00128100, 00008000) 16 MB P34: metadata (00130100, 00010000) 32 MB P35: boot (00140100, 00010000) 32 MB P36: dtbo (00150100, 00004000) 8 MB P37: steady (00154100, 00002000) 4 MB P38: reserved3 (00156100, 00001F00) 3968 KB P39: gz1 (00158000, 00008000) 16 MB P40: gz2 (00160000, 00008000) 16 MB P41: lk (00168000, 00001000) 2048 KB P42: uh (00169000, 00001000) 2048 KB P43: tee1 (0016A000, 00003000) 6 MB P44: reserved (0016D000, 00003000) 6 MB P45: super (00170000, 00CA8000) 6.328 GB P46: prism (00E18000, 0015E000) 700 MB P47: optics (00F76000, 0000A000) 20 MB P48: cache (00F80000, 00064000) 200 MB P49: carrier (00FE4000, 00016800) 45 MB P50: omr (00FFA800, 00019000) 50 MB P51: spu (01013800, 00019000) 50 MB P52: userdata (0102C800, 0644D800) 50.15 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DV6DMB_efs_0xf400_0x4000_12_07_2021_19_45_21.bin file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.1.5; FW: 2.00. Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DV6DMB_nvdata_0x44000_0x20000_12_07_2021_19_45_21. bin file... Reading. Please wait... ERROR[008]: Data TX error. Attempting to read... Disconnected. Socket validation failed. Socket validation failed. Get Measurements error. Reloading... Loading firmware. Please wait... Done. Selected eMMC interface. Your current activation is not fully compatible with present hardware and requires an upgrade. Some features may be disabled or slower than expected. Use Card Update Tool to activate your upgrade string. Socket detected! Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC DV6DMB Page size : 512 B Block size : 512 B Block count : 244285440 Size : 116.48 GB (119280.00 MB) --------------------------------------------------------------- CID Info CID : 150100445636444D4200274FD4D1B739 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : DV6DMB Product revision : 0.0 Product serial number : (hex) 274FD4D1 Manufacturing date : 11/2020 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 40714240 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/DV6DMB_12_07_2021_19_47_24.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.5; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: boot_para (00002000, 0000D000) 26 MB P02: para (0000F000, 00000400) 512 KB P03: efs (0000F400, 00004000) 8 MB P04: sec_efs (00013400, 00004000) 8 MB P05: bota (00017400, 0000E400) 28.5 MB P06: param (00025800, 00002000) 4 MB P07: up_param (00027800, 00002000) 4 MB P08: expdb (00029800, 0000A000) 20 MB P09: frp (00033800, 00000800) 1024 KB P10: nvcfg (00034000, 00010000) 32 MB P11: nvdata (00044000, 00020000) 64 MB P12: metadata (00064000, 00010000) 32 MB P13: protect1 (00074000, 00004000) 8 MB P14: protect2 (00078000, 00004000) 8 MB P15: seccfg (0007C000, 00004000) 8 MB P16: persist (00080000, 00018000) 48 MB P17: persistent (00098000, 00000400) 512 KB P18: misc (00098400, 00003C00) 7.5 MB P19: keyrefuge (0009C000, 00008000) 16 MB P20: recovery (000A4000, 00010000) 32 MB P21: md_udc (000B4000, 0000C000) 24 MB P22: sec1 (000C0000, 00001000) 2048 KB P23: proinfo (000C1000, 00001800) 3072 KB P24: md1img (000C2800, 00040000) 128 MB P25: spmfw (00102800, 00000800) 1024 KB P26: scp1 (00103000, 00000800) 1024 KB P27: sspm_1 (00103800, 00000800) 1024 KB P28: efuse (00104000, 00000400) 512 KB P29: nvram (00104400, 00020000) 64 MB P30: reserved2 (00124400, 00003C00) 7.5 MB P31: vbmeta (00128000, 00000080) 64 KB P32: vbmeta_samsung (00128080, 00000080) 64 KB P33: keydata (00128100, 00008000) 16 MB P34: metadata (00130100, 00010000) 32 MB P35: boot (00140100, 00010000) 32 MB P36: dtbo (00150100, 00004000) 8 MB P37: steady (00154100, 00002000) 4 MB P38: reserved3 (00156100, 00001F00) 3968 KB P39: gz1 (00158000, 00008000) 16 MB P40: gz2 (00160000, 00008000) 16 MB P41: lk (00168000, 00001000) 2048 KB P42: uh (00169000, 00001000) 2048 KB P43: tee1 (0016A000, 00003000) 6 MB P44: reserved (0016D000, 00003000) 6 MB P45: super (00170000, 00CA8000) 6.328 GB P46: prism (00E18000, 0015E000) 700 MB P47: optics (00F76000, 0000A000) 20 MB P48: cache (00F80000, 00064000) 200 MB P49: carrier (00FE4000, 00016800) 45 MB P50: omr (00FFA800, 00019000) 50 MB P51: spu (01013800, 00019000) 50 MB P52: userdata (0102C800, 0644D800) 50.15 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DV6DMB_efs_0xf400_0x4000_12_07_2021_19_47_24.bin file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.1.5; FW: 2.00. Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DV6DMB_nvdata_0x44000_0x20000_12_07_2021_19_47_24. bin file... Reading. Please wait... Done. Elapsed time 00:00:21 SW: 2.1.5; FW: 2.00. ---------------------------------------------------------------Searching Android build info... Not found ---------------------------------------------------------------RPMB: Counter of the successful data write requests = 1657. Selected pit file: C:/Users/hat07/Desktop/a31 dump/u1/BL_A315FXXU1CUD4_CL21396524_QB39553526_REV00_user_ low_ship_MULTI_CERT.tar.md5 Unknown format of input file C:/Users/hat07/Desktop/a31 dump/u1/BL_A315FXXU1CUD4_CL21396524_QB39553526_REV00_user_ low_ship_MULTI_CERT.tar.md5! Selected pit file: C:/Users/hat07/Desktop/a31 dump/u1/A31_CIS_SER.pit Open file "C:/Users/hat07/Desktop/a31 dump/u1/BL_A315FXXU1CUD4_CL21396524_QB39553526_REV00_user_ low_ship_MULTI_CERT.tar.md5". Open file "C:/Users/hat07/Desktop/a31 dump/u1/AP_A315FXXU1CUD4_CL21396524_QB39553526_REV00_user_ low_ship_MULTI_CERT_meta_OS11.tar.md5". Open file "C:/Users/hat07/Desktop/a31 dump/u1/CP_A315FXXU1CUD4_CP18896574_CL21396524_QB39553526_ REV00_user_low_ship_MULTI_CERT.tar.md5". Open file "C:/Users/hat07/Desktop/a31 dump/u1/CSC_OMC_OJM_A315FOJM1CUD4_CL21396524_QB39553526_RE V00_user_low_ship_MULTI_CERT.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition bootloader... from 0 to 1B9 Done. Switched to user area. Writing partition param... from 25800 to 7A8 Done. Writing partition up_param... from 27800 to 7A8 Done. Writing partition recovery... from A4000 to E944 Done. Writing partition md_udc... from B4000 to 3 Done. Writing partition md1img... from C2800 to 13EA1 Done. Writing partition spmfw... from 102800 to 16 Done. Writing partition scp1... from 103000 to 132 Done. Writing partition sspm_1... from 103800 to 3CC Done. Writing partition efuse... from 104000 to 2 Done. Writing partition vbmeta... from 128000 to 7 Done. Writing partition vbmeta_samsung... from 128080 to 6 Done. Writing partition boot... from 140100 to 7D46 Done. Writing partition dtbo... from 150100 to 7F Done. Writing partition gz1... from 158000 to 13CC Done. Writing partition lk... from 168000 to 681 Done. Writing partition uh... from 169000 to D4 Done. Writing partition tee1... from 16A000 to 30E Done. Writing partition prism... from E18000 to 2BF62 Done. Writing partition optics... from F76000 to 1F5 Done. Writing partition cache... from F80000 to 3 Done. Writing partition omr... from FFA800 to 3 Done. Writing is finished. SW: 2.1.5; FW: 2.00. Smart report info: Hash code: 00000000000000000000000000000000000000000000000000 00000000000000 Super block size : 0x00000000 Bytes Super page size : 0x00000000 Bytes Optima write size : 0x00000000 Bytes Number of banks : 0 Bank0 init bad block : 0 Bank0 runtime bad block : 0 Bank0 remain reserved block : 0 Max erase count : 0 Min erase count : 0 Avg erase count : 0 Read reclaim count : 0 Optimal trim size : 0x00000000 Bytes Max erase count (SCL) : 0 Min erase count (SCL) : 0 Avg erase count (SCL) : 0 Max erase count (MLC) : 0 Min erase count (MLC) : 0 Avg erase count (MLC) : 0 DEVICE_LIFE_TIME_EST_TYP_B : 0% - 10% device life time used DEVICE_LIFE_TIME_EST_TYP_A : 0% - 10% device life time used PRE_EOL_INFO : Normal SW: 2.1.5; FW: 2.00. Disconnected. Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC DV6DMB Page size : 512 B Block size : 512 B Block count : 244285440 Size : 116.48 GB (119280.00 MB) --------------------------------------------------------------- CID Info CID : 150100445636444D4200274FD4D1B739 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : DV6DMB Product revision : 0.0 Product serial number : (hex) 274FD4D1 Manufacturing date : 11/2020 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 40714240 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/DV6DMB_12_07_2021_20_04_08.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.5; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: boot_para (00002000, 0000D000) 26 MB P02: para (0000F000, 00000400) 512 KB P03: efs (0000F400, 00004000) 8 MB P04: sec_efs (00013400, 00004000) 8 MB P05: bota (00017400, 0000E400) 28.5 MB P06: param (00025800, 00002000) 4 MB P07: up_param (00027800, 00002000) 4 MB P08: expdb (00029800, 0000A000) 20 MB P09: frp (00033800, 00000800) 1024 KB P10: nvcfg (00034000, 00010000) 32 MB P11: nvdata (00044000, 00020000) 64 MB P12: metadata (00064000, 00010000) 32 MB P13: protect1 (00074000, 00004000) 8 MB P14: protect2 (00078000, 00004000) 8 MB P15: seccfg (0007C000, 00004000) 8 MB P16: persist (00080000, 00018000) 48 MB P17: persistent (00098000, 00000400) 512 KB P18: misc (00098400, 00003C00) 7.5 MB P19: keyrefuge (0009C000, 00008000) 16 MB P20: recovery (000A4000, 00010000) 32 MB P21: md_udc (000B4000, 0000C000) 24 MB P22: sec1 (000C0000, 00001000) 2048 KB P23: proinfo (000C1000, 00001800) 3072 KB P24: md1img (000C2800, 00040000) 128 MB P25: spmfw (00102800, 00000800) 1024 KB P26: scp1 (00103000, 00000800) 1024 KB P27: sspm_1 (00103800, 00000800) 1024 KB P28: efuse (00104000, 00000400) 512 KB P29: nvram (00104400, 00020000) 64 MB P30: reserved2 (00124400, 00003C00) 7.5 MB P31: vbmeta (00128000, 00000080) 64 KB P32: vbmeta_samsung (00128080, 00000080) 64 KB P33: keydata (00128100, 00008000) 16 MB P34: metadata (00130100, 00010000) 32 MB P35: boot (00140100, 00010000) 32 MB P36: dtbo (00150100, 00004000) 8 MB P37: steady (00154100, 00002000) 4 MB P38: reserved3 (00156100, 00001F00) 3968 KB P39: gz1 (00158000, 00008000) 16 MB P40: gz2 (00160000, 00008000) 16 MB P41: lk (00168000, 00001000) 2048 KB P42: uh (00169000, 00001000) 2048 KB P43: tee1 (0016A000, 00003000) 6 MB P44: reserved (0016D000, 00003000) 6 MB P45: super (00170000, 00CA8000) 6.328 GB P46: prism (00E18000, 0015E000) 700 MB P47: optics (00F76000, 0000A000) 20 MB P48: cache (00F80000, 00064000) 200 MB P49: carrier (00FE4000, 00016800) 45 MB P50: omr (00FFA800, 00019000) 50 MB P51: spu (01013800, 00019000) 50 MB P52: userdata (0102C800, 0D8C9800) 108.4 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DV6DMB_efs_0xf400_0x4000_12_07_2021_20_04_08.bin file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.1.5; FW: 2.00. Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DV6DMB_nvdata_0x44000_0x20000_12_07_2021_20_04_08. bin file... Reading. Please wait... Done. Elapsed time 00:00:21 SW: 2.1.5; FW: 2.00. ---------------------------------------------------------------Searching Android build info... Not found ---------------------------------------------------------------RPMB: Counter of the successful data write requests = 1657. Please select file. Get Measurements error. Reloading... Disconnected. | |
The Following User Says Thank You to hat07 For This Useful Post: |
