09-11-2021, 14:11 | #1 (permalink) |
Freak Poster Join Date: Aug 2013
Member: 2012251 Status: Offline Sonork: hat07 Thanks Meter: 28 | connecting problem sony g3221 [Answered] Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Unknown eMMC Page size : 512 B Block size : 512 B Block count : 0 Size : 0 b --------------------------------------------------------------- CID Info CID : 00000000000000000000000000000000 Manufacturer ID : 0X00 Device/BGA : Device (removable) OEM/Application ID : 0X00 Product name : Product revision : 0.0 Product serial number : (hex) 0 Manufacturing date : 00/1997 --------------------------------------------------------------- CSD Info CSD : 00000000000000000000000000000000 CSD structure : CSD version No. 1.0 SPEC version : Allocated by MMCA Data read access time1: 0 ms TRAN speed : 0 MHz READ block length : 1 Bytes WP group enable : NO PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.0 (for MMC v4.0) Erase block size : 0 Kbytes Boot1 size : 0 Kbytes Boot2 size : 0 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b EXT_CSD data error!!! Connect unsuccessful!!! Get Measurements error. Reloading... |
09-13-2021, 09:04 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Please, post here full software log. What box do you have? Try adding 150-300 Ohm resistors between the CMD <-> VCCQ, D0 <-> VCCQ lines as shown here |
09-15-2021, 22:10 | #3 (permalink) | |
Member: 2012251 Status: Offline Sonork: hat07 Thanks Meter: 28 | Quote:
09-16-2021, 07:26 | #4 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Try the following settings: Quote:
In what condition was the phone, it turned on? Check that the communication lines CMD, CLK, D0 are not short circuit on GND or power supply. | |
