01-06-2020, 22:21 | #1 (permalink) |
Major Poster Join Date: Feb 2012
Member: 1728056 Status: Offline Thanks Meter: 110 | Repair boot condor plume l2pro REPAIR BOOT CONDOR PLUME L2PRO READ & REPAIRED DONE VIA eMMC Code: Welcome to Medusa Pro Software version 2.0.1. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE63MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514536334D4203F6AEA879C5D9 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE63MB Product revision : 0.3 Product serial number : (hex) F6AEA879 Manufacturing date : 12/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 1540096 Number of sectors : 6144000 Device Manufacturer : Condor Build ID : O11019 Display Build ID : SP633_V09_20181220 Release ID : 8.1.0 Device Model : Plume L2 Pro Device Name : Plume_L2_Pro Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : Plume_L2_Pro-user 8.1.0 O11019 1544532567 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QE63MB_06_01_2020_22_02_21.bin. Connect success |
The Following 7 Users Say Thank You to kaka88 For This Useful Post: |
01-07-2020, 13:04 | #4 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | Quote:
i didn't ask you for srf file just wanted to compare something on the logs you can back to my thread here and see http://forum.gsmhosting.com/vbb/f798...-emmc-2686450/ | |
The Following 3 Users Say Thank You to starkrimes For This Useful Post: |
01-07-2020, 13:51 | #5 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,103 | Yes no partition table in posted log Log for repaire is easy for users to compare first stat and After repaire |
The Following User Says Thank You to rebainoor For This Useful Post: |
01-07-2020, 18:57 | #6 (permalink) |
Member: 1191316 Status: Offline Thanks Meter: 900 | The SRF file you made is only for 16GB and can make an isseu with finger print & camera and not compatible with 32GB model i asked you for log just for that but the version on my thread compatible with both models PROVE : Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 1540096 Number of sectors : 6144000 Device Manufacturer : Condor Build ID : O11019 Display Build ID : SP633_V09_20181220 Release ID : 8.1.0 Device Model : Plume L2 Pro Device Name : Plume_L2_Pro Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : Plume_L2_Pro-user 8.1.0 O11019 1544532567 release-keys |
01-07-2020, 19:17 | #7 (permalink) | |
Member: 1728056 Status: Offline Thanks Meter: 110 | Quote:
01-07-2020, 19:25 | #9 (permalink) | |
i'm not judging you bro, just gave you advice and to prove my speech try flash the sp633 v09 on both devices and see i'm talking on experience hope you take it as an advice not judge or challenge regards | |
The Following User Says Thank You to starkrimes For This Useful Post: |
01-07-2020, 21:08 | #10 (permalink) | |
The Following User Says Thank You to kaka88 For This Useful Post: |
