12-02-2020, 05:30 | #1 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | cph1803 one click pattern unlock done Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE63MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514536334D4203D7DDF2EB75F5 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE63MB Product revision : 0.3 Product serial number : (hex) D7DDF2EB Manufacturing date : 07/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE63MB_02_12_2020_09_52_05.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.6; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: oppodycnvbk (00000028, 00005000) 10 MB P02: oppostanvbk (00005028, 00005000) 10 MB P03: modemst1 (0000A028, 00000C00) 1536 KB P04: modemst2 (0000AC28, 00000C00) 1536 KB P05: persist (0000B828, 00010000) 32 MB P06: opporeserve1 (0001B828, 00004000) 8 MB P07: opporeserve2 (0001F828, 00020000) 64 MB P08: reserve_exp1 (0003F828, 00001000) 2048 KB P09: reserve_exp2 (00040828, 00001000) 2048 KB P10: fsc (00041828, 00000002) 1024 b P11: ssd (00041830, 00000010) 8 KB P12: sbl1 (00041840, 00000400) 512 KB P13: rpm (00041C40, 00000400) 512 KB P14: tz (00042040, 00001000) 2048 KB P15: devcfg (00043040, 00000200) 256 KB P16: sbl1bak (00043240, 00000400) 512 KB P17: rpmbak (00043640, 00000400) 512 KB P18: tzbak (00043A40, 00001000) 2048 KB P19: devcfgbak (00044A40, 00000200) 256 KB P20: dsp (00044C40, 00008000) 16 MB P21: DDR (00050000, 00000040) 32 KB P22: fsg (00050040, 00000C00) 1536 KB P23: sec (00050C40, 00000020) 16 KB P24: aboot (00050C60, 00000800) 1024 KB P25: abootbak (00051460, 00000800) 1024 KB P26: modem (00051C60, 00040000) 128 MB P27: dtbo (00091C60, 00004000) 8 MB P28: vbmeta (00095C60, 00000080) 64 KB P29: boot (00095CE0, 00020000) 64 MB P30: recovery (000B5CE0, 00020000) 64 MB P31: devinfo (000D5CE0, 00000800) 1024 KB P32: splash (000D8000, 00005800) 11 MB P33: LOGO (000DD800, 00010000) 32 MB P34: DRIVER (000ED800, 00010000) 32 MB P35: cache (000FD800, 00080000) 256 MB P36: misc (0017D800, 00000800) 1024 KB P37: keystore (0017E000, 00000400) 512 KB P38: config (0017E400, 00000040) 32 KB P39: oem (0017E440, 00000800) 1024 KB P40: limits (00180000, 00000040) 32 KB P41: mota (00184000, 00000400) 512 KB P42: dip (00184400, 00000800) 1024 KB P43: mdtp (00184C00, 00010000) 32 MB P44: syscfg (00194C00, 00000400) 512 KB P45: mcfg (00195000, 00002000) 4 MB P46: lksecapp (00198000, 00000100) 128 KB P47: cmnlib (00198100, 00000800) 1024 KB P48: cmnlib64 (00198900, 00000800) 1024 KB P49: keymaster (00199100, 00000800) 1024 KB P50: lksecappbak (00199900, 00000100) 128 KB P51: cmnlibbak (00199A00, 00000800) 1024 KB P52: cmnlib64bak (0019A200, 00000800) 1024 KB P53: keymasterbak (0019AA00, 00000800) 1024 KB P54: apdp (0019C000, 00000200) 256 KB P55: msadp (0019C200, 00000200) 256 KB P56: dpo (0019C400, 00000010) 8 KB P57: logdump (0019C410, 00020000) 64 MB P58: vm-kystore (001BC410, 00000800) 1024 KB P59: vm-data (001BCC10, 00005000) 10 MB P60: hyp (001C4000, 00004000) 8 MB P61: vm-system (001C8000, 00020000) 64 MB P62: vm-linux (001E8000, 00010000) 32 MB P63: system (001F8000, 006B4800) 3433 MB P64: vendor (008AC800, 0020FB00) 1055 MB P65: userdata (00AC0000, 0125EFDF) 9.186 GB Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QE63MB_modemst1_0xa028_0xc00_02_12_2020_09_52_05.b in file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.6; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QE63MB_modemst2_0xac28_0xc00_02_12_2020_09_52_05.b in file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.6; FW: 1.24. Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QE63MB_fsg_0x50040_0xc00_02_12_2020_09_52_05.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.6; FW: 1.24. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 2064384 Number of sectors : 7030784 Build ID : OPM1.171019.026 Release ID : 8.1.0 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20201010.154803 release-keys --------------------------------------------------------------- Reset operation finished Disconnected. |
The Following User Says Thank You to kamal_singla For This Useful Post: |
