09-16-2022, 19:53 | #1 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2686529 Status: Offline Thanks Meter: 0 | Emcp Bga 254, no userdata partition [Answered] Medusa pro Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.2V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Samsung eMMC DD68MB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100444436384D4202A3BEACF19463 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : DD68MB Full name one from : KMDD60018M-B320 Product revision : 0.2 Product serial number : (hex) A3BEACF1 Manufacturing date : 09/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/DD68MB_12_09_2022_21_37_11.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.4.7; FW: 1.24. P00: GPT (00000000, 00000100) 128 KB P01: xbl_a (00000100, 00001C00) 3584 KB P02: xbl_b (00001D00, 00001C00) 3584 KB P03: tz_a (00003900, 00001000) 2048 KB P04: tz_b (00004900, 00001000) 2048 KB P05: rpm_a (00005900, 00000400) 512 KB P06: rpm_b (00005D00, 00000400) 512 KB P07: hyp_a (00006100, 00000400) 512 KB P08: hyp_b (00006500, 00000400) 512 KB P09: devcfg_a (00006900, 00000100) 128 KB P10: devcfg_b (00006A00, 00000100) 128 KB P11: pmic_a (00006B00, 00000400) 512 KB P12: pmic_b (00006F00, 00000400) 512 KB P13: abl_a (00007300, 00000800) 1024 KB P14: abl_b (00007B00, 00000800) 1024 KB P15: cmnlib_a (00008300, 00000400) 512 KB P16: cmnlib64_a (00008700, 00000400) 512 KB P17: cmnlib_b (00008B00, 00000400) 512 KB P18: cmnlib64_b (00008F00, 00000400) 512 KB P19: keymaster_a (00009300, 00000400) 512 KB P20: keymaster_b (00009700, 00000400) 512 KB P21: storsec_a (00009B00, 00000100) 128 KB P22: storsec_b (00009C00, 00000100) 128 KB P23: prov_a (00009D00, 00000200) 256 KB P24: prov_b (00009F00, 00000200) 256 KB P25: modem_a (0000A100, 00037000) 110 MB P26: modem_b (00041100, 00037000) 110 MB P27: fsc (00078100, 00000002) 1024 b P28: ssd (00078108, 00000010) 8 KB P29: dsp_a (00078200, 00008000) 16 MB P30: dsp_b (00080200, 00008000) 16 MB P31: ddr (00088200, 00000800) 1024 KB P32: utags (00088A00, 00000400) 512 KB P33: utagsBackup (00088E00, 00000400) 512 KB P34: modemst1 (00089200, 00001000) 2048 KB P35: modemst2 (0008A200, 00001000) 2048 KB P36: fsg_a (0008B200, 00003000) 6 MB P37: fsg_b (0008E200, 00003000) 6 MB P38: persist (00091200, 00010000) 32 MB P39: frp (000A1200, 00000400) 512 KB P40: cid (000A1600, 00000100) 128 KB P41: carrier (000A1700, 00008000) 16 MB P42: metadata (000A9700, 00000400) 512 KB P43: kpan (000A9B00, 00004000) 8 MB P44: boot_a (000ADB00, 00020000) 64 MB P45: boot_b (000CDB00, 00020000) 64 MB P46: dto_a (000EDB00, 00008000) 16 MB P47: dto_b (000F5B00, 00008000) 16 MB P48: misc (000FDB00, 00000800) 1024 KB P49: logfs (000FE300, 00004000) 8 MB P50: apdp (00102300, 00000200) 256 KB P51: msadp (00102500, 00000200) 256 KB P52: dpo (00102700, 00000002) 1024 b P53: devinfo (00102708, 00000002) 1024 b P54: bluetooth_a (00102710, 00002400) 4.5 MB P55: bluetooth_b (00104B10, 00002400) 4.5 MB P56: logo_a (00106F10, 00010520) 32.64 MB P57: logo_b (00117430, 00010520) 32.64 MB P58: vbmeta_a (00127950, 00000080) 64 KB P59: vbmeta_b (001279D0, 00000080) 64 KB SW: 2.2.4.7; FW: 1.24. Backuping GPT partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DD68MB_GPT_0x0_0x100_12_09_2022_21_41_23.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.4.7; FW: 1.24. Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DD68MB_modemst1_0x89200_0x1000_12_09_2022_21_41_23 .bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.2.4.7; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DD68MB_modemst2_0x8a200_0x1000_12_09_2022_21_41_23 .bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.2.4.7; FW: 1.24. Backuping cid partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DD68MB_cid_0xa1600_0x100_12_09_2022_21_41_23.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 |
09-19-2022, 15:12 | #3 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. Please try to up voltage to 2.8v and reduce Bus speed, then repeat operation again. Post the result here. Also, what did you do with this device before? Last edited by Medusa Box; 09-20-2022 at 08:16. |
