05-22-2018, 11:52 | #1 (permalink) |
Banned Join Date: Jan 2008
Member: 692226 Status: Offline Thanks Meter: 19 | How to repair GT-N7100 with product code 00000 via eMMC? [Solved] Emmc connect sucessfuly just want to know next steps . Kindly expalin me experts best way to repair ... Thanks Last edited by Medusa Box; 05-22-2018 at 14:24. |
05-22-2018, 12:52 | #3 (permalink) | |
Member: 692226 Status: Offline Thanks Meter: 19 | Quote:
Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC 000000 Page size : 512 B Block size : 512 B Block count : 33554432 Size : 16.00 GB (16384.00 MB) --------------------------------------------------------------- CID Info CID : 1501003030303030305620110726589D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 000000 Product revision : 5.6 Product serial number : (hex) 20110726 Manufacturing date : 05/2021 --------------------------------------------------------------- CSD Info CSD : 902701320F5903FFF6DBFFEF8A404023 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 512 Kbytes Boot2 size : 512 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 4026531840 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/000000_19_05_2018_21_49_21.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.9; FW: 1.23. | |
05-22-2018, 13:11 | #4 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Accordingly to your Software log eMMC firmware is damaged in your device. You can try to write/update eMMC firmware if this eMMC chip is supported. Please check eMMC part number, connect the device, go to "eMMC service" tab in Software and press "Write/Update firmware" button. Then check in eMMC list, whether eMMC part number is present in it. If eMMC is present - select necessary eMMC from the list and press "Write/Update eMMC firmware" button to write eMMC firmware. When eMMC firmware will be written correctly, re-connect eMMC and check, whether product code was successfully repaired. Post here the result. |
05-22-2018, 13:21 | #5 (permalink) | |
Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC 000000 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 1501003030303030300C201301281063 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 000000 Product revision : 0.12 Product serial number : (hex) 20130128 Manufacturing date : 01/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8E40406D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7659520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/000000_19_05_2018_21_53_24.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.9; FW: 1.23. Writing eMMC firmware from file: C:/Program Files (x86)/Medusa Pro Software/EMMC_firmwares/KMVTU000LM-B503/KMVTU000LM-B503_FW.bin...Done. Finalizing...Done. Changing CID to 15010056545530304DF780F6213A2123. Write CID succesfully completed. Disconnected. EMMC writing firmware Done. SW: 1.5.9; FW: 1.23. Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC VTU00M Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 15010056545530304DF780F6213A2123 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : VTU00M Product revision : 15.7 Product serial number : (hex) 80F6213A Manufacturing date : 02/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8E40406D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7659520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/VTU00M_19_05_2018_21_53_54.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.9; FW: 1.23. Factory Format will erase all eMMC data! Do you want to continue? Yes. Formating...Done. SW: 1.5.9; FW: 1.23. Disconnected. | |
The Following User Says Thank You to unknownbeep For This Useful Post: |
