04-19-2021, 09:31 | #1 (permalink) |
Crazy Poster Join Date: Dec 2016 Location: Поль&# Age: 53
Member: 2664306 Status: Offline Thanks Meter: 2 | Error 011 when connecting with ufs [Answered] |
04-20-2021, 13:21 | #5 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. We are testing this problem on our own. Please try "GEAR: PWM Gear 1-4" mode. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
04-22-2021, 10:30 | #7 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. We found out what the problem is: "Resizing flash is incorrect". Here we have attached software log of connection original flash drive from SM-A705F. Physical partition number: 0 Size: 119.09 GB Physical partition number: 1 Size: 8.00 MB Physical partition number: 2 Size: 8.00 MB Physical partition number: 3 Size: 60.00 MB According to the log that you provided to us "Resizing flash is incorrect": Physical partition number: 0 Block count : 1024 (0x400) Size : 4.00 MB P00: GPT (00000000, 00000108) 1056 KB P01: modemst1 (00000108, 00000200) 2048 KB P02: modemst2 (00000308, 00000200) 2048 KB . . . Accordingly, when trying to perform a read operation, an error occurs: Backuping modemst2 partition ... Opening C: / Program Files (x86) / Medusa Pro Software / Backups / SAMSUNG_KM2H7001CM-B518_modemst2_0x308_0x200_19_04_2021_11_21_23.bin file ... Reading. Please wait ... ERROR [011]: Read error. The problem is that "Physical partition number: 0" is (4.00 MB) smaller than the address at which "modemst2" is read (4.00 MB +). The size "LUN 0-3" on the flash drive does not match the firmware "A705". There must be an error while writing. Because "Physical Partition Number: 0" was too small for the firmware. But at the same time the "GPT partition" was written. "Backup", while the connection could not be completed, a connection error occurs. In the next updates, we will solve the connection problem in such situations, and you will be able to work with these flash drives. |
04-22-2021, 19:34 | #8 (permalink) |
Member: 2664306 Status: Offline Thanks Meter: 2 | Thank you, we will wait for the update to arrive, and still solve the problem with the micron memory connection. Not as I can not give two phones away, people do not look beautiful anymore. |
